1#ifndef __CS_MEDCOUPLING_REMAPPER_HXX__
2#define __CS_MEDCOUPLING_REMAPPER_HXX__
96 const char *select_criteria,
97 const char *medfile_path,
99 const char **field_names,
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
@ t
Definition cs_field_pointer.h:94
void cs_medcoupling_remapper_update_time_value(cs_medcoupling_remapper_t *r, int id)
Load the time value corresponding to id.
Definition cs_medcoupling_remapper.cxx:1066
cs_real_t * cs_medcoupling_remapper_copy_values(cs_medcoupling_remapper_t *r, int field_id, double default_val)
Interpolate values for a given field.
Definition cs_medcoupling_remapper.cxx:864
void cs_medcoupling_remapper_find_time_index(cs_medcoupling_remapper_t *r, cs_real_t t, int *id1, int *id2)
Retrieve the two closest time steps indexes.
Definition cs_medcoupling_remapper.cxx:953
struct _cs_medcoupling_remapper_t cs_medcoupling_remapper_t
Definition cs_medcoupling_remapper.h:44
void cs_medcoupling_remapper_destroy_all(void)
Destroy all remappers.
Definition cs_medcoupling_remapper.cxx:1049
int cs_medcoupling_remapper_initialize(const char *name, int elt_dim, const char *select_criteria, const char *medfile_path, int n_fields, const char **field_names, int iteration, int order)
initialize a remapper based on a set of given arguments
Definition cs_medcoupling_remapper.cxx:687
void cs_medcoupling_remapper_rotate(cs_medcoupling_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
Rotate the mesh using a center point, axis and angle.
Definition cs_medcoupling_remapper.cxx:921
void cs_medcoupling_remapper_get_time_from_index(cs_medcoupling_remapper_t *r, int id, cs_real_t *t)
Definition cs_medcoupling_remapper.cxx:998
void cs_medcoupling_remapper_set_options(cs_medcoupling_remapper_t *r, const char key[], const char value[])
set non-default options for a remapper
Definition cs_medcoupling_remapper.cxx:762
cs_medcoupling_remapper_t * cs_medcoupling_remapper_by_id(int r_id)
get a remapper by its id
Definition cs_medcoupling_remapper.cxx:621
void cs_medcoupling_remapper_translate(cs_medcoupling_remapper_t *r, cs_real_t translation[3])
translate the mesh using a given vector
Definition cs_medcoupling_remapper.cxx:895
void cs_medcoupling_remapper_set_iteration(cs_medcoupling_remapper_t *r, int iteration, int order)
set and load a given time iteration from the MED file
Definition cs_medcoupling_remapper.cxx:727
void cs_medcoupling_remapper_get_iter_order_from_index(cs_medcoupling_remapper_t *r, int id, int *it, int *order)
Definition cs_medcoupling_remapper.cxx:1027
cs_medcoupling_remapper_t * cs_medcoupling_remapper_by_name_try(const char *name)
get a remapper by its name
Definition cs_medcoupling_remapper.cxx:648
void cs_medcoupling_remapper_setup(cs_medcoupling_remapper_t *r)
update the interpolation matrix of the remapper
Definition cs_medcoupling_remapper.cxx:824
