1#ifndef __CS_TURBOMACHINERY_H__
2#define __CS_TURBOMACHINERY_H__
111 double rotation_velocity,
112 const double rotation_axis[3],
113 const double rotation_invariant[3]);
321 double dt_retry_multiplier);
Definition cs_defs.h:542
Definition cs_defs.h:342
cs_real_t cs_real_34_t[3][4]
Definition cs_defs.h:374
Definition cs_defs.h:543
@ dt
Definition cs_field_pointer.h:65
Definition cs_restart.h:95
void cs_turbomachinery_relative_velocity(int rotor_num, const cs_real_t coords[3], cs_real_t velocity[3])
Compute velocity relative to fixed coordinates at a given point.
Definition cs_turbomachinery.cpp:2070
void cs_turbomachinery_finalize(void)
Free turbomachinery structure.
Definition cs_turbomachinery.cpp:1694
void cs_turbomachinery_define(void)
Definitions for turbomachinery computation.
Definition cs_turbomachinery.cpp:1596
void cs_turbomachinery_set_rotation_velocity(int rotor_num, double omega)
Set rotation velocity.
Definition cs_turbomachinery.cpp:1924
void cs_turbomachinery_rotation_matrix(int rotor_num, double theta, cs_real_t matrix[3][4])
Compute rotation matrix.
Definition cs_turbomachinery.cpp:1831
int cs_turbomachinery_coupling_add(const char *sel_criteria, float tolerance, int verbosity)
Add a boundary coupling to the list of rotor/stator couplings.
Definition cs_turbomachinery.cpp:1527
const int * cs_turbomachinery_get_cell_rotor_num(void)
Return cell rotor number.
Definition cs_turbomachinery.cpp:1876
int cs_turbomachinery_join_add(const char *sel_criteria, float fraction, float plane, int verbosity, int visualization)
Add a cs_join_t structure to the list of rotor/stator joinings.
Definition cs_turbomachinery.cpp:1478
void cs_turbomachinery_restart_write(cs_restart_t *r)
Write turbomachinery metadata to checkpoint file.
Definition cs_turbomachinery.cpp:2141
int cs_turbomachinery_n_rotors(void)
Return number of rotors.
Definition cs_turbomachinery.cpp:1853
void cs_turbomachinery_rotate_fields(const cs_real_t dt[])
Rotation of vector and tensor fields.
Definition cs_turbomachinery.cpp:1995
void cs_turbomachinery_define_functions(void)
Create or access function objects specific to turbomachinery models (relative_pressure,...
Definition cs_turbomachinery.cpp:2178
void cs_turbomachinery_resize_cell_fields(void)
Resize cell-based fields.
Definition cs_turbomachinery.cpp:1751
void cs_turbomachinery_set_rotation_retry(int n_max_join_retries, double dt_retry_multiplier)
Set turbomachinery joining retry parameters.
Definition cs_turbomachinery.cpp:1947
void cs_turbomachinery_restart_mesh(void)
Update mesh for unsteady rotor/stator computation in case of restart.
Definition cs_turbomachinery.cpp:1575
int cs_turbomachinery_get_n_couplings(void)
Return number of boundary couplings used for rotor/stator model.
Definition cs_turbomachinery.cpp:1412
void cs_turbomachinery_restart_read(cs_restart_t *r)
Read turbomachinery metadata from restart file.
Definition cs_turbomachinery.cpp:2095
cs_turbomachinery_model_t cs_turbomachinery_get_model(void)
Return rotor/stator model.
Definition cs_turbomachinery.cpp:1393
void cs_turbomachinery_reinit_i_face_fields(void)
Reinitialize interior face-based fields.
Definition cs_turbomachinery.cpp:1728
cs_real_34_t * cs_turbomachinery_get_rotation_matrices(double dt)
Build rotation matrices for a given time interval.
Definition cs_turbomachinery.cpp:1969
Definition cs_turbomachinery.h:56
@ CS_TURBOMACHINERY_TRANSIENT
Definition cs_turbomachinery.h:60
@ CS_TURBOMACHINERY_NONE
Definition cs_turbomachinery.h:58
@ CS_TURBOMACHINERY_FROZEN
Definition cs_turbomachinery.h:59
void cs_turbomachinery_update_mesh(double *t_elapsed)
Update mesh for unsteady rotor/stator computation.
Definition cs_turbomachinery.cpp:1561
void cs_turbomachinery_initialize(void)
Initializations for turbomachinery computation.
Definition cs_turbomachinery.cpp:1628
void cs_turbomachinery_set_model(cs_turbomachinery_model_t model)
Define rotor/stator model.
Definition cs_turbomachinery.cpp:1372
double cs_turbomachinery_get_rotation_velocity(int rotor_num)
Return rotation velocity.
Definition cs_turbomachinery.cpp:1907
void cs_turbomachinery_get_wall_bc_coeffs(cs_real_t **coftur, cs_real_t **hfltur)
Get arrays associated to wall BC update.
Definition cs_turbomachinery.cpp:1891
void cs_turbomachinery_add_rotor(const char *cell_criteria, double rotation_velocity, const double rotation_axis[3], const double rotation_invariant[3])
Define a rotor by its axis and cell selection criteria.
Definition cs_turbomachinery.cpp:1434
