#include "base/cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdlib.h>#include <stdarg.h>#include <string.h>#include <math.h>#include <float.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_array.h"#include "base/cs_ale.h"#include "atmo/cs_atmo_variables.h"#include "base/cs_boundary_conditions.h"#include "cfbl/cs_cf_model.h"#include "comb/cs_coal_physical_properties.h"#include "ctwr/cs_ctwr_physical_properties.h"#include "cdo/cs_domain.h"#include "elec/cs_elec_model.h"#include "cdo/cs_equation.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "base/cs_gas_mix.h"#include "gui/cs_gui.h"#include "base/cs_ht_convert.h"#include "turb/cs_les_mu_t.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parall.h"#include "base/cs_parameters.h"#include "base/cs_physical_constants.h"#include "pprt/cs_physical_model.h"#include "base/cs_prototypes.h"#include "base/cs_thermal_model.h"#include "turb/cs_turbulence_ml.h"#include "turb/cs_turbulence_model.h"#include "turb/cs_turbulence_ke.h"#include "turb/cs_turbulence_kw.h"#include "turb/cs_turbulence_rij.h"#include "turb/cs_turbulence_sa.h"#include "turb/cs_turbulence_v2f.h"#include "base/cs_velocity_pressure.h"#include "base/cs_vof.h"#include "base/cs_wall_condensation.h"#include "base/cs_wall_condensation_1d_thermal.h"#include "base/cs_1d_wall_thermal.h"#include "base/cs_physical_properties_default.h"Functions | |
| void | cs_physical_properties_update (int iterns) |
| Fills physical properties which are variable in time. | |
Compute physical properties which are variable in time.
| void cs_physical_properties_update | ( | int | iterns | ) |
| [in] | iterns | Navier-Stokes sub-iterations indicator:
