57#define CS_ARRAY_SUBSET_NULL -1
58#define CS_ARRAY_SUBSET_IN 0
59#define CS_ARRAY_SUBSET_OUT 1
60#define CS_ARRAY_SUBSET_INOUT 2
78#if defined(__cplusplus)
96template <
typename T,
size_t stride,
typename... Arrays>
103 T* array_ptrs[] = {arrays ... };
105#if defined (__NVCC__)
107 for (T* array : array_ptrs)
108 is_available_on_device = is_available_on_device
112 if (is_available_on_device) {
113 cudaStream_t stream_ = cs_cuda_get_stream(0);
123 for (T* array : array_ptrs)
124 memcpy(array + i_elt*stride, ref_val, stride*
sizeof(T));
128# pragma omp parallel for if (n_elts >= CS_THR_MIN)
150template <
typename T,
size_t stride,
typename... Arrays>
158 T* array_ptrs[] = {arrays ... };
160#if defined (__NVCC__)
161 bool is_available_on_device =
true;
162 for (T* array : array_ptrs)
163 is_available_on_device = is_available_on_device
167 if (is_available_on_device) {
168 cudaStream_t stream_ = cs_cuda_get_stream(0);
178 for (T* array : array_ptrs)
179 for (
size_t k = 0;
k < stride;
k++) {
180 array[i_elt*stride +
k] = ref_val;
185# pragma omp parallel for if (n_elts >= CS_THR_MIN)
208template <
typename T,
size_t stride,
typename... Arrays>
210cs_arrays_set_value_on_subset(
const cs_lnum_t n_elts,
222 T* array_ptrs[] = {arrays ... };
225 for (T* array : array_ptrs)
226 memcpy(array + i_elt*stride, ref_val, stride*
sizeof(T));
230# pragma omp parallel for if (n_elts >= CS_THR_MIN)
232 set_value(elt_ids[i]);
254template <
typename T,
size_t stride,
typename... Arrays>
256cs_arrays_set_value_on_subset(
269 T* array_ptrs[] = {arrays ... };
272 for (T* array : array_ptrs)
273 for (
size_t k = 0;
k < stride;
k++) {
274 array[i_elt*stride +
k] = ref_val;
279# pragma omp parallel for if (n_elts >= CS_THR_MIN)
281 set_value(elt_ids[i]);
304#if defined (__NVCC__)
308 if (is_available_on_device) {
309 cudaStream_t stream_ = cs_cuda_get_stream(0);
315# pragma omp parallel for if (size > CS_THR_MIN)
338cs_array_difference(
const cs_lnum_t size,
const T *x,
const T *y, T *diff)
342#pragma omp parallel for if (size > CS_THR_MIN)
void cs_array_real_fill_zero(cs_lnum_t size, cs_real_t a[])
Assign zero to all elements of an array.
Definition cs_array.cpp:1019
void cs_array_real_set_wvalue(cs_lnum_t n_elts, int stride, const cs_real_t ref_val[], const cs_real_t weight[], cs_real_t a[])
Assign a weighted constant value of dim "stride" to an interlaced array sharing the same stride....
Definition cs_array.cpp:602
void cs_array_real_set_scalar_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t ref_val, cs_real_t a[])
Assign a constant scalar value to an array on a selected subset of elements. If elt_ids is null,...
Definition cs_array.cpp:766
void cs_array_set_value_real(cs_lnum_t n_elts, cs_lnum_t dim, cs_real_t v, cs_real_t a[])
Assign a constant value to an array (deprecated function).
Definition cs_array.cpp:1045
void cs_array_bool_fill_false(cs_lnum_t size, bool a[])
Assign false to all elements of an array. Case of an array of booleans.
Definition cs_array.cpp:106
void cs_array_real_set_tensor(cs_lnum_t n_elts, const cs_real_t ref_tens[3][3], cs_real_t a[])
Assign a constant 3x3 tensor to an array (of stride 9) which is interlaced.
Definition cs_array.cpp:950
void cs_array_int_fill_zero(cs_lnum_t size, int a[])
Assign zero to all elements of an array. Case of a int array.
Definition cs_array.cpp:247
void cs_array_real_set_vector(cs_lnum_t n_elts, const cs_real_t ref_val[3], cs_real_t a[])
Assign a constant vector to an array of stride 3 which is interlaced.
Definition cs_array.cpp:830
void cs_array_flag_fill_zero(cs_lnum_t size, cs_flag_t a[])
Assign zero to all elements of an array. Case of a cs_flag_t array.
Definition cs_array.cpp:124
void cs_array_real_scale(cs_lnum_t n_elts, int stride, const cs_lnum_t *elt_ids, cs_real_t scaling_factor, cs_real_t dest[])
Multiply each value by a scaling factor s.t. dest *= scaling_factor If elt_ids is non-null,...
Definition cs_array.cpp:489
void cs_array_real_set_wvector_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_val[3], const cs_real_t weight[], cs_real_t a[])
Assign a weighted constant vector value to an interlaced array (of stride 3). The subset selection is...
Definition cs_array.cpp:916
void cs_array_real_copy_subset(cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], int mode, const cs_real_t ref[], cs_real_t dest[])
Copy an array ("ref") into another array ("dest") on possibly only a part of the array(s)....
Definition cs_array.cpp:336
void cs_array_lnum_fill_zero(cs_lnum_t size, cs_lnum_t a[])
Assign zero to all elements of an array. Case of a cs_lnum_t array.
Definition cs_array.cpp:146
void cs_array_lnum_set_value_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_lnum_t num, cs_lnum_t a[])
Assign the value "num" to an array on a selected subset of elements. if elt_ids is null,...
Definition cs_array.cpp:222
void cs_array_real_set_scalar(cs_lnum_t n_elts, cs_real_t ref_val, cs_real_t a[])
Assign a constant scalar value to an array.
Definition cs_array.cpp:720
void cs_array_bool_fill_true(cs_lnum_t size, bool a[])
Assign true to all elements of an array. Case of an array of booleans.
Definition cs_array.cpp:88
void cs_array_real_set_vector_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_val[3], cs_real_t a[])
Assign a constant vector to an interlaced array (of stride 3) on a selected subset of elements....
Definition cs_array.cpp:881
void cs_array_real_set_value_on_subset(cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], const cs_real_t ref_val[], cs_real_t a[])
Assign a constant value of dim "stride" to an interlaced array sharing the same stride....
Definition cs_array.cpp:641
void cs_array_real_padd(cs_lnum_t n_elts, const cs_real_t l_add[], cs_real_t r[])
Add in place an array s.t. r += l_add.
Definition cs_array.cpp:541
void cs_array_lnum_copy(cs_lnum_t size, const cs_lnum_t src[], cs_lnum_t dest[])
Copy values from an array of cs_lnum_t type to another of the same dimensions.
Definition cs_array.cpp:170
void cs_array_real_copy(cs_lnum_t size, const cs_real_t src[], cs_real_t dest[])
Copy real values from an array to another of the same dimensions.
Definition cs_array.cpp:457
void cs_array_int_set_value(cs_lnum_t size, int num, int a[])
Assign the value "num" to all elements of an array. Case of a int array.
Definition cs_array.cpp:271
void cs_array_real_set_value(cs_lnum_t n_elts, int stride, const cs_real_t ref_val[], cs_real_t a[])
Definition cs_array.cpp:567
void cs_array_real_set_wscalar_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t ref_val, const cs_real_t weight[], cs_real_t a[])
Assign a weighted constant scalar value to an array on a selected subset of elements....
Definition cs_array.cpp:799
void cs_array_real_set_tensor_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_tens[3][3], cs_real_t a[])
Assign a constant 3x3 tensor to an interlaced array (of stride 9) on a subset of elements....
Definition cs_array.cpp:985
void cs_array_real_set_wvector(cs_lnum_t n_elts, const cs_real_t ref_val[3], const cs_real_t weight[], cs_real_t a[])
Assign a weighted constant vector value to an interlaced array (of stride 3). The array of weights ha...
Definition cs_array.cpp:854
void cs_array_lnum_set_value(cs_lnum_t size, cs_lnum_t num, cs_lnum_t a[])
Assign the value "num" to all elements of an array. Case of a cs_lnum_t array.
Definition cs_array.cpp:199
void cs_array_real_set_wvalue_on_subset(cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], const cs_real_t ref_val[], const cs_real_t weight[], cs_real_t a[])
Definition cs_array.cpp:682
void cs_array_int_set_value_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int num, int a[])
Definition cs_array.cpp:294
void cs_array_real_set_wscalar(cs_lnum_t n_elts, cs_real_t ref_val, const cs_real_t weight[], cs_real_t a[])
Assign a weighted constant scalar value to an array. The weight array has the same size as the array ...
Definition cs_array.cpp:742
void cs_array_copy(cudaStream_t stream, const cs_lnum_t size, const T *src, T *dest)
Copy values from an array to another of the same dimensions.
Definition cs_array_cuda.h:212
void cs_arrays_set_value(cudaStream_t stream, const cs_lnum_t n_elts, const T *ref_val, Arrays &&... arrays)
Assign values to all elements of multiple arrays. ref_val is input as a pointer or an array.
Definition cs_array_cuda.h:120
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
unsigned short int cs_flag_t
Definition cs_defs.h:344
@ k
Definition cs_field_pointer.h:72
static cs_alloc_mode_t cs_check_device_ptr(const void *ptr)
Check if a pointer is associated with a device.
Definition cs_mem.h:787
@ CS_ALLOC_HOST_DEVICE_SHARED
Definition cs_mem.h:57
