55#define CS_FIELD_INTENSIVE (1 << 0)
58#define CS_FIELD_EXTENSIVE (1 << 1)
63#define CS_FIELD_VARIABLE (1 << 2)
66#define CS_FIELD_PROPERTY (1 << 3)
69#define CS_FIELD_POSTPROCESS (1 << 4)
72#define CS_FIELD_ACCUMULATOR (1 << 5)
75#define CS_FIELD_USER (1 << 6)
78#define CS_FIELD_CDO (1 << 7)
309 const char *name_suffix,
546 const char *name_suffix);
567 const char *name_suffix);
592 const char *name_part_2,
593 const char *name_part_3);
697 double default_value,
719 const char *default_value,
745 const void *default_value,
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
int cs_field_set_key_int(cs_field_t *f, int key_id, int value)
Assign a integer value for a given key to a field.
Definition cs_field.cpp:3250
int cs_field_clear_key_int_bits(cs_field_t *f, int key_id, int mask)
Set integer bits matching a mask to 0 for a given key for a field.
Definition cs_field.cpp:3400
void cs_field_bc_coeffs_init(cs_field_bc_coeffs_t *bc_coeffs)
Definition cs_field.cpp:1502
void cs_field_init_bc_coeffs(cs_field_t *f)
Initialize boundary condition coefficients arrays.
Definition cs_field.cpp:2102
int cs_field_define_key_int(const char *name, int default_value, int type_flag)
Define a key for an integer value by its name and return an associated id.
Definition cs_field.cpp:2859
Definition cs_field.cpp:3298
int cs_field_key_flag(int key_id)
Get the type flag associated with a given key id.
Definition cs_field.cpp:3096
const void * cs_field_get_key_struct_const_ptr(const cs_field_t *f, int key_id)
Return a read-only pointer to a simple structure for a given key to a field.
Definition cs_field.cpp:3874
void cs_field_set_n_time_vals(cs_field_t *f, int n_time_vals)
Change the number of time values managed by a field.
Definition cs_field.cpp:1793
Definition cs_field.cpp:2512
cs_field_t * cs_field_by_double_composite_name_try(const char *name_part_1, const char *name_part_2, const char *name_part_3)
Return pointer to a field based on a double composite name if present.
Definition cs_field.cpp:2644
int cs_field_define_key_str(const char *name, const char *default_value, int type_flag)
Define a key for a string value by its name and return an associated id.
Definition cs_field.cpp:2933
void cs_field_set_values(cs_field_t *f, cs_real_t c)
Set current field values to the given constant.
Definition cs_field.cpp:2321
cs_field_t * cs_field_by_composite_name(const char *name_prefix, const char *name_suffix)
Return a pointer to a field based on a composite name.
Definition cs_field.cpp:2562
void * cs_field_get_key_struct_ptr(cs_field_t *f, int key_id)
Return a pointer to a simple structure for a given key to a field.
Definition cs_field.cpp:3795
void cs_field_destroy_all_keys(void)
Destroy all defined field keys and associated values.
Definition cs_field.cpp:3064
cs_field_t * cs_field_create(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Create a field descriptor.
Definition cs_field.cpp:1639
int cs_field_n_fields(void)
Definition cs_field.cpp:1619
void cs_field_log_defs(void)
Print info relative to all field definitions to log file.
Definition cs_field.cpp:3933
const char * cs_field_get_label(const cs_field_t *f)
Return a label associated with a field.
Definition cs_field.cpp:4601
bool cs_field_is_key_locked(const cs_field_t *f, int key_id)
Query if a given key has been locked for a field.
Definition cs_field.cpp:3173
void cs_field_allocate_values(cs_field_t *f)
Allocate arrays for field values.
Definition cs_field.cpp:1854
void cs_field_bc_coeffs_shallow_copy(const cs_field_bc_coeffs_t *ref, cs_field_bc_coeffs_t *copy)
Shallow copy of boundary condition coefficients.
Definition cs_field.cpp:1541
int cs_field_set_key_str(cs_field_t *f, int key_id, const char *str)
Assign a character string for a given key to a field.
Definition cs_field.cpp:3548
int cs_field_set_key_struct(cs_field_t *f, int key_id, void *s)
Assign a simple structure for a given key to a field.
Definition cs_field.cpp:3669
cs_field_error_type_t
Definition cs_field.h:89
@ CS_FIELD_INVALID_KEY_NAME
Definition cs_field.h:92
@ CS_FIELD_INVALID_FIELD
Definition cs_field.h:96
@ CS_FIELD_INVALID_TYPE
Definition cs_field.h:95
@ CS_FIELD_INVALID_CATEGORY
Definition cs_field.h:94
@ CS_FIELD_LOCKED
Definition cs_field.h:97
@ CS_FIELD_OK
Definition cs_field.h:91
@ CS_FIELD_INVALID_KEY_ID
Definition cs_field.h:93
const char * cs_field_get_key_str(const cs_field_t *f, int key_id)
Return a string for a given key associated with a field.
Definition cs_field.cpp:3600
bool cs_field_is_key_set(const cs_field_t *f, int key_id)
Query if a given key has been set for a field.
Definition cs_field.cpp:3142
Return a pointer to a field based on its name if present.
Definition cs_field.cpp:2538
int cs_field_set_key_int_bits(cs_field_t *f, int key_id, int mask)
Set integer bits matching a mask to 1 for a given key for a field.
Definition cs_field.cpp:3369
void cs_field_key_disable_setup_log(int key_id)
Disable logging setup values associated with a given key.
Definition cs_field.cpp:3120
int cs_field_define_sub_key(const char *name, int parent_id)
Define a sub key.
Definition cs_field.cpp:3038
void cs_field_allocate_or_map_all(void)
Allocate arrays for all defined fields based on their location.
Definition cs_field.cpp:2457
void cs_field_bc_coeffs_free_copy(const cs_field_bc_coeffs_t *ref, cs_field_bc_coeffs_t *copy)
Free copy of boundary condition coefficients.
Definition cs_field.cpp:1570
void cs_field_destroy_all(void)
Destroy all defined fields.
Definition cs_field.cpp:2389
void cs_field_map_values(cs_field_t *f, cs_real_t *val, cs_real_t *val_pre)
Map existing value arrays to field descriptor.
Definition cs_field.cpp:1885
cs_field_t * cs_field_create_by_composite_name(const char *name_prefix, const char *name_suffix, int type_flag, int location_id, int dim, bool has_previous)
Definition cs_field.cpp:1676
const void * cs_field_get_key_struct(const cs_field_t *f, int key_id, void *s)
Return a structure for a given key associated with a field.
Definition cs_field.cpp:3721
void cs_field_log_info(const cs_field_t *f, int log_keywords)
Print info relative to a given field to log file.
Definition cs_field.cpp:4071
void cs_field_log_key_struct_t(const void *t)
Definition cs_field.h:205
void cs_field_log_key_defs(void)
Print info relative to all key definitions to log file.
Definition cs_field.cpp:4266
Definition cs_field.cpp:2488
double cs_field_get_key_double(const cs_field_t *f, int key_id)
Return a floating point value for a given key associated with a field.
Definition cs_field.cpp:3478
const char * cs_glob_field_comp_name_9[]
const char * cs_glob_field_comp_name_6[]
int cs_field_define_key_struct(const char *name, const void *default_value, cs_field_log_key_struct_t *log_func, cs_field_log_key_struct_t *log_func_default, cs_field_clear_key_struct_t *clear_func, size_t size, int type_flag)
Define a key for a structure value by its name and return an associated id.
Definition cs_field.cpp:2985
Definition cs_field.cpp:2804
int cs_field_define_key_double(const char *name, double default_value, int type_flag)
Define a key for an floating point value by its name and return an associated id.
Definition cs_field.cpp:2896
void cs_field_define_keys_base(void)
Define base keys.
Definition cs_field.cpp:4575
void cs_field_clear_key_struct_t(void *t)
Definition cs_field.h:215
int cs_field_key_id_try(const char *name)
Return an id associated with a given key name if present.
Definition cs_field.cpp:2831
cs_field_t * cs_field_find_or_create(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Return a field matching a given name and attributes, creating it if necessary.
Definition cs_field.cpp:1733
void cs_field_log_fields(int log_keywords)
Print info relative to all defined fields to log file.
Definition cs_field.cpp:4205
void cs_field_current_to_previous(cs_field_t *f)
Copy current field values to previous values if applicable.
Definition cs_field.cpp:2348
void cs_field_log_all_key_vals(bool log_defaults)
Print info relative to all given field keys to log file.
Definition cs_field.cpp:4544
int cs_field_lock_key(cs_field_t *f, int key_id)
Lock a field relative to a given key.
Definition cs_field.cpp:3205
cs_field_t * cs_field_by_composite_name_try(const char *name_prefix, const char *name_suffix)
Return a pointer to a field based on a composite name if present.
Definition cs_field.cpp:2593
void cs_field_allocate_bc_coeffs(cs_field_t *f, bool have_flux_bc, bool have_mom_bc, bool have_conv_bc, bool have_exch_bc)
Allocate boundary condition coefficients arrays.
Definition cs_field.cpp:1938
void cs_field_component_id_by_name(const char *name, int *f_id, int *c_id)
Return the id of a defined field and an associated component based on a component name.
Definition cs_field.cpp:2715
int cs_field_set_key_double(cs_field_t *f, int key_id, double value)
Assign a floating point value for a given key to a field.
Definition cs_field.cpp:3430
int cs_field_id_by_name(const char *name)
Return the id of a defined field based on its name.
Definition cs_field.cpp:2694
const char * cs_glob_field_comp_name_3[]
void cs_field_allocate_gradient(cs_field_t *f)
Allocate arrays for field gradient.
Definition cs_field.cpp:2297
void cs_field_log_key_vals(int key_id, bool log_defaults)
Print info relative to a given field key to log file.
Definition cs_field.cpp:4420
@ t
Definition cs_field_pointer.h:94
Definition cs_field.h:104
cs_real_t * val_f_lim
Definition cs_field.h:109
cs_real_t * val_f_d_lim
Definition cs_field.h:113
cs_real_t * val_f_d
Definition cs_field.h:112
cs_real_t * val_ip
Definition cs_field.h:106
cs_real_t * val_f
Definition cs_field.h:108
Field boundary condition descriptor (for variables)
Definition cs_field.h:121
cs_real_t * b
Definition cs_field.h:131
cs_real_t * rcodcl3
Definition cs_field.h:128
int * icodcl
Definition cs_field.h:125
cs_real_t * a
Definition cs_field.h:130
Definition cs_field.h:144
cs_real_t * rcodcl1
Definition cs_field.h:126
Definition cs_field.h:148
cs_real_t * bf
Definition cs_field.h:133
cs_real_t * hint
Definition cs_field.h:139
cs_real_t * ad
Definition cs_field.h:134
cs_real_t * bc
Definition cs_field.h:137
cs_real_t * val_f_d
Definition cs_field.h:147
int location_id
Definition cs_field.h:123
cs_real_t * bd
Definition cs_field.h:135
cs_real_t * val_f_pre
Definition cs_field.h:151
cs_real_t * ac
Definition cs_field.h:136
cs_real_t * af
Definition cs_field.h:132
cs_real_t * val_f
Definition cs_field.h:143
cs_real_t * rcodcl2
Definition cs_field.h:127
cs_real_t * _hext
Definition cs_field.h:140
Definition cs_field.h:158
cs_real_t * grad
Definition cs_field.h:186
int dim
Definition cs_field.h:165
int id
Definition cs_field.h:162
bool is_owner
Definition cs_field.h:193
Definition cs_field.h:190
int location_id
Definition cs_field.h:167
const char * name
Definition cs_field.h:160
int type
Definition cs_field.h:163
cs_real_t * val
Definition cs_field.h:179
int n_time_vals
Definition cs_field.h:169
cs_real_t * val_pre
Definition cs_field.h:182
cs_real_t ** vals
Definition cs_field.h:171
