cs_turbulence_rij.h
1#ifndef __CS_TURBULENCE_RIJ_H__
2#define __CS_TURBULENCE_RIJ_H__
5 * Rij-epsilon turbulence model.
31 * Local headers
34#include "base/cs_defs.h"
41 * Public function prototypes
44/*----------------------------------------------------------------------------*/
55/*-----------------------------------------------------------------------------*/
56
57void
58cs_turbulence_rij(int phase_id);
59
60/*----------------------------------------------------------------------------*/
69/*----------------------------------------------------------------------------*/
70
71void
73 int phase_id,
74 cs_real_t c_durbin_l);
75
76/*----------------------------------------------------------------------------*/
86/*----------------------------------------------------------------------------*/
87
88void
90 cs_real_t almax);
91
92/*----------------------------------------------------------------------------*/
100/*----------------------------------------------------------------------------*/
101
102void
103cs_turbulence_rij_clip(int phase_id,
104 cs_lnum_t n_cells);
105
106/*----------------------------------------------------------------------------*/
112/*----------------------------------------------------------------------------*/
113
114void
115cs_turbulence_rij_mu_t(int phase_id);
116
117/*----------------------------------------------------------------------------*/
120/*----------------------------------------------------------------------------*/
121
122void
124
125/*----------------------------------------------------------------------------*/
126
128
129#endif /* __CS_TURBULENCE_RIJ_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
void cs_turbulence_rij_clip(int phase_id, cs_lnum_t n_cells)
Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version).
Definition cs_turbulence_rij.cpp:3894
void cs_turbulence_rij_mu_t(int phase_id)
Compute the turbulent viscosity for the Reynolds Stress model.
Definition cs_turbulence_rij.cpp:4153
void cs_turbulence_rij_init_by_ref_quantities(cs_real_t uref, cs_real_t almax)
Initialize Rij-epsilon variables based on reference quantities.
Definition cs_turbulence_rij.cpp:3829
void cs_turbulence_rij_compute_rusanov(void)
Compute Rusanov equivalent diffusivity of the model.
Definition cs_turbulence_rij.cpp:4260
void cs_turbulence_rij_solve_alpha(int f_id, int phase_id, cs_real_t c_durbin_l)
Solve the equation on alpha in the framework of the Rij-EBRSM model.
Definition cs_turbulence_rij.cpp:3568
void cs_turbulence_rij(int phase_id)
Solve the for incompressible flows or slightly compressible flows for one time step.
Definition cs_turbulence_rij.cpp:2913
