#include "base/cs_base.h"Go to the source code of this file.
| typedef struct _cs_map_name_to_id_t | cs_map_name_to_id_t |
| cs_map_name_to_id_t * | cs_map_name_to_id_create (void) |
| void | cs_map_name_to_id_destroy (cs_map_name_to_id_t **m) |
| int | cs_map_name_to_id (cs_map_name_to_id_t *m, const char *key) |
| int | cs_map_name_to_id_try (const cs_map_name_to_id_t *m, const char *key) |
| const char * | cs_map_name_to_id_reverse (const cs_map_name_to_id_t *m, size_t id) |
| size_t | cs_map_name_to_id_size (const cs_map_name_to_id_t *m) |
| const char * | cs_map_name_to_id_key (const cs_map_name_to_id_t *m, size_t index) |
| typedef struct _cs_map_name_to_id_t cs_map_name_to_id_t |
| int cs_map_name_to_id | ( | cs_map_name_to_id_t * | m, |
| const char * | key ) |
| cs_map_name_to_id_t * cs_map_name_to_id_create | ( | void | ) |
| void cs_map_name_to_id_destroy | ( | cs_map_name_to_id_t ** | m | ) |
| const char * cs_map_name_to_id_key | ( | const cs_map_name_to_id_t * | m, |
| size_t | index ) |
| const char * cs_map_name_to_id_reverse | ( | const cs_map_name_to_id_t * | m, |
| size_t | id ) |
| size_t cs_map_name_to_id_size | ( | const cs_map_name_to_id_t * | m | ) |
| int cs_map_name_to_id_try | ( | const cs_map_name_to_id_t * | m, |
