cs_array.h File Reference
#include "base/cs_base_accel.h"
Include dependency graph for cs_array.h:
Macros
#define CS_ARRAY_SUBSET_NULL   -1
#define CS_ARRAY_SUBSET_IN   0
#define CS_ARRAY_SUBSET_OUT   1
#define CS_ARRAY_SUBSET_INOUT   2
void cs_array_bool_fill_true (cs_lnum_t size, bool a[])
 Assign true to all elements of an array. Case of an array of booleans.
void cs_array_bool_fill_false (cs_lnum_t size, bool a[])
 Assign false to all elements of an array. Case of an array of booleans.
void cs_array_flag_fill_zero (cs_lnum_t size, cs_flag_t a[])
 Assign zero to all elements of an array. Case of a cs_flag_t array.
void cs_array_lnum_fill_zero (cs_lnum_t size, cs_lnum_t a[])
 Assign zero to all elements of an array. Case of a cs_lnum_t array.
void cs_array_lnum_copy (cs_lnum_t size, const cs_lnum_t src[], cs_lnum_t dest[])
 Copy values from an array of cs_lnum_t type to another of the same dimensions.
void cs_array_lnum_set_value (cs_lnum_t size, cs_lnum_t num, cs_lnum_t a[])
 Assign the value "num" to all elements of an array. Case of a cs_lnum_t array.
void cs_array_lnum_set_value_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_lnum_t num, cs_lnum_t a[])
 Assign the value "num" to an array on a selected subset of elements. if elt_ids is null, then one recovers the function cs_array_lnum_set_value.
void cs_array_int_fill_zero (cs_lnum_t size, int a[])
 Assign zero to all elements of an array. Case of a int array.
void cs_array_int_set_value (cs_lnum_t size, int num, int a[])
 Assign the value "num" to all elements of an array. Case of a int array.
void cs_array_int_set_value_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int num, int a[])
 Assign the value "num" to an array on a selected subset of elements. if elt_ids is null, then one recovers the function cs_array_int_set_value.
void cs_array_real_copy_subset (cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], int mode, const cs_real_t ref[], cs_real_t dest[])
 Copy an array ("ref") into another array ("dest") on possibly only a part of the array(s). Array with stride > 1 are assumed to be interlaced. The subset of elements on which working is defined by "elt_ids". The way to apply the subset is defined with the parameter "mode" as follows:
void cs_array_real_copy (cs_lnum_t size, const cs_real_t src[], cs_real_t dest[])
 Copy real values from an array to another of the same dimensions.
void cs_array_real_scale (cs_lnum_t n_elts, int stride, const cs_lnum_t *elt_ids, cs_real_t scaling_factor, cs_real_t dest[])
 Multiply each value by a scaling factor s.t. dest *= scaling_factor If elt_ids is non-null, one applies an indirection. A stride can also be applied. One assumes an interlaced array.
void cs_array_real_padd (cs_lnum_t n_elts, const cs_real_t l_add[], cs_real_t r[])
 Add in place an array s.t. r += l_add.
void cs_array_real_set_value (cs_lnum_t n_elts, int stride, const cs_real_t ref_val[], cs_real_t a[])
 Assign a constant value of dim "stride" to an interlaced array sharing the same stride.
void cs_array_real_set_wvalue (cs_lnum_t n_elts, int stride, const cs_real_t ref_val[], const cs_real_t weight[], cs_real_t a[])
 Assign a weighted constant value of dim "stride" to an interlaced array sharing the same stride. Apply a weight for each element. This weight is constant for each component of an element.
void cs_array_real_set_value_on_subset (cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], const cs_real_t ref_val[], cs_real_t a[])
 Assign a constant value of dim "stride" to an interlaced array sharing the same stride. Only a subset of elements are considered. If elt_ids is null, then one recovers the function cs_array_real_set_value.
void cs_array_real_set_wvalue_on_subset (cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], const cs_real_t ref_val[], const cs_real_t weight[], cs_real_t a[])
 Assign a weighted constant value of dim "stride" to an interlaced array sharing the same stride. Only a subset of elements are considered. If elt_ids is null, then one recovers the function cs_array_real_set_wvalue Apply a weight for each element. This weight is constant for each component of an element.
void cs_array_real_set_scalar (cs_lnum_t n_elts, cs_real_t ref_val, cs_real_t a[])
 Assign a constant scalar value to an array.
void cs_array_real_set_wscalar (cs_lnum_t n_elts, cs_real_t ref_val, const cs_real_t weight[], cs_real_t a[])
 Assign a weighted constant scalar value to an array. The weight array has the same size as the array "a".
void cs_array_real_set_scalar_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t ref_val, cs_real_t a[])
 Assign a constant scalar value to an array on a selected subset of elements. If elt_ids is null, then one recovers the function cs_array_real_set_scalar.
void cs_array_real_set_wscalar_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t ref_val, const cs_real_t weight[], cs_real_t a[])
 Assign a weighted constant scalar value to an array on a selected subset of elements. If elt_ids is null, then one recovers the function cs_array_real_set_wscalar.
void cs_array_real_set_vector (cs_lnum_t n_elts, const cs_real_t ref_val[3], cs_real_t a[])
 Assign a constant vector to an array of stride 3 which is interlaced.
void cs_array_real_set_wvector (cs_lnum_t n_elts, const cs_real_t ref_val[3], const cs_real_t weight[], cs_real_t a[])
 Assign a weighted constant vector value to an interlaced array (of stride 3). The array of weights has the same size as the array "a".
void cs_array_real_set_vector_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_val[3], cs_real_t a[])
 Assign a constant vector to an interlaced array (of stride 3) on a selected subset of elements. If elt_ids is null, then one recovers the function cs_array_real_set_vector.
void cs_array_real_set_wvector_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_val[3], const cs_real_t weight[], cs_real_t a[])
 Assign a weighted constant vector value to an interlaced array (of stride 3). The subset selection is given by elt_ids. If null, then one recovers the function cs_array_real_set_wvector The array of weights has the same size as the array "a".
void cs_array_real_set_tensor (cs_lnum_t n_elts, const cs_real_t ref_tens[3][3], cs_real_t a[])
 Assign a constant 3x3 tensor to an array (of stride 9) which is interlaced.
void cs_array_real_set_tensor_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_tens[3][3], cs_real_t a[])
 Assign a constant 3x3 tensor to an interlaced array (of stride 9) on a subset of elements. If elt_ids is null, then one recovers the function cs_array_real_set_tensor.
void cs_array_real_fill_zero (cs_lnum_t size, cs_real_t a[])
void cs_array_set_value_real (cs_lnum_t n_elts, cs_lnum_t dim, cs_real_t v, cs_real_t a[])
 Assign a constant value to an array (deprecated function).
◆ CS_ARRAY_SUBSET_IN
◆ CS_ARRAY_SUBSET_INOUT
◆ CS_ARRAY_SUBSET_NULL
◆ CS_ARRAY_SUBSET_OUT
◆ cs_array_bool_fill_false()
void cs_array_bool_fill_false ( cs_lnum_t size,
bool a[] )
[in]sizetotal number of elements to set
[in,out]aarray to set
◆ cs_array_bool_fill_true()
void cs_array_bool_fill_true ( cs_lnum_t size,
bool a[] )
◆ cs_array_flag_fill_zero()
void cs_array_flag_fill_zero ( cs_lnum_t size,
cs_flag_t a[] )
[in]sizetotal number of elements to set to zero
[in,out]aarray of flags to set
◆ cs_array_int_fill_zero()
void cs_array_int_fill_zero ( cs_lnum_t size,
int a[] )
◆ cs_array_int_set_value()
void cs_array_int_set_value ( cs_lnum_t size,
int num,
int a[] )
[in]numvalue to set
◆ cs_array_int_set_value_on_subset()
void cs_array_int_set_value_on_subset ( cs_lnum_t n_elts,
int num,
int a[] )
[in]n_eltsnumber of elements
[in]elt_idslist of ids in the subset or null (size: n_elts)
[in]numvalue to set
◆ cs_array_lnum_copy()
void cs_array_lnum_copy ( cs_lnum_t size,
cs_lnum_t dest[] )
[in]sizenumber of elements * dimension
[in]srcsource array values (size: n_elts*dim)
[out]destdestination array values (size: n_elts*dim)
◆ cs_array_lnum_fill_zero()
void cs_array_lnum_fill_zero ( cs_lnum_t size,
cs_lnum_t a[] )
◆ cs_array_lnum_set_value()
void cs_array_lnum_set_value ( cs_lnum_t size,
cs_lnum_t num,
cs_lnum_t a[] )
[in]numvalue to set
◆ cs_array_lnum_set_value_on_subset()
void cs_array_lnum_set_value_on_subset ( cs_lnum_t n_elts,
cs_lnum_t num,
cs_lnum_t a[] )
[in]numvalue to set
◆ cs_array_real_copy()
void cs_array_real_copy ( cs_lnum_t size,
cs_real_t dest[] )
◆ cs_array_real_copy_subset()
void cs_array_real_copy_subset ( cs_lnum_t n_elts,
int stride,
int mode,
cs_real_t dest[] )
  • Only the "ref" array if mode = 0 (CS_ARRAY_SUBSET_IN)
  • Only the "dest" array if mode = 1 (CS_ARRAY_SUBSET_OUT)
  • Both "ref" and "dest" arrays if mode = 2 (CS_ARRAY_SUBSET_INOUT)
It elt_ids is null or mode < 0 (CS_ARRAY_SUBSET_NULL), then the behavior is as cs_array_real_copy
One assumes that all arrays are allocated with a correct size.
[in]n_eltsnumber of elements in the array
[in]stridenumber of values for each element
[in]modeapply the subset ids to which array(s)
[in]refreference values to copy
[in,out]destarray storing values after applying the indirection
◆ cs_array_real_fill_zero()
void cs_array_real_fill_zero ( cs_lnum_t size,
cs_real_t a[] )
◆ cs_array_real_padd()
void cs_array_real_padd ( cs_lnum_t n_elts,
cs_real_t r[] )
[in]l_addarray to add
[out]rdestination array values
◆ cs_array_real_scale()
void cs_array_real_scale ( cs_lnum_t n_elts,
int stride,
const cs_lnum_t * elt_ids,
cs_real_t dest[] )
[in]scaling_factorvalue of the scaling factor
◆ cs_array_real_set_scalar()
void cs_array_real_set_scalar ( cs_lnum_t n_elts,
cs_real_t ref_val,
cs_real_t a[] )
[in]ref_valvalue to assign
◆ cs_array_real_set_scalar_on_subset()
void cs_array_real_set_scalar_on_subset ( cs_lnum_t n_elts,
cs_real_t ref_val,
cs_real_t a[] )
◆ cs_array_real_set_tensor()
void cs_array_real_set_tensor ( cs_lnum_t n_elts,
cs_real_t a[] )
[in]ref_tenstensor to assign
◆ cs_array_real_set_tensor_on_subset()
void cs_array_real_set_tensor_on_subset ( cs_lnum_t n_elts,
cs_real_t a[] )
[in]elt_idslist of ids defining the subset or nullptr
◆ cs_array_real_set_value()
void cs_array_real_set_value ( cs_lnum_t n_elts,
int stride,
cs_real_t a[] )
[in]ref_vallist of values to assign (size: stride)
[in,out]aarray to set (size: n_elts*stride)
◆ cs_array_real_set_value_on_subset()
void cs_array_real_set_value_on_subset ( cs_lnum_t n_elts,
int stride,
cs_real_t a[] )
[in,out]aarray to set (size >= n_elts * stride)
◆ cs_array_real_set_vector()
void cs_array_real_set_vector ( cs_lnum_t n_elts,
cs_real_t a[] )
[in]ref_valvector to assign
◆ cs_array_real_set_vector_on_subset()
void cs_array_real_set_vector_on_subset ( cs_lnum_t n_elts,
cs_real_t a[] )
◆ cs_array_real_set_wscalar()
void cs_array_real_set_wscalar ( cs_lnum_t n_elts,
cs_real_t ref_val,
cs_real_t a[] )
[in]weightvalues of the weight to apply
◆ cs_array_real_set_wscalar_on_subset()
void cs_array_real_set_wscalar_on_subset ( cs_lnum_t n_elts,
cs_real_t ref_val,
cs_real_t a[] )
[in]weightvalues of weights to apply
◆ cs_array_real_set_wvalue()
void cs_array_real_set_wvalue ( cs_lnum_t n_elts,
int stride,
cs_real_t a[] )
[in]weightvalues of the weight to apply (size: n_elts)
◆ cs_array_real_set_wvalue_on_subset()
void cs_array_real_set_wvalue_on_subset ( cs_lnum_t n_elts,
int stride,
cs_real_t a[] )
[in]weightvalues of the weight to apply (size >= n_elts)
[in,out]aarray to set (size >= n_elts*stride)
◆ cs_array_real_set_wvector()
void cs_array_real_set_wvector ( cs_lnum_t n_elts,
cs_real_t a[] )
◆ cs_array_real_set_wvector_on_subset()
void cs_array_real_set_wvector_on_subset ( cs_lnum_t n_elts,
cs_real_t a[] )
◆ cs_array_set_value_real()
void cs_array_set_value_real ( cs_lnum_t n_elts,
cs_lnum_t dim,
cs_real_t v,
cs_real_t a[] )
[in]n_eltsnumber of associated elements
[in]dimassociated dimension
[in]vvalue to assign
[out]aarray values (size: n_elts*dim)
