Definition cs_defs.h:542
Definition cs_defs.h:543
unsigned short int cs_flag_t
Definition cs_defs.h:344
cs_domain_t * cs_glob_domain
Definition cs_domain.cpp:89
void cs_domain_free(cs_domain_t **p_domain)
Free a cs_domain_t structure.
Definition cs_domain.cpp:270
bool cs_domain_needs_log(const cs_domain_t *domain)
Check if an output is requested according to the domain setting.
Definition cs_domain.cpp:456
void cs_domain_set_output_param(cs_domain_t *domain, int restart_nt, int log_nt, int verbosity)
Set parameters related to the way output/logging is done.
Definition cs_domain.cpp:352
void cs_domain_set_cdo_mode(cs_domain_t *domain, cs_param_cdo_mode_t mode)
Set the global variable storing the mode of activation to apply to CDO/HHO schemes....
Definition cs_domain.cpp:314
bool cs_domain_needs_iteration(cs_domain_t *domain)
Check if one needs to continue iterations in time.
Definition cs_domain.cpp:417
cs_domain_stage_t
Indicator describing at which stage is the computation.
Definition cs_domain.h:91
@ CS_DOMAIN_STAGE_AFTER_TIME_LOOP
Definition cs_domain.h:98
@ CS_DOMAIN_STAGE_TIME_STEP_END
Definition cs_domain.h:97
@ CS_DOMAIN_STAGE_BEFORE_TIME_LOOP
Definition cs_domain.h:94
@ CS_DOMAIN_STAGE_TIME_STEP_SUB_ITERATION
Definition cs_domain.h:96
@ CS_DOMAIN_STAGE_TIME_STEP_BEGIN
Definition cs_domain.h:95
@ CS_DOMAIN_STAGE_BEFORE_STEADY_COMPUTATION
Definition cs_domain.h:93
@ CS_DOMAIN_N_STAGES
Definition cs_domain.h:100
void cs_domain_set_stage(cs_domain_t *domain, cs_domain_stage_t stage)
Set the computation stage in the domain structure.
Definition cs_domain.cpp:376
int cs_domain_get_cdo_mode(const cs_domain_t *domain)
Get the mode of activation for the CDO/HHO schemes. Deprecated way to retrieve the CDO mode.
Definition cs_domain.cpp:332
void cs_domain_increment_time(cs_domain_t *domain)
Update time step after one temporal iteration.
Definition cs_domain.cpp:476
cs_domain_stage_t cs_domain_get_stage(const cs_domain_t *domain)
Retrieve the computation stage from the domain structure.
Definition cs_domain.cpp:397
static void cs_domain_increment_time_step(cs_domain_t *domain)
Update the time step after one temporal iteration.
Definition cs_domain.h:202
cs_domain_t * cs_domain_create(void)
Create and initialize by default a cs_domain_t structure.
Definition cs_domain.cpp:172
cs_param_cdo_mode_t
Definition cs_param_cdo.h:94
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition cs_boundary.h:155
Definition cs_cdo_connect.h:61
Definition cs_cdo_quantities.h:145
High-level metadata for handling CDO/HHO schemes.
Definition cs_domain.h:109
cs_flag_t hho_scheme_flag
Definition cs_domain.h:119
cs_flag_t mac_scheme_flag
Definition cs_domain.h:120
cs_flag_t eb_scheme_flag
Definition cs_domain.h:114
cs_flag_t vcb_scheme_flag
Definition cs_domain.h:118
cs_flag_t cb_scheme_flag
Definition cs_domain.h:116
cs_flag_t fb_scheme_flag
Definition cs_domain.h:115
cs_flag_t vb_scheme_flag
Definition cs_domain.h:117
Definition cs_domain.h:129
cs_boundary_t * ale_boundaries
Definition cs_domain.h:153
int verbosity
Definition cs_domain.h:169
cs_mesh_quantities_t * mesh_quantities
Definition cs_domain.h:140
cs_time_step_t * time_step
Definition cs_domain.h:160
char * study_name
Definition cs_domain.h:135
char * case_name
Definition cs_domain.h:134
int output_nt
Definition cs_domain.h:167
cs_timer_counter_t tcp
Definition cs_domain.h:177
bool only_steady
Definition cs_domain.h:157
cs_cdo_connect_t * connect
Definition cs_domain.h:147
char * run_id
Definition cs_domain.h:133
cs_time_step_options_t * time_options
Definition cs_domain.h:161
Definition cs_domain.h:163
int restart_nt
Definition cs_domain.h:168
cs_timer_counter_t tca
Definition cs_domain.h:179
bool is_last_iter
Definition cs_domain.h:158
cs_domain_cdo_context_t * cdo_context
Definition cs_domain.h:173
cs_boundary_t * boundaries
Definition cs_domain.h:152
cs_cdo_quantities_t * cdo_quantities
Definition cs_domain.h:148
Definition cs_mesh_quantities.h:92
time step options descriptor
Definition cs_time_step.h:92
time step descriptor
Definition cs_time_step.h:64
int nt_cur
Definition cs_time_step.h:74
