| static const char * | cs_base_strtf (bool boolean) |
| | Return a string "true" or "false" according to the boolean.
| char * | cs_base_get_app_name (int argc, const char *argv[]) |
| void | cs_base_logfile_head (int argc, char *argv[]) |
| void | cs_exit (int status) |
| void | cs_base_error_init (bool signal_defaults) |
| void | cs_base_mem_init (void) |
| void | cs_base_mem_finalize (void) |
| void | cs_base_signal_restore (void) |
| void | cs_base_time_summary (void) |
| void | cs_base_update_status (const char *format,...) |
| | Update status file.
| void | cs_base_trace_set (bool trace) |
| void | cs_base_bft_printf_init (const char *log_name, bool rn_log_flag) |
| void | cs_base_bft_printf_set (const char *log_name, bool rn_log_flag) |
| const char * | cs_base_bft_printf_name (void) |
| bool | cs_base_bft_printf_suppressed (void) |
| void | cs_base_warn (const char *file_name, int line_num) |
| void | cs_base_atexit_set (cs_base_atexit_t *const fct) |
| void | cs_base_sigint_handler_set (cs_base_sigint_handler_t *const h) |
| void | cs_base_option_string_clean (char *s) |
| const char * | cs_base_get_localedir (void) |
| const char * | cs_base_get_pkgdatadir (void) |
| const char * | cs_base_get_pkglibdir (void) |
| void | cs_base_check_bool (bool *b) |
| FILE * | cs_base_open_properties_data_file (const char *base_name) |
| void | cs_base_backtrace_dump (FILE *f, int lv_start) |
| | Dump a stack trace to a file.
| void | cs_base_at_finalize (cs_base_atexit_t *func) |
| | Register a function to be called at the finalization stage.
| void | cs_base_finalize_sequence (void) |
| | Call sequence of finalization functions.
| void | cs_base_get_run_identity (char **run_id, char **case_name, char **study_name) |
| | Query run-time directory info, using working directory names.
◆ CS_APP_NAME
| #define CS_APP_NAME "code_saturne" |
◆ CS_APP_VERSION
| #define CS_APP_VERSION PACKAGE_VERSION /* PACKAGE_VERSION from autoconf */ |
◆ CS_BASE_STRING_LEN
| #define CS_BASE_STRING_LEN 80 |
◆ CS_MEM_ALIGN
◆ cs_base_atexit_t
| typedef void cs_base_atexit_t(void) |
◆ cs_base_sigint_handler_t
| typedef void cs_base_sigint_handler_t(int signum) |
◆ cs_base_at_finalize()
The finalization is done in the reverse (first in, last out) sequence relative to calls of cs_base_at_finalize.
- Parameters
| [in] | func | finalization function to call. |
◆ cs_base_atexit_set()
◆ cs_base_backtrace_dump()
| void cs_base_backtrace_dump |
FILE * | f, |
int | lv_start ) |
- Parameters
| [in] | f | pointer to file in which to dump trace |
| [in] | lv_start | start level in stack trace |
◆ cs_base_bft_printf_init()
| void cs_base_bft_printf_init |
const char * | log_name, |
bool | rn_log_flag ) |
◆ cs_base_bft_printf_name()
| const char * cs_base_bft_printf_name |
void | | ) |
◆ cs_base_bft_printf_set()
| void cs_base_bft_printf_set |
◆ cs_base_bft_printf_suppressed()
| bool cs_base_bft_printf_suppressed |
void | | ) |
◆ cs_base_check_bool()
| void cs_base_check_bool |
bool * | b | ) |
◆ cs_base_error_init()
| void cs_base_error_init |
bool | signal_defaults | ) |
◆ cs_base_finalize_sequence()
| void cs_base_finalize_sequence |
void | | ) |
◆ cs_base_get_app_name()
| char * cs_base_get_app_name |
int | argc, |
const char * | argv[] ) |
◆ cs_base_get_localedir()
| const char * cs_base_get_localedir |
void | | ) |
◆ cs_base_get_pkgdatadir()
| const char * cs_base_get_pkgdatadir |
void | | ) |
◆ cs_base_get_pkglibdir()
| const char * cs_base_get_pkglibdir |
void | | ) |
◆ cs_base_get_run_identity()
| void cs_base_get_run_identity |
char ** | run_id, |
char ** | case_name, |
char ** | study_name ) |
Returned names are allocated if non-null, so should be deallocated by the caller when no longer needed.
Names are extracted from the working directory structure, which is expected to be of the form: <prefix>/study_name/case_name/RESU/run_id
or, in the case of a coupled run: <prefix>/study_name/RESU_COUPLING/run_id/case_name
If some names cannot be queried, nullptr is returned.
- Parameters
| [out] | run_id | run_id, or nullptr |
| [out] | case_name | case name, or nullptr |
| [out] | study_name | study name, or nullptr |
◆ cs_base_logfile_head()
| void cs_base_logfile_head |
int | argc, |
char * | argv[] ) |
◆ cs_base_mem_finalize()
| void cs_base_mem_finalize |
void | | ) |
◆ cs_base_mem_init()
| void cs_base_mem_init |
void | | ) |
◆ cs_base_open_properties_data_file()
| FILE * cs_base_open_properties_data_file |
const char * | base_name | ) |
◆ cs_base_option_string_clean()
| void cs_base_option_string_clean |
char * | s | ) |
◆ cs_base_sigint_handler_set()
◆ cs_base_signal_restore()
| void cs_base_signal_restore |
void | | ) |
◆ cs_base_strtf()
| const char * cs_base_strtf |
bool | boolean | ) |
inlinestatic |
- Parameters
- Returns
- a string "true" or "false"
◆ cs_base_time_summary()
| void cs_base_time_summary |
void | | ) |
◆ cs_base_trace_set()
| void cs_base_trace_set |
bool | trace | ) |
◆ cs_base_update_status()
| void cs_base_update_status |
const char * | format, |
Update status file.
If the format string is null, the file is removed.
- Parameters
| [in] | format | format string, or nullptr |
| [in] | ... | format arguments |
◆ cs_base_warn()
| void cs_base_warn |
const char * | file_name, |
int | line_num ) |
◆ cs_exit()
| void cs_exit |
int | status | ) |
