cs_mesh_location.h
1#ifndef __CS_MESH_LOCATION_H__
2#define __CS_MESH_LOCATION_H__
5 * Mesh locations management.
9 This file is part of the code_saturne Kernel, element of the
10 code_saturne CFD tool.
11
12 Copyright (C) 1998-2025 EDF S.A., France
13
14 contact: saturne-support@edf.fr
15
16 The code_saturne Kernel is free software; you can redistribute it
17 and/or modify it under the terms of the GNU General Public License
18 as published by the Free Software Foundation; either version 2 of
19 the License, or (at your option) any later version.
20
21 The code_saturne Kernel is distributed in the hope that it will be
22 useful, but WITHOUT ANY WARRANTY; without even the implied warranty
23 of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
24 GNU General Public License for more details.
25
26 You should have received a copy of the GNU General Public License
27 along with the code_saturne Kernel; if not, write to the
28 Free Software Foundation, Inc.,
29 51 Franklin St, Fifth Floor,
30 Boston, MA 02110-1301 USA
31*/
32
33/*----------------------------------------------------------------------------*/
34
35#if defined(HAVE_MPI)
36#include <mpi.h>
37#endif
38
39/*----------------------------------------------------------------------------
40 * Local headers
41 *----------------------------------------------------------------------------*/
43#include "base/cs_defs.h"
44#include "mesh/cs_mesh.h"
45
46/*----------------------------------------------------------------------------*/
49
50/*=============================================================================
51 * Macro definitions
53
54/*============================================================================
55 * Type definitions
57
58/* Mesh location types */
59
73
74/* Mesh location construction method type */
75
84
85/* Opaque mesh location object */
86
87typedef struct _cs_mesh_location_t cs_mesh_location_t;
88
89/*----------------------------------------------------------------------------
90 * Function pointer to mesh location elements selection definition.
91 *
92 * If non-empty and not containing all elements, a list of elements
93 * of the parent mesh belonging to the location should be allocated
94 * (using CS_MALLOC) and defined by this function when called.
95 * This list's lifecycle is then managed by the mesh location object.
96 *
97 * Note: if the input pointer is non-null, it must point to valid data
98 * when the selection function is called, so that value or structure should
99 * not be temporary (i.e. local);
100 *
101 * parameters:
102 * input <-- pointer to optional (untyped) value or structure.
103 * m <-- pointer to associated mesh structure.
104 * location_id <-- id of associated location.
105 * n_elts --> number of selected elements
106 * elt_ids --> list of selected elements (0 to n-1 numbering).
107 *----------------------------------------------------------------------------*/
108
109typedef void
110(cs_mesh_location_select_t) (void *input,
111 const cs_mesh_t *m,
112 int location_id,
113 cs_lnum_t *n_elts,
114 cs_lnum_t **elt_ids);
115
116/*=============================================================================
117 * Global variables
118 *============================================================================*/
119
120/* Names associated with location types */
121
122extern const char *cs_mesh_location_type_name[];
123
124/*=============================================================================
125 * Public function prototypes
126 *============================================================================*/
127
128/*----------------------------------------------------------------------------
129 * Return number of mesh locations defined.
130 *----------------------------------------------------------------------------*/
131
132int
134
135/*----------------------------------------------------------------------------
136 * Initialize mesh location API.
137 *
138 * By default, 7 mesh locations are built, matching the 7 first values of
139 * the cs_mesh_location_type_t enum: CS_MESH_LOCATION_NONE for global
140 * values, CS_MESH_LOCATION_CELLS for the cells of the (default) global mesh,
141 * CS_MESH_LOCATION_INTERIOR_FACES and CS_MESH_LOCATION_BOUNDARY_FACES for
142 * its faces, and CS_MESH_LOCATION_VERTICES for its vertices.
143 * CS_MESH_LOCATION_FACES and a placeholder for CS_MESH_LOCATION_EDGES are
144 * also added for CDO discretizations.
145 *
146 * Locations should then be built once the global mesh is complete, and
147 * its halo structures completed.
148 *----------------------------------------------------------------------------*/
149
150void
152
153/*----------------------------------------------------------------------------
154 * Finalize mesh location API.
155 *----------------------------------------------------------------------------*/
156
157void
159
160/*----------------------------------------------------------------------------*/
168/*----------------------------------------------------------------------------*/
169
170int
171cs_mesh_location_get_id_by_name(const char *ref_name);
172
173/*----------------------------------------------------------------------------
174 * Associate mesh locations with a mesh.
175 *
176 * If mesh_id is negative, all defined mesh locations are associated
177 * (which is useful for the common case where only one mesh is present).
178 * If mesh_id is non-negative, only the location with the matching
179 * id is associated (which may be useful when multiple meshes are defined).
180 *
181 * The number of elements are computed based on the underlying mesh,
182 * and element lists are built for mesh subset locations.
183 *
184 * parameters:
185 * mesh <-- pointer to associated mesh structure
186 * id <-- id of mesh location
187 *----------------------------------------------------------------------------*/
188
189void
191 int id);
192
193/*----------------------------------------------------------------------------
194 * Define a new mesh location.
195 *
196 * So as to define a subset of mesh entities of a given type, an optional
197 * selection criteria may be given.
198 *
199 * parameters:
200 * name <-- name of location to define
201 * type <-- type of location to define
202 * criteria <-- selection criteria for associated elements, or NULL
203 *
204 * returns:
205 * id of newly created mesh location
206 *----------------------------------------------------------------------------*/
207
208int
209cs_mesh_location_add(const char *name,
211 const char *criteria);
212
213/*----------------------------------------------------------------------------*/
232/*----------------------------------------------------------------------------*/
233
234int
235cs_mesh_location_add_by_func(const char *name,
238 void *input);
239
240/*----------------------------------------------------------------------------*/
255/*----------------------------------------------------------------------------*/
256
257int
258cs_mesh_location_add_by_union(const char *name,
260 int n_ml_ids,
261 const int *ml_ids,
262 bool complement);
263
264/*----------------------------------------------------------------------------
265 * Get a mesh location's name.
266 *
267 * parameters:
268 * id <-- id of mesh location
269 *
270 * returns:
271 * pointer to mesh location name
272 *----------------------------------------------------------------------------*/
273
274const char *
276
277/*----------------------------------------------------------------------------
278 * Get a mesh location's type.
279 *
280 * parameters:
281 * id <-- id of mesh location
282 *
283 * returns:
284 * mesh location type
285 *----------------------------------------------------------------------------*/
286
289
290/*----------------------------------------------------------------------------
291 * Get a mesh location's number of elements.
292 *
293 * A pointer to a array of 3 values is returned:
294 * 0: local number of elements
295 * 1: with standard ghost elements (if applicable)
296 * 2: with extended ghost elements (if applicable)
297 *
298 * parameters:
299 * id <-- id of mesh location
300 *
301 * returns:
302 * array of numbers of elements.
303 *----------------------------------------------------------------------------*/
304
305const cs_lnum_t *
307
308/*----------------------------------------------------------------------------
309 * Get a mesh location's elements list, if present.
310 *
311 * A list of elements is defined if the location is a subset of a main
312 * location type.
313 *
314 * \deprecated Use \ref cs_mesh_location_get_elt_ids_try or
315 * \ref cs_mesh_location_get_elt_ids instead.
316 *
317 * parameters:
318 * id <-- id of mesh location
319 *
320 * returns:
321 * pointer to elements list (0 to n-1 numbering).
322 *----------------------------------------------------------------------------*/
323
324const cs_lnum_t *
326
327/*----------------------------------------------------------------------------*/
339/*----------------------------------------------------------------------------*/
340
341const cs_lnum_t *
343
344/*----------------------------------------------------------------------------*/
356/*----------------------------------------------------------------------------*/
357
358const cs_lnum_t *
360
361/*----------------------------------------------------------------------------*/
369/*----------------------------------------------------------------------------*/
370
373
374/*----------------------------------------------------------------------------*/
382/*----------------------------------------------------------------------------*/
383
384const char *
386
387/*----------------------------------------------------------------------------*/
395/*----------------------------------------------------------------------------*/
396
399
400/*----------------------------------------------------------------------------*/
408/*----------------------------------------------------------------------------*/
409
410int
412
413/*----------------------------------------------------------------------------*/
421/*----------------------------------------------------------------------------*/
422
423int *
425
426/*----------------------------------------------------------------------------*/
435/*----------------------------------------------------------------------------*/
436
437bool
439
440/*----------------------------------------------------------------------------*/
449/*----------------------------------------------------------------------------*/
450
451bool
453
454/*----------------------------------------------------------------------------*/
462/*----------------------------------------------------------------------------*/
463
464void
466 bool explicit_elt_ids);
467
468/*----------------------------------------------------------------------------*/
469
471
472#endif /* __CS_MESH_LOCATION_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
Definition cs_defs.h:335
int cs_mesh_location_get_n_sub_ids(int id)
Get a mesh location's number of sub ids.
Definition cs_mesh_location.cpp:984
const char * cs_mesh_location_type_name[]
void cs_mesh_location_build(cs_mesh_t *mesh, int id)
Definition cs_mesh_location.cpp:528
Definition cs_mesh_location.h:60
@ CS_MESH_LOCATION_CELLS
Definition cs_mesh_location.h:63
@ CS_MESH_LOCATION_EDGES
Definition cs_mesh_location.h:68
@ CS_MESH_LOCATION_PARTICLES
Definition cs_mesh_location.h:69
@ CS_MESH_LOCATION_OTHER
Definition cs_mesh_location.h:70
@ CS_MESH_LOCATION_INTERIOR_FACES
Definition cs_mesh_location.h:64
@ CS_MESH_LOCATION_VERTICES
Definition cs_mesh_location.h:66
@ CS_MESH_LOCATION_BOUNDARY_FACES
Definition cs_mesh_location.h:65
@ CS_MESH_LOCATION_FACES
Definition cs_mesh_location.h:67
@ CS_MESH_LOCATION_NONE
Definition cs_mesh_location.h:62
void cs_mesh_location_set_explicit_ids(int id, bool explicit_elt_ids)
Set behavior of cs_mesh_location_get_elt_ids for a given mesh location and locations based on it.
Definition cs_mesh_location.cpp:1060
int cs_mesh_location_add(const char *name, cs_mesh_location_type_t type, const char *criteria)
Definition cs_mesh_location.cpp:666
cs_mesh_location_def_t cs_mesh_location_get_definition_method(int id)
Get a mesh location's definition method.
Definition cs_mesh_location.cpp:920
int cs_mesh_location_get_id_by_name(const char *ref_name)
Find the related location id from the location name.
Definition cs_mesh_location.cpp:766
bool cs_mesh_location_is_complement(int id)
Check if a mesh location is built as a complement of other mesh locations.
Definition cs_mesh_location.cpp:1023
bool cs_mesh_location_get_explicit_ids(int id)
Check if cs_mesh_location_get_elt_ids always returns explicit element ids for a given mesh location.
Definition cs_mesh_location.cpp:1043
cs_mesh_location_select_t * cs_mesh_location_get_selection_function(int id)
Get a mesh location's selection function pointer.
Definition cs_mesh_location.cpp:966
int cs_mesh_location_add_by_func(const char *name, cs_mesh_location_type_t type, cs_mesh_location_select_t *func, void *input)
Define a new mesh location with an associated selection function.
Definition cs_mesh_location.cpp:703
const cs_lnum_t * cs_mesh_location_get_n_elts(int id)
Definition cs_mesh_location.cpp:823
const char * cs_mesh_location_get_name(int id)
Definition cs_mesh_location.cpp:782
const char * cs_mesh_location_get_selection_string(int id)
Get a mesh location's selection criteria string.
Definition cs_mesh_location.cpp:948
int cs_mesh_location_add_by_union(const char *name, cs_mesh_location_type_t type, int n_ml_ids, const int *ml_ids, bool complement)
Definition cs_mesh_location.cpp:735
int cs_mesh_location_n_locations(void)
Definition cs_mesh_location.cpp:435
const cs_lnum_t * cs_mesh_location_get_elt_ids(int id)
Get a mesh location's element ids.
Definition cs_mesh_location.cpp:891
Definition cs_mesh_location.h:76
@ CS_MESH_LOCATION_DEF_NONE
Definition cs_mesh_location.h:78
@ CS_MESH_LOCATION_DEF_SELECTION_FUNC
Definition cs_mesh_location.h:80
@ CS_MESH_LOCATION_DEF_UNION
Definition cs_mesh_location.h:81
@ CS_MESH_LOCATION_DEF_SELECTION_STR
Definition cs_mesh_location.h:79
void cs_mesh_location_initialize(void)
Definition cs_mesh_location.cpp:458
int * cs_mesh_location_get_sub_ids(int id)
Get a mesh location's list of sub ids.
Definition cs_mesh_location.cpp:1003
cs_mesh_location_type_t cs_mesh_location_get_type(int id)
Definition cs_mesh_location.cpp:800
void cs_mesh_location_finalize(void)
Definition cs_mesh_location.cpp:490
const cs_lnum_t * cs_mesh_location_get_elt_ids_try(int id)
Get a mesh location's element ids, if present.
Definition cs_mesh_location.cpp:869
Definition cs_mesh_location.h:87
void cs_mesh_location_select_t(void *input, const cs_mesh_t *m, int location_id, cs_lnum_t *n_elts, cs_lnum_t **elt_ids)
Definition cs_mesh_location.h:110
const cs_lnum_t * cs_mesh_location_get_elt_list(int id)
Definition cs_mesh_location.cpp:847
Definition mesh.f90:26
Definition cs_mesh.h:85
