1#ifndef __CS_BOUNDARY_CONDITIONS_H__
2#define __CS_BOUNDARY_CONDITIONS_H__
63#define CS_MAX_BC_PM_ZONE_NUM 2000
66#define CS_MAX_BC_TYPE 200
146 const char *type_name);
215 ple_locator_t *locator,
251 int source_location_id,
void cs_boundary_conditions_create(void)
Create the legacy boundary conditions face type and face zone arrays.
Definition cs_boundary_conditions.cpp:2243
void * cs_boundary_conditions_get_model_inlet_try(const cs_zone_t *zone)
Return pointer to model inlet structure associated with a given boundary zone, if associated,...
Definition cs_boundary_conditions.cpp:2719
cs_time_control_t * cs_boundary_conditions_open_get_time_control(const cs_zone_t *zone)
Acess the time control structure of an open (inlet/outlet) boundary.
Definition cs_boundary_conditions.cpp:2826
void cs_boundary_conditions_open_turb(void)
void cs_boundary_conditions_open_set_volume_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant volume flow rate to an inlet or outlet.
Definition cs_boundary_conditions.cpp:3183
void cs_boundary_conditions_open_set_mass_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant mass flow rate to an inlet or outlet.
Definition cs_boundary_conditions.cpp:3019
void cs_boundary_conditions_open_set_velocity_by_normal_value(const cs_zone_t *z, cs_real_t u_norm)
Assign a constant velocity normal to an inlet.
Definition cs_boundary_conditions.cpp:2887
cs_boundary_condition_pm_info_t * cs_glob_bc_pm_info
const int * cs_glob_bc_type
cs_real_t cs_boundary_conditions_open_get_mass_flow_rate(const cs_zone_t *z)
Return the volume flow rate to an inlet or outlet.
Definition cs_boundary_conditions.cpp:2980
void cs_boundary_conditions_open_set_mass_flow_rate_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Assign a mass flow rate to an inlet or outlet based on provided function.
Definition cs_boundary_conditions.cpp:3113
void cs_boundary_conditions_mapped_set(const cs_field_t *f, ple_locator_t *locator, cs_mesh_location_type_t location_type, int normalize, int interpolate, cs_lnum_t n_faces, const cs_lnum_t *faces, cs_real_t *balance_w)
Set mapped boundary conditions for a given field and mapping locator.
Definition cs_boundary_conditions.cpp:1992
void cs_boundary_conditions_complete(int bc_type[])
Automatic adjustments for boundary condition codes.
Definition cs_boundary_conditions.cpp:2580
ple_locator_t * cs_boundary_conditions_map(cs_mesh_location_type_t location_type, cs_lnum_t n_location_elts, cs_lnum_t n_faces, const cs_lnum_t *location_elts, const cs_lnum_t *faces, cs_real_3_t *coord_shift, int coord_stride, double tolerance)
Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later inter...
Definition cs_boundary_conditions.cpp:1840
cs_real_t * cs_boundary_conditions_get_b_head_loss(bool alloc_if_null)
Return pointer to boundary head losses array.
Definition cs_boundary_conditions.cpp:2769
int cs_boundary_conditions_add_map(int bc_location_id, int source_location_id, cs_real_t coord_shift[3], double tolerance)
Add location of locate shifted boundary face coordinates on cells or boundary faces for automatic int...
Definition cs_boundary_conditions.cpp:2187
int * cs_boundary_conditions_get_bc_type(void)
Return pointer to boundary conditions BC type array.
Definition cs_boundary_conditions.cpp:2387
void cs_boundary_conditions_create_legacy_zone_data(void)
Create the legacy boundary conditions zone data arrays.
Definition cs_boundary_conditions.cpp:2220
void cs_boundary_conditions_open_set_velocity_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Assign a normal velocity to an inlet using a provided function.
Definition cs_boundary_conditions.cpp:2934
void cs_boundary_conditions_free(void)
Free the boundary conditions face type and face zone arrays.
Definition cs_boundary_conditions.cpp:2295
void cs_boundary_conditions_compute(int bc_type[])
Update per variable boundary condition codes.
Definition cs_boundary_conditions.cpp:2401
void * cs_boundary_conditions_get_model_inlet(const cs_zone_t *zone)
Return pointer to model inlet structure associated with a given open (inlet/outlet) boundary.
Definition cs_boundary_conditions.cpp:2691
void cs_boundary_conditions_error(const int *bc_type, const char *type_name)
Handling of boundary condition definition errors and associated output.
Definition cs_boundary_conditions.cpp:1786
int cs_boundary_conditions_get_legacy_zone_num(const cs_zone_t *z)
Definition cs_boundary_conditions.cpp:2744
void cs_boundary_conditions_inlet_set_turbulence_intensity(const cs_zone_t *zone, cs_real_t ti)
Base the inlet turbulence values on a a circular duct with smooth wall (see ref cs_turbulence_bc_ke_h...
Definition cs_boundary_conditions.cpp:3348
void cs_boundary_conditions_assign_model_inlet(const cs_zone_t *zone, void *s_ptr, void *s_del)
Assign pointer to model inlet structure associated with a given open (inlet/outlet) boundary.
Definition cs_boundary_conditions.cpp:2794
void cs_boundary_conditions_reset(void)
Prepare (reset) condition coefficients for all variable fields.
Definition cs_boundary_conditions.cpp:2337
void cs_boundary_conditions_inlet_set_turbulence_hyd_diam(const cs_zone_t *zone, cs_real_t hd)
Definition cs_boundary_conditions.cpp:3326
void cs_boundary_conditions_open_set_volume_flow_rate_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Assign a volume flow rate to an inlet or outlet based on provided function.
Definition cs_boundary_conditions.cpp:3267
void cs_boundary_conditions_open_set_velocity_by_value(const cs_zone_t *z, const cs_real_t u[3])
Assign a constant velocity to an open (inlet/outlet) boundary.
Definition cs_boundary_conditions.cpp:2848
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
void cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Function pointer for evaluation of local function values.
Definition cs_function.h:112
Definition cs_mesh_location.h:60
Definition cs_boundary_conditions.h:100
int * iautom
Definition cs_boundary_conditions.h:106
int * izfppp
Definition cs_boundary_conditions.h:103
Definition cs_field.h:158
Definition cs_time_control.h:96
