#include "base/cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_field.h"#include "base/cs_mem.h"#include "base/cs_field_pointer.h"Functions | |
| void | cs_field_pointer_ensure_init (void) |
| Ensure field pointer array is initialized. | |
| void | cs_field_pointer_destroy_all (void) |
| Free all field pointer data. | |
| void | cs_field_pointer_map (cs_field_pointer_id_t e, cs_field_t *f) |
| Map a simple field to an enumerated pointer. | |
| void | cs_field_pointer_map_indexed (cs_field_pointer_id_t e, int index, cs_field_t *f) |
| Map a field to an (enumerated pointer, index) couple. | |
| void | cs_field_pointer_map_base (void) |
| Map base fields to enumerated pointers. | |
| void | cs_field_pointer_map_boundary (void) |
| Map some boundary fields to enumerated pointers. | |
| void | cs_field_pointer_map_atmospheric (int n_chem_species, const int species_f_id[]) |
| Map base fields to enumerated pointers for atmospheric models. | |
| struct cs_field_pointer_array_t * | cs_glob_field_pointers = nullptr |
Field pointers and ids for standard and model fields.
| void cs_field_pointer_destroy_all | ( | void | ) |
| void cs_field_pointer_ensure_init | ( | void | ) |
| void cs_field_pointer_map | ( | cs_field_pointer_id_t | e, |
| cs_field_t * | f ) |
The associated field pointer may then be retreived using CS_F_(e).
| [in] | e | field enumerator value |
| [in] | f | pointer to field structure |
| void cs_field_pointer_map_atmospheric | ( | int | n_chem_species, |
| const int | species_f_id[] ) |
| [in] | n_chem_species | number of chemical species |
| [in] | species_f_id | field id for each chemical species |
| void cs_field_pointer_map_base | ( | void | ) |
| void cs_field_pointer_map_boundary | ( | void | ) |
| void cs_field_pointer_map_indexed | ( | cs_field_pointer_id_t | e, |
| int | index, | ||
This sort of mapping may be used for sets of fields whose size is not known in advance.
The associated field pointer may then be retreived using CS_FI_(e, i).
| [in] | index | field enumerator index |
| struct cs_field_pointer_array_t* cs_glob_field_pointers = nullptr |
