void | cs_log_iteration_destroy_all (void) |
| Free arrays possible used by logging of array statistics.
void | cs_log_iteration (void) |
| Log field and other array statistics for the current time step.
void | cs_log_equation_convergence_info_write (void) |
| Default function for equation convergence log info.
void | cs_log_iteration_set_automatic (int n) |
| Set adaptive interval for "per time step" logging information.
void | cs_log_iteration_set_interval (int n) |
| Set interval for "per time step" logging information.
void | cs_log_iteration_set_active (void) |
| Activate or deactivate default log for current iteration.
void | cs_log_iteration_add_array (const char *name, const char *category, const cs_mesh_location_type_t loc_id, bool is_intensive, int dim, const cs_real_t val[]) |
| Add or update array not saved as permanent field to iteration log.
void | cs_log_iteration_clipping (const char *name, int dim, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[]) |
| Add or update clipping info for a given array.
void | cs_log_iteration_clipping_field (int f_id, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[], cs_lnum_t n_clip_min_comp[], cs_lnum_t n_clip_max_comp[]) |
| Add or update clipping info for a field.
void | cs_log_iteration_prepare (void) |
| Initialize structures used for logging for new iteration.
void | cs_log_iteration_l2residual (void) |
| Log L2 time residual for variable fields.
void | cs_log_iteration_log_setup (void) |
| Print default log per iteration options to setup.log.
◆ cs_log_equation_convergence_info_write()
void cs_log_equation_convergence_info_write |
void | | ) |
◆ cs_log_iteration()
void cs_log_iteration |
void | | ) |
◆ cs_log_iteration_add_array()
- Parameters
[in] | name | array name |
[in] | category | category name |
[in] | loc_id | associated mesh location id |
[in] | is_intensive | are the matching values intensive ? |
[in] | dim | associated dimension (interleaved) |
[in] | val | associated values |
◆ cs_log_iteration_clipping()
- Parameters
[in] | name | field or array name |
[in] | dim | associated dimension |
[in] | n_clip_min | number of local clippings to minimum value |
[in] | n_clip_max | number of local clippings to maximum value |
[in] | min_pre_clip | minimum values prior to clipping |
[in] | max_pre_clip | maximum values prior to clipping |
◆ cs_log_iteration_clipping_field()
- Parameters
[in] | f_id | associated field id |
[in] | n_clip_min_comp | number of clip min by component |
[in] | n_clip_max_comp | number of clip max by component |
◆ cs_log_iteration_destroy_all()
void cs_log_iteration_destroy_all |
void | | ) |
◆ cs_log_iteration_l2residual()
void cs_log_iteration_l2residual |
void | | ) |
◆ cs_log_iteration_log_setup()
void cs_log_iteration_log_setup |
void | | ) |
◆ cs_log_iteration_prepare()
void cs_log_iteration_prepare |
void | | ) |
◆ cs_log_iteration_set_active()
void cs_log_iteration_set_active |
void | | ) |
◆ cs_log_iteration_set_automatic()
void cs_log_iteration_set_automatic |
int | n | ) |
Logging will also occur:
- Each time step for the first n absolute or restarted time steps.
- Every 5 time steps between n and 5.n time steps.
- Every 10 time steps between 5.n and 10.n time steps.
- Every 50 time steps between 10.n and 50.n time steps.
- Every 100 time steps between 50.n and 100.n time steps.
- At the last time step
- Parameters
[in] | n | base interval for output. |
◆ cs_log_iteration_set_interval()
void cs_log_iteration_set_interval |
int | n | ) |
Logging will also occur for the 10 first time steps, as well as the last one.
- Parameters
[in] | n | interval between 2 output time steps. |
