Enumerator dt local time step
p pressure
pgr granular pressure
pfr frictional pressure
vel velocity
k turbulent kinetic energy
eps turbulent dissipation
rij Reynolds stress tensor
phi for model
f_bar for model
alp_bl for or EBRSM model
omg for SST model
nusa for Spalart- Allmaras
hybrid_blend Blending factor for DDES
mesh_u mesh velocity
void_f void fraction
vol_f volume fraction
h enthalpy
t temperature
t_b temperature (at boundary faces)
e_tot total energy
h_tot total enthalpy
rho density (at cells)
rho_b density (at boundary faces)
cp isobaric specific heat
cv isochoric specific heat
mu molecular viscosity
mu_t turbulent dynamic viscosity
lambda Thermal conductivity
th_diff Dynamic thermal diffusivity
poro porosity
if_poro internal faces porosity
t_poro tensorial porosity
t_kelvin temperature, in Kelvin
vism mesh viscosity
volume_f homogeneous model volume fraction
mass_f homogeneous model mass fraction
energy_f homogeneous model energy fraction
pot_t potential temperature
ntdrp total number of droplets
chemistry chemistry species (indexed)
fm mixture fraction
fp2m mixture fraction variance
fsm soot mass fraction
npm soot precursor number
ygfm fresh gas fraction
potr Electric potential, real part
poti Electric potential, imaginary part
potva Vector potential
ycoel Constituent mass fraction
joulp Joule power
radsc radiation source
elech electric charge
curre current real
curim current imaginary
laplf laplace forces
magfl magnetic field
elefl electric field
rad_energy Radiative energy
rad_q Radiative flux
radiance (spectral) radiance field
rad_est Radiative flux explicit source term
rad_ist Radiative flux implicit source term
rad_abs Radiative absorption
rad_emi Radiative emission
rad_cak Radiative absorption coefficient
qinci Radiative incident radiative flux density
qinsp Spectral radiative incident flux
xlam Wall thermal conductivity
epa Wall thickness
emissivity Wall emissivity
fnet Boundary radiative flux
fconv Boundary radiative convective flux
hconv radiative exchange coefficient
fup Spectral upward radiative flux
fdown Spectral downward radiative flux
rad_ck_up Spectral upward Radiative absorption coefficient
rad_ck_down Spectral downward Radiative absorption coefficient
mol_mass gas mix molar max
head hydraulic head
humid Humidity
ym_w Mass fraction of dry air in humid air
t_l_pack Injected liquid water temperature
yh_l_pack Injected liquid water enthalpy
y_l_pack Mass of liquid per unit volume of cell
thermal_diff_h Humid air thermal diffusivity
thermal_diff_l Injected liquid water thermal diffusivity
pack_zone_id Id of the packing zone
yf_ncond non-condensable mass fraction
qp Turbulent Kinetic Energy q2
qfp Covariance q12
qfpxx XX component of qfp
qfpxy XY component of qfp
qfpxz XZ component of qfp
qfpyx YX component of qfp
qfpyy YY component of qfp
qfpyz YZ component of qfp
qfpzx ZX component of qfp
qfpzy ZY component of qfp
qfpzz ZZ component of qfp
gamma Interfacial mass transfer
ia Interfacial area
x2 x2 for droplets
d32 Sauter diameter
drag Phases drag
ad_mass Added mass
wlubr Wall lubrication
th_diff_t Turbulent thermal diffusivity
drho_dp drho over dp
drho_dh drho over dh
tau12_t turbulent tau12
lift Lift coefficient
disp_t Turbulent dispersion
surf_tens Surface tension
sl_corr Free surface correction weight for GLIM
fi field_a vol_f weight for GLIM
fj field_b vol_f weight for GLIM
drift_vel Particles drift velocity
yplus Wall distance: y+
vel_mean Mean velocity (for dispersed phases)
vel_rel Relative velocity (for dispersed phases)
dt_dp dtemp/dpress derivative
kindiff Particles kinetic diffusivity
coldiff Particles collisional diffusivity
elast Particles restitution coefficient
c_alpha Weighting coefficient for GEMMA model
add_var User added variables
user
CS_FIELD_N_POINTERS
