bft_error.h
1#ifndef __BFT_ERROR_H__
2#define __BFT_ERROR_H__
5 * Base error handling
30#include "base/cs_defs.h"
32/*----------------------------------------------------------------------------*/
35 * Standard C library headers
38#include <stdarg.h>
40/*----------------------------------------------------------------------------
41 * Local headers
42 *----------------------------------------------------------------------------*/
44/*-----------------------------------------------------------------------------*/
45
49 * Public types
51
52typedef void (bft_error_handler_t) (const char *const file_name,
53 const int line_num,
54 const int sys_error_code,
55 const char *const format,
56 va_list arg_ptr);
57
58/*============================================================================
59 * Public function prototypes
60 *============================================================================*/
61
62/*
63 * Calls the error handler (set by bft_error_handler_set() or default).
64 *
65 * With the default error handler, bft_print_flush() is called, an error
66 * message is output to stderr, and the current process exits with an
67 * EXIT_FAILURE code.
68 *
69 * parameters:
70 * file_name: <-- name of source file from which error handler called.
71 * line_num: <-- line of source file from which error handler called.
72 * sys_error_code: <-- error code if error in system or libc call, 0 otherwise.
73 * format: <-- format string, as printf() and family.
74 * ... : <-- variable arguments based on format string.
75 */
76
77#if defined(__GNUC__)
78
79void
80bft_error(const char *const file_name,
81 const int line_num,
82 const int sys_error_code,
83 const char *const format,
84 ...)
85 __attribute__((format(printf, 4, 5)));
86
87#else
88
89void
90bft_error(const char *const file_name,
91 const int line_num,
92 const int sys_error_code,
93 const char *const format,
94 ...);
95
96#endif
97
98/*
99 * Returns the error handler associated with the bft_error() function.
100 *
101 * returns:
102 * pointer to the error handler function.
103 */
104
107
108/*
109 * Associates an error handler with the bft_error() function.
110 *
111 * parameters:
112 * handler: <-- pointer to the error handler function.
113 */
114
115void
117
118/*----------------------------------------------------------------------------*/
119
121
122#endif /* __BFT_ERROR_H__ */
bft_error_handler_t * bft_error_handler_get(void)
Definition bft_error.cpp:215
void bft_error_handler_t(const char *const file_name, const int line_num, const int sys_error_code, const char *const format, va_list arg_ptr)
Function pointer to opaque error handler.
Definition bft_error.h:52
Definition bft_error.cpp:193
void bft_error_handler_set(bft_error_handler_t *const handler)
Definition bft_error.cpp:227
Definition cs_defs.h:542
Definition cs_defs.h:543
