211 bool *auto_variables,
212 bool *auto_curve_coo,
295 const char **labels);
348 void *p_define_input);
401 const int *writer_ids);
528 const fvm_nodal_t *location_mesh);
543 const char *mesh_name);
558 const char *mesh_name);
645 int mesh_location_id);
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
const char * cs_probe_set_get_name(const cs_probe_set_t *pset)
Retrieve the name related to a cs_probe_set_t structure.
Definition cs_probe.cpp:846
cs_probe_set_t * cs_probe_set_get_by_id(int pset_id)
Retrieve a cs_probe_set_t structure from its id.
Definition cs_probe.cpp:826
void cs_probe_finalize(void)
Free all structures related to a set of probes.
cs_probe_set_t * cs_probe_set_create_from_segment(const char *name, int n_probes, const cs_real_t start_coords[3], const cs_real_t end_coords[3])
Define a new set of probes from the segment spanned by two points.
Definition cs_probe.cpp:1078
void cs_probe_set_get_post_info(const cs_probe_set_t *pset, bool *time_varying, bool *on_boundary, bool *on_curve, bool *auto_variables, bool *auto_curve_coo, bool *auto_cart_coo, int *n_writers, int *writer_ids[])
Retrieve information useful for the postprocessing step.
Definition cs_probe.cpp:874
cs_real_t * cs_probe_set_get_loc_curvilinear_abscissa(const cs_probe_set_t *pset)
Return the list of curvilinear abscissa of probes located on the local ranks for the given probe set.
Definition cs_probe.cpp:2208
void cs_probe_set_option(cs_probe_set_t *pset, const char *keyname, const char *keyval)
Set optional parameters related to the management of a set of probes.
Definition cs_probe.cpp:1444
cs_probe_set_t * cs_probe_set_create_from_array(const char *name, int n_probes, const cs_real_3_t *coords, const char **labels)
Define a new set of probes from an array of coordinates.
Definition cs_probe.cpp:1029
cs_probe_snap_t
Definition cs_probe.h:55
@ CS_PROBE_SNAP_NONE
Definition cs_probe.h:57
@ CS_PROBE_SNAP_VERTEX
Definition cs_probe.h:59
@ CS_PROBE_SNAP_ELT_CENTER
Definition cs_probe.h:58
void cs_probe_set_locate(cs_probe_set_t *pset, const fvm_nodal_t *location_mesh)
Try to locate each probe and define the coordinate really used for the postprocessing step.
Definition cs_probe.cpp:1538
fvm_nodal_t * cs_probe_set_export_mesh(cs_probe_set_t *pset, const char *mesh_name)
Define a fvm_nodal_t structure from the set of probes.
Definition cs_probe.cpp:1851
int cs_probe_get_n_sets(void)
Retrieve the number of probe sets defined.
Definition cs_probe.cpp:780
cs_probe_set_t * cs_probe_set_create(const char *name)
Create a new set of probes.
Definition cs_probe.cpp:957
int cs_probe_set_get_n_local(const cs_probe_set_t *pset)
Return the number probes in the local domain.
Definition cs_probe.cpp:2163
void cs_probe_set_define_local_t(void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s)
Function pointer to definition of probes based on rank-local points.
Definition cs_probe.h:89
void cs_probe_set_add_probe(cs_probe_set_t *pset, cs_real_t x, cs_real_t y, cs_real_t z, const char *label)
Add a new probe to an existing set of probes.
Definition cs_probe.cpp:981
const char * cs_probe_set_get_location_criteria(cs_probe_set_t *pset)
Return the location filter selection criteria string for a given probe set.
Definition cs_probe.cpp:918
const cs_lnum_t * cs_probe_set_get_elt_ids(const cs_probe_set_t *pset, int mesh_location_id)
Return the ids of a probe set's local matching elements, relative to a given mesh location.
Definition cs_probe.cpp:2237
struct _cs_probe_set_t cs_probe_set_t
Definition cs_probe.h:53
void cs_probe_set_transfer_associated_field_info(cs_probe_set_t *pset, int *n_fields, int **field_info)
Transfer info on associated fields to the caller.
int cs_probe_set_get_interpolation(cs_probe_set_t *pset)
Return the interpolation option for a given probe set.
Definition cs_probe.cpp:939
void cs_probe_set_assign_curvilinear_abscissa(cs_probe_set_t *pset, const cs_real_t *s)
Assign curvilinear abscissa for the given probe set.
Definition cs_probe.cpp:1224
void cs_probe_set_auto_curvilinear_coords(cs_probe_set_t *pset, bool mode)
Set automatic output of curvilinear coordinates.
Definition cs_probe.cpp:1360
void cs_probe_set_associate_field(cs_probe_set_t *pset, int writer_id, int field_id, int comp_id)
Associate a field to a probe set.
Definition cs_probe.cpp:1301
fvm_nodal_t * cs_probe_set_unlocated_export_mesh(cs_probe_set_t *pset, const char *mesh_name)
Define a fvm_nodal_t structure from the set of unlocated probes.
Definition cs_probe.cpp:2002
void cs_probe_set_get_members(const cs_probe_set_t *pset, cs_probe_snap_t *snap_mode, int *n_probes, cs_real_3_t *coords[])
Retrieve the main members of a cs_probe_set_t structure.
Definition cs_probe.cpp:2132
void cs_probe_set_snap_mode(cs_probe_set_t *pset, cs_probe_snap_t snap_mode)
Set snap mode related to the management of a set of probes.
Definition cs_probe.cpp:1408
cs_probe_set_t * cs_probe_set_get(const char *name)
Retrieve a cs_probe_set_t structure.
Definition cs_probe.cpp:796
void cs_probe_set_allow_overwrite(const char *name)
allow overwriting the definition of a given probe set.
Definition cs_probe.cpp:1194
const cs_real_t * cs_probe_set_get_curvilinear_abscissa(const cs_probe_set_t *pset)
Return the list of curvilinear abscissa for the given probe set.
Definition cs_probe.cpp:2184
void cs_probe_set_auto_var(cs_probe_set_t *pset, bool mode)
Set automatic output of variables behavior.
Definition cs_probe.cpp:1336
void cs_probe_set_auto_cartesian_coords(cs_probe_set_t *pset, bool mode)
Set automatic output of cartesian coordinates.
Definition cs_probe.cpp:1384
void cs_probe_set_dump(const cs_probe_set_t *pset)
Dump a cs_probe_set_t structure.
Definition cs_probe.cpp:2082
cs_probe_set_t * cs_probe_set_create_from_local(const char *name, cs_probe_set_define_local_t *p_define_func, void *p_define_input)
Define a new set of probes from rank-local definition function.
Definition cs_probe.cpp:1167
void cs_probe_set_associate_writers(cs_probe_set_t *pset, int n_writers, const int *writer_ids)
Associate a list of writers to a probe set.
Definition cs_probe.cpp:1264
char * label
Definition keywords.h:58
