cs_turbulence_rij.h File Reference
Include dependency graph for cs_turbulence_rij.h:
void cs_turbulence_rij (int phase_id)
 Solve the $ R_{ij} - \epsilon $ for incompressible flows or slightly compressible flows for one time step.
void cs_turbulence_rij_solve_alpha (int f_id, int phase_id, cs_real_t c_durbin_l)
 Solve the equation on alpha in the framework of the Rij-EBRSM model.
void cs_turbulence_rij_init_by_ref_quantities (cs_real_t uref, cs_real_t almax)
 Initialize Rij-epsilon variables based on reference quantities.
void cs_turbulence_rij_clip (int phase_id, cs_lnum_t n_cells)
 Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version).
void cs_turbulence_rij_mu_t (int phase_id)
 Compute the turbulent viscosity for the Reynolds Stress model.
void cs_turbulence_rij_compute_rusanov (void)
 Compute Rusanov equivalent diffusivity of the model.
◆ cs_turbulence_rij()
void cs_turbulence_rij ( int phase_id)
Please refer to the $ R_{ij} - \epsilon $ model section of the theory guide for more informations, as well as the turrij section.
[in]phase_idturbulent phase id (-1 for single phase flow) !
◆ cs_turbulence_rij_clip()
void cs_turbulence_rij_clip ( int phase_id,
cs_lnum_t n_cells )
[in]n_cellsnumber of cells
◆ cs_turbulence_rij_compute_rusanov()
void cs_turbulence_rij_compute_rusanov ( void )
◆ cs_turbulence_rij_init_by_ref_quantities()
void cs_turbulence_rij_init_by_ref_quantities ( cs_real_t uref,
cs_real_t almax )
If uref is not provided (0 or negative), values are set at a large negative value (-cs_math_big_r) to allow for later checks.
[in]urefcharacteristic flow velocity
[in]almaxcharacteristic macroscopic length of the domain
◆ cs_turbulence_rij_mu_t()
void cs_turbulence_rij_mu_t ( int phase_id)
◆ cs_turbulence_rij_solve_alpha()
void cs_turbulence_rij_solve_alpha ( int f_id,
int phase_id,
cs_real_t c_durbin_l )
Also called for alpha of scalars for EB-DFM.
[in]f_idfield id of alpha variable
[in]c_durbin_lconstant for the Durbin length !
