1#ifndef __CS_PARAMETERS_H__
2#define __CS_PARAMETERS_H__
250 int iscvr = 0, f_id = 0;
352 const char *variable_name);
Definition cs_defs.h:542
Definition cs_defs.h:543
Definition cs_field.cpp:3298
Definition cs_field.cpp:2488
Definition cs_field.cpp:2804
void cs_parameters_read_restart_info(void)
Read general restart info.
Definition cs_parameters.cpp:1187
void cs_parameters_create_added_properties(void)
Create previously added user properties.
Definition cs_parameters.cpp:1577
cs_equation_param_t cs_var_cal_opt_t
Definition cs_parameters.h:62
int cs_parameters_n_added_properties(void)
Return the number of defined user properties not added yet.
Definition cs_parameters.cpp:1337
void cs_parameters_output_complete(void)
Complete general output options definitions.
Definition cs_parameters.cpp:2785
void cs_parameters_define_auxiliary_fields(void)
Create properties definied directly in C.
Definition cs_parameters.cpp:1427
void cs_parameters_add_variable(const char *name, int dim)
Define a user variable.
Definition cs_parameters.cpp:1210
void cs_parameters_add_property(const char *name, int dim, int location_id)
Define a user property.
Definition cs_parameters.cpp:1288
cs_field_t * cs_parameters_add_boundary_temperature(void)
Define a boundary values field for temperature, if applicable.
Definition cs_parameters.cpp:1737
void cs_parameters_create_added_variables(void)
Create previously added user variables.
Definition cs_parameters.cpp:1349
void cs_space_disc_log_setup(void)
Print the space discretization structure to setup.log.
Definition cs_parameters.cpp:2951
cs_equation_param_t cs_parameters_equation_param_default(void)
Return a local equation param structure, with default options.
Definition cs_parameters.cpp:2865
@ CS_OUTLET
Definition cs_parameters.h:86
@ CS_COUPLED_FD
Definition cs_parameters.h:101
@ CS_EPHCF
Definition cs_parameters.h:96
@ CS_INLET
Definition cs_parameters.h:85
@ CS_COUPLED
Definition cs_parameters.h:100
@ CS_ESICF
Definition cs_parameters.h:92
@ CS_INDEF
Definition cs_parameters.h:84
@ CS_CONVECTIVE_INLET
Definition cs_parameters.h:105
@ CS_ROUGHWALL
Definition cs_parameters.h:90
@ CS_SOPCF
Definition cs_parameters.h:95
@ CS_SSPCF
Definition cs_parameters.h:94
@ CS_FREE_INLET
Definition cs_parameters.h:102
@ CS_EQHCF
Definition cs_parameters.h:98
@ CS_SMOOTHWALL
Definition cs_parameters.h:89
@ CS_SYMMETRY
Definition cs_parameters.h:87
@ CS_FREE_SURFACE
Definition cs_parameters.h:104
@ CS_DRIFT_SCALAR_ON
Definition cs_parameters.h:119
@ CS_DRIFT_SCALAR_THERMOPHORESIS
Definition cs_parameters.h:121
@ CS_DRIFT_SCALAR_IMPOSED_MASS_FLUX
Definition cs_parameters.h:125
@ CS_DRIFT_SCALAR_NO_MASS_AGGREGATION
Definition cs_parameters.h:128
@ CS_DRIFT_SCALAR_ADD_DRIFT_FLUX
Definition cs_parameters.h:120
@ CS_DRIFT_SCALAR_TURBOPHORESIS
Definition cs_parameters.h:122
@ CS_DRIFT_SCALAR_CENTRIFUGALFORCE
Definition cs_parameters.h:124
@ CS_DRIFT_SCALAR_ELECTROPHORESIS
Definition cs_parameters.h:123
@ CS_DRIFT_SCALAR_ZERO_BNDY_FLUX_AT_WALLS
Definition cs_parameters.h:127
Definition cs_parameters.h:126
void cs_parameters_set_init_state_on(int idx)
Set init state to 1. This is necessary for fortran mapping and should be changed in the future.
Definition cs_parameters.cpp:1011
void cs_parameters_add_variable_variance(const char *name, const char *variable_name)
Define a user variable which is a variance of another variable.
Definition cs_parameters.cpp:1251
int cs_parameters_n_added_variables(void)
Return the number of defined user variables not added yet.
Definition cs_parameters.cpp:1323
void cs_parameters_define_field_keys(void)
Define general field keys.
Definition cs_parameters.cpp:1029
static int cs_parameters_iscavr(cs_field_t *f)
For a given field, returns the scalar number of the fluctuating field if given field is a variance.
Definition cs_parameters.h:248
const cs_space_disc_t * cs_glob_space_disc
bool cs_parameters_need_extended_neighborhood(void)
Check if extended neighborhood is needed.
Definition cs_parameters.cpp:1823
const cs_time_scheme_t * cs_glob_time_scheme
void cs_parameters_global_complete(void)
Complete global parameters.
Definition cs_parameters.cpp:1875
void cs_time_scheme_log_setup(void)
Print the time scheme structure to setup.log.
Definition cs_parameters.cpp:2877
cs_time_scheme_t * cs_get_glob_time_scheme(void)
Provide access to cs_glob_time_scheme.
Definition cs_parameters.cpp:996
cs_space_disc_t * cs_get_glob_space_disc(void)
Provide access to cs_glob_space_disc.
Definition cs_parameters.cpp:980
cs_field_t * cs_parameters_add_boundary_values(cs_field_t *f)
Define a boundary values field for a variable field.
Definition cs_parameters.cpp:1627
void cs_parameters_eqp_complete(void)
Complete general equation parameter definitions.
Definition cs_parameters.cpp:2069
cs_restart_auxiliary_t * cs_glob_restart_auxiliary
cs_tree_node_t * cs_glob_tree
Definition cs_equation_param.h:193
Definition cs_field.h:158
Additional checkpoint/restart files.
Definition cs_parameters.h:199
int read_auxiliary
Definition cs_parameters.h:201
int write_auxiliary
Definition cs_parameters.h:202
Definition cs_parameters.h:68
int n_it
Definition cs_parameters.h:70
double rhs_norm
Definition cs_parameters.h:71
double res_norm
Definition cs_parameters.h:72
double derive
Definition cs_parameters.h:73
double l2residual
Definition cs_parameters.h:74
Space discretisation options descriptor.
Definition cs_parameters.h:136
int itbrrb
Definition cs_parameters.h:157
int imrgra
Definition cs_parameters.h:142
int imvisf
Definition cs_parameters.h:138
int iflxmw
Definition cs_parameters.h:152
Time scheme descriptor.
Definition cs_parameters.h:167
int time_order
Definition cs_parameters.h:169
double thetst
Definition cs_parameters.h:183
double thetvi
Definition cs_parameters.h:186
int isno2t
Definition cs_parameters.h:173
double thetsn
Definition cs_parameters.h:180
int istmpf
Definition cs_parameters.h:171
double thetcp
Definition cs_parameters.h:188
int isto2t
Definition cs_parameters.h:177
int iccvfg
Definition cs_parameters.h:190
