43#define GUI_STR(str) #str
301 const char *property_name,
cs_real_t cs_real_33_t[3][3]
Definition cs_defs.h:368
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
@ vel
Definition cs_field_pointer.h:70
void cs_gui_porous_model(void)
Definition cs_gui.cpp:4295
void cs_gui_initial_conditions(void)
Apply initial conditions based on GUI-defined settings.
Definition cs_gui.cpp:2781
void cs_gui_equation_parameters(void)
Definition cs_gui.cpp:2149
void cs_gui_time_tables(void)
Read GUI defined time tables.
Definition cs_gui.cpp:5750
void cs_gui_scalar_source_terms(cs_field_t *f, const cs_real_t *pvar, cs_real_t *tsexp, cs_real_t *tsimp)
void cs_gui_pressure_drop_by_zone(void)
Definition cs_gui.cpp:5254
void cs_gui_checkpoint_parameters(void)
Read GUi-defined Checkpoint parameters.
Definition cs_gui.cpp:2113
void cs_gui_parallel_io(void)
Definition cs_gui.cpp:3798
void cs_gui_momentum_source_terms(const cs_real_3_t *vel, cs_real_3_t *tsexp, cs_real_33_t *tsimp)
void cs_gui_finalize(void)
Definition cs_gui.cpp:2261
void cs_gui_dt(void)
Definition cs_gui.cpp:1883
cs_equation_param_t * cs_gui_get_equation_param(const char *name)
Definition cs_gui.cpp:2284
void cs_gui_thermal_source_terms(cs_field_t *f, const cs_real_t *pvar, cs_real_t *tsexp, cs_real_t *tsimp)
void cs_gui_internal_coupling(void)
Definition cs_gui.cpp:5394
void cs_gui_properties_value(const char *property_name, double *value)
Definition cs_gui.cpp:4331
void cs_gui_physical_variable(void)
Definition cs_gui.cpp:5867
void cs_gui_turb_model(void)
Definition cs_gui.cpp:4750
void cs_gui_time_moments(void)
Definition cs_gui.cpp:4544
void cs_gui_porosity(void)
Definition cs_gui.cpp:2036
void cs_gui_properties_value_by_fluid_id(const int fluid_id, const char *property_name, double *value)
Definition cs_gui.cpp:4357
void cs_gui_physical_properties(void)
Definition cs_gui.cpp:4025
void cs_gui_hydrostatic_equ_param(void)
Definition cs_gui.cpp:1926
void cs_gui_user_variables(void)
Definition cs_gui.cpp:4943
void cs_gui_linear_solvers(void)
Definition cs_gui.cpp:3391
void cs_gui_scalar_model_settings(void)
Definition cs_gui.cpp:4392
void cs_gui_fluid_properties_value(const char *param, double *value)
Definition cs_gui.cpp:2307
void cs_gui_hydrostatic_pressure(void)
Definition cs_gui.cpp:1904
void cs_gui_calculator_functions(void)
Definition cs_gui.cpp:5032
void cs_gui_turbomachinery(void)
Definition cs_gui.cpp:4644
void cs_gui_numerical_options(void)
Definition cs_gui.cpp:3673
void cs_gui_user_arrays(void)
Definition cs_gui.cpp:5004
int cs_gui_thermal_model_code(void)
Definition cs_gui.cpp:4507
void cs_gui_dt_param(void)
Definition cs_gui.cpp:1949
void cs_gui_zones(void)
Definition cs_gui.cpp:5080
void cs_gui_define_fans(void)
Definition cs_gui.cpp:5276
void cs_gui_balance_by_zone(void)
Definition cs_gui.cpp:5225
void cs_gui_error_estimator(void)
Definition cs_gui.cpp:5342
void cs_gui_usage_log(void)
Definition cs_gui.cpp:4915
void cs_gui_cp_params(void)
Definition cs_gui.cpp:1791
void cs_gui_thermal_source_terms_setup(void)
Define thermal scalar source terms as xdef.
Definition cs_gui.cpp:5685
void cs_gui_turb_ref_values(void)
Definition cs_gui.cpp:4876
void cs_gui_turbomachinery_rotor(void)
Definition cs_gui.cpp:4659
void cs_gui_laminar_viscosity(void)
Definition cs_gui.cpp:1814
void cs_gui_partition(void)
Definition cs_gui.cpp:3865
void cs_gui_head_losses(const cs_zone_t *zone, const cs_real_3_t *cvara_vel, cs_real_t cku[][6])
Compute GUI-defined head losses for a given volume zone.
Definition cs_gui.cpp:2710
void cs_gui_mpi_algorithms(void)
Definition cs_gui.cpp:3961
void cs_gui_physical_constants(void)
Definition cs_gui.cpp:3986
void cs_gui_thermal_model(void)
Definition cs_gui.cpp:4462
void cs_gui_groundwater_property_laws(int permeability, int diffusion, int unsaturated)
Definition cs_gui.cpp:2327
const cs_gui_volume_meg_context_t * cs_gui_add_volume_meg_context(const cs_zone_t *zone, const cs_field_t *fields[], const int n_fields)
Add new volume MEG function context info.
Definition cs_gui.cpp:5479
Definition cs_equation_param.h:193
Definition cs_field.h:158
const cs_zone_t * zone
Definition cs_gui.h:53
const cs_field_t ** fields
Definition cs_gui.h:54
