1#ifndef __CS_LOG_ITERATION_H__
2#define __CS_LOG_ITERATION_H__
137 const char *category,
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
void cs_log_iteration_set_active(void)
Activate or deactivate default log for current iteration.
Definition cs_log_iteration.cpp:1932
void cs_log_iteration_set_interval(int n)
Set interval for "per time step" logging information.
Definition cs_log_iteration.cpp:1914
void cs_log_iteration(void)
Log field and other array statistics for the current time step.
Definition cs_log_iteration.cpp:1686
void cs_log_iteration_destroy_all(void)
Free arrays possible used by logging of array statistics.
Definition cs_log_iteration.cpp:1646
void cs_log_iteration_prepare(void)
Initialize structures used for logging for new iteration.
Definition cs_log_iteration.cpp:2166
void cs_log_equation_convergence_info_write(void)
Default function for equation convergence log info.
Definition cs_log_iteration.cpp:1714
void cs_log_iteration_set_automatic(int n)
Set adaptive interval for "per time step" logging information.
Definition cs_log_iteration.cpp:1892
void cs_log_iteration_clipping_field(int f_id, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[], cs_lnum_t n_clip_min_comp[], cs_lnum_t n_clip_max_comp[])
Add or update clipping info for a field.
Definition cs_log_iteration.cpp:2144
void cs_log_iteration_clipping(const char *name, int dim, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[])
Add or update clipping info for a given array.
Definition cs_log_iteration.cpp:2110
void cs_log_iteration_add_array(const char *name, const char *category, const cs_mesh_location_type_t loc_id, bool is_intensive, int dim, const cs_real_t val[])
Add or update array not saved as permanent field to iteration log.
Definition cs_log_iteration.cpp:1955
void cs_log_iteration_l2residual(void)
Log L2 time residual for variable fields.
Definition cs_log_iteration.cpp:2189
void cs_log_iteration_log_setup(void)
Print default log per iteration options to setup.log.
Definition cs_log_iteration.cpp:2266
Definition cs_mesh_location.h:60
