base Directory Reference
Files
cs_1d_wall_thermal.cpp
cs_1d_wall_thermal.h
cs_1d_wall_thermal_check.cpp
cs_1d_wall_thermal_check.h
cs_ale.cpp
cs_ale.h
cs_all_to_all.cpp
cs_all_to_all.h
cs_array.cpp
cs_array.h
cs_array_2dspan.h
cs_array_cuda.h
cs_array_reduce.cpp
cs_array_reduce.h
cs_assert.h
cs_ast_coupling.cpp
cs_ast_coupling.h
cs_base.cpp
cs_base.h
cs_base_accel.cpp
cs_base_accel.h
cs_base_cuda.h
cs_base_fortran.c
cs_base_fortran.h
cs_base_headers.h
cs_block_dist.cpp
cs_block_dist.h
cs_block_to_part.cpp
cs_block_to_part.h
cs_boundary.cpp
Handle the "physical" boundary conditions attached to a computational domain.
cs_boundary.h
cs_boundary_conditions.cpp
cs_boundary_conditions.h
cs_boundary_conditions_check.cpp
Check boundary condition codes.
cs_boundary_conditions_check.h
cs_boundary_conditions_coupling.cpp
cs_boundary_conditions_coupling.h
cs_boundary_conditions_priv.h
cs_boundary_conditions_set_coeffs.cpp
Translation of the boundary conditions given by the user in a form that fits the solver.
cs_boundary_conditions_set_coeffs.h
cs_boundary_conditions_set_coeffs_symmetry.cpp
Compute the symmetry boundary condition coefficients.
cs_boundary_conditions_set_coeffs_symmetry.h
cs_boundary_conditions_set_coeffs_turb.cpp
cs_boundary_conditions_set_coeffs_turb.h
cs_boundary_conditions_type.cpp
cs_boundary_conditions_type.h
cs_boundary_zone.cpp
cs_boundary_zone.h
cs_c_bindings.f90
Definition of C function and subroutine bindings.
cs_calcium.cpp
cs_calcium.h
cs_compute_thermo_pressure_density.cpp
cs_compute_thermo_pressure_density.h
cs_control.cpp
cs_control.h
cs_coolprop.cxx
cs_coolprop.hxx
cs_coupling.cpp
cs_coupling.h
cs_crystal_router.cpp
cs_crystal_router.h
cs_cuda_contrib.h
cs_debug.h
cs_defs.cpp
cs_defs.h
cs_dilatable_scalar_diff_st.cpp
cs_dilatable_scalar_diff_st.h
Weakly compressible algorithm (semi-analytic): Computation of scalar diffusion terms.
cs_dispatch.h
cs_drift_convective_flux.cpp
cs_drift_convective_flux.h
cs_eos.cxx
cs_eos.hxx
cs_equation_iterative_solve.cpp
This file gathers functions that solve advection diffusion equations with source terms for one time step for a scalar, vector or tensor variable.
cs_equation_iterative_solve.h
cs_execution_context.cpp
cs_execution_context.h
cs_ext_library_info.cpp
cs_ext_library_info.h
cs_ext_neighborhood.cpp
cs_ext_neighborhood.h
cs_fan.cpp
cs_fan.h
cs_field.cpp
cs_field.h
cs_field_default.cpp
cs_field_default.h
cs_field_operator.cpp
cs_field_operator.h
cs_field_pointer.cpp
cs_field_pointer.h
cs_file.cpp
cs_file.h
cs_file_csv_parser.cpp
cs_file_csv_parser.h
cs_flag_check.cpp
cs_flag_check.h
cs_fp_exception.cpp
cs_fp_exception.h
cs_function.cpp
Function objects management.
cs_function.h
cs_function_default.cpp
cs_function_default.h
cs_gas_mix.cpp
cs_gas_mix.h
cs_halo.cpp
cs_halo.h
cs_halo_cuda.h
cs_halo_perio.cpp
cs_halo_perio.h
cs_head_losses.cpp
cs_head_losses.h
cs_ht_convert.cpp
cs_ht_convert.h
cs_ibm.cpp
cs_ibm.h
cs_initialize_fields.cpp
Various field initializations.
cs_initialize_fields.h
cs_interface.cpp
cs_interface.h
cs_internal_coupling.cpp
cs_internal_coupling.h
cs_interpolate.cpp
cs_interpolate.h
cs_io.cpp
cs_io.h
cs_log.cpp
cs_log.h
cs_log_iteration.cpp
Log field and other array statistics at relevant time steps.
cs_log_iteration.h
cs_log_setup.cpp
Setup info at the end of the setup stage.
cs_log_setup.h
cs_map.cpp
cs_map.h
cs_mass_source_terms.cpp
cs_mass_source_terms.h
cs_math.cpp
cs_math.h
cs_measures_util.cpp
cs_measures_util.h
cs_medcoupling_intersector.cxx
cs_medcoupling_intersector.h
cs_medcoupling_mesh.cxx
cs_medcoupling_mesh.hxx
cs_medcoupling_postprocess.cxx
cs_medcoupling_postprocess.h
cs_medcoupling_remapper.cxx
cs_medcoupling_remapper.h
cs_medcoupling_utils.cxx
cs_medcoupling_utils.h
cs_mem.cpp
cs_mem.h
cs_mem_cuda_priv.h
cs_mobile_structures.cpp
cs_mobile_structures.h
cs_notebook.cpp
cs_notebook.h
cs_numbering.cpp
cs_numbering.h
cs_opts.cpp
cs_opts.h
cs_order.cpp
cs_order.h
cs_parall.cpp
cs_parall.h
cs_param_types.cpp
cs_param_types.h
cs_paramedmem_coupling.cxx
cs_paramedmem_coupling.h
cs_paramedmem_remapper.cxx
cs_paramedmem_remapper.h
cs_parameters.cpp
cs_parameters.h
cs_parameters_check.cpp
cs_parameters_check.h
cs_part_to_block.cpp
cs_part_to_block.h
cs_physical_constants.cpp
cs_physical_constants.h
cs_physical_properties.cpp
cs_physical_properties.h
cs_physical_properties_default.cpp
cs_physical_properties_default.h
cs_porosity_from_scan.cpp
cs_porosity_from_scan.h
cs_porous_model.cpp
Porous model management.
cs_porous_model.h
cs_post.cpp
Post-processing management.
cs_post.h
cs_post_default.cpp
cs_post_default.h
cs_post_util.cpp
cs_post_util.h
cs_preprocess.cpp
cs_preprocess.h
cs_preprocessor_data.cpp
cs_preprocessor_data.h
cs_pressure_correction.cpp
cs_pressure_correction.h
cs_probe.cpp
Probes and profiles management.
cs_probe.h
cs_prototypes.h
cs_random.cpp
cs_random.h
cs_range_set.cpp
Operations related to handling of an owning rank for distributed entities.
cs_range_set.h
cs_rank_neighbors.cpp
cs_rank_neighbors.h
cs_renumber.cpp
cs_renumber.h
cs_resource.cpp
Resource allocation management (available time).
cs_resource.h
cs_restart.cpp
cs_restart.h
cs_restart_default.cpp
cs_restart_default.h
cs_restart_main_and_aux.cpp
cs_restart_main_and_aux.h
cs_restart_map.cpp
cs_restart_map.h
cs_rotation.cpp
cs_rotation.h
cs_runaway_check.cpp
Runaway (diverging) computation detection.
cs_runaway_check.h
cs_sat_coupling.cpp
cs_sat_coupling.h
cs_scalar_clipping.cpp
Clipping scalar field.
cs_scalar_clipping.h
cs_search.cpp
cs_search.h
cs_selector.cpp
cs_selector.h
cs_selector_f2c.f90
cs_setup.cpp
cs_setup.h
cs_solid_zone.cpp
cs_solid_zone.h
cs_solve_all.cpp
cs_solve_all.h
cs_solve_equation.cpp
This subroutine performs the solving the convection/diffusion equation (with eventually source terms and/or drift) for a field quantity over a time step.
cs_solve_equation.h
cs_solve_navier_stokes.cpp
cs_solve_navier_stokes.h
cs_solve_transported_variables.cpp
Resolution of source term convection diffusion equations for scalars in a time step.
cs_solve_transported_variables.h
cs_sort.cpp
cs_sort.h
cs_sort_partition.cpp
cs_sort_partition.h
cs_syr_coupling.cpp
cs_syr_coupling.h
cs_sys_coupling.cpp
cs_sys_coupling.h
cs_system_info.cxx
cs_system_info.h
cs_thermal_model.cpp
cs_thermal_model.h
cs_theta_scheme.cpp
cs_theta_scheme.h
cs_time_control.cpp
cs_time_control.h
cs_time_moment.cpp
Temporal moments management.
cs_time_moment.h
cs_time_plot.cpp
cs_time_plot.h
cs_time_step.cpp
cs_time_step.h
cs_time_step_compute.cpp
Compute the local time step and the local Courant and Fourier number.
cs_time_step_compute.h
cs_time_stepping.cpp
Main time loop.
cs_time_stepping.h
cs_time_table.cpp
cs_time_table.h
cs_timer.cpp
cs_timer.h
cs_timer_stats.cpp
cs_timer_stats.h
cs_tree.cpp
cs_tree.h
cs_turbomachinery.cpp
cs_turbomachinery.h
cs_utilities.cpp
cs_utilities.h
cs_velocity_pressure.cpp
cs_velocity_pressure.h
cs_vof.cpp
cs_vof.h
cs_volume_mass_injection.cpp
cs_volume_mass_injection.h
cs_volume_zone.cpp
cs_volume_zone.h
cs_wall_condensation.cpp
cs_wall_condensation.h
cs_wall_condensation_1d_thermal.cpp
cs_wall_condensation_1d_thermal.h
cs_wall_distance.cpp
cs_wall_distance.h
cs_wall_functions.cpp
cs_wall_functions.h
cs_xdef_eval_at_zone.cpp
cs_xdef_eval_at_zone.h
cs_zone.h
csinit.f90
cstnum.f90
Module for numerical constants.
cstphy.f90
Module for physical constants.
dimens.f90
Module for dimensions.
entsor.f90
Module for input/output.
field.f90
Module for field-related operations.
field_operator.f90
Module for field-based algebraic operations.
findpt.f90
This subroutine looks for the nearest element to the position (xx, yy, zz) among the element of xyzcen array.
fldprp.f90
Properties definition initialization, according to calculation type selected by the user.
fldvar.f90
Variables definition initialization, according to calculation type selected by the user.
iniini.f90
Commons default initialization before handing over the user.
majgeo.f90
mesh.f90
Module for mesh-related arrays.
numvar.f90
Module for variable numbering.
optcal.f90
Module for calculation options.
parall.f90
Module for basic MPI and OpenMP parallelism-related values.
paramx.f90
Module for definition of general parameters.
period.f90
Module for periodicity flags.
pointe.f90
Module for pointer variables.
src
base
Generated on
for code_saturne by
1.14.0
