#include <stdarg.h>
| bool | cs_time_control_is_active (cs_time_control_t *tc, const cs_time_step_t *ts) |
| void | cs_time_control_init_by_time_step (cs_time_control_t *tc, int nt_start, int nt_end, int nt_interval, bool at_start, bool at_end) |
| void | cs_time_control_init_by_time (cs_time_control_t *tc, double t_start, double t_end, double t_interval, bool at_start, bool at_end) |
| void | cs_time_control_init_by_func (cs_time_control_t *tc, cs_time_control_func_t *control_func, void *control_input, bool at_start, bool at_end) |
| void | cs_time_control_get_description (const cs_time_control_t *tc, char *desc, size_t desc_size) |
| void | cs_time_control_copy (const cs_time_control_t *src, cs_time_control_t *dst) |
| | Copy contents of a cs_time_control to another instance.
| void | cs_time_control_copy_from_default (cs_time_control_t *tc) |
| | Copy contents of the default cs_time_control to another instance.
◆ cs_time_control_func_t
Function pointer to a time control function.
Each function of this sort may be used to determine whether a given set of operations (such as variable or property updates) should be done at the current time step.
- Parameters
| [in] | ts | current time step structure |
| [in] | input | pointer to optional (untyped) value or structure, or NULL. |
- Returns
- true if active at given time step, false otherwise
◆ cs_time_control_type_t
| Enumerator |
| CS_TIME_CONTROL_TIME_STEP | control based on time step
| CS_TIME_CONTROL_TIME | control based on simulated time
| CS_TIME_CONTROL_FUNCTION | control based on function
◆ cs_time_control_copy()
- Parameters
| [in] | src | Instance to copy data from |
| [out] | dst | Instance to copy data to |
◆ cs_time_control_copy_from_default()
- Parameters
| [out] | tc | Instance to copy data to |
◆ cs_time_control_get_description()
| void cs_time_control_get_description |
const cs_time_control_t * | tc, |
char * | desc, |
size_t | desc_size ) |
◆ cs_time_control_init_by_func()
◆ cs_time_control_init_by_time()
| void cs_time_control_init_by_time |
double | t_start, |
double | t_end, |
double | t_interval, |
bool | at_start, |
bool | at_end ) |
◆ cs_time_control_init_by_time_step()
| void cs_time_control_init_by_time_step |
int | nt_start, |
int | nt_end, |
int | nt_interval, |
bool | at_start, |
bool | at_end ) |
◆ cs_time_control_is_active()
