cs_mobile_structures.h File Reference
#include "base/cs_restart.h"
#include "base/cs_time_control.h"
Include dependency graph for cs_mobile_structures.h:
void cs_mobile_structures_setup (void)
 Initialize mobile structures with ALE for internal coupling.
void cs_mobile_structures_initialize (void)
void cs_mobile_structures_finalize (void)
 Finalize mobile structures with ALE for internal coupling.
void cs_mobile_structures_log_setup (void)
 Log structures and coupling information.
int cs_mobile_structures_get_n_int_structures (void)
 Query number of internal mobile structures defined.
int cs_mobile_structures_get_n_ext_structures (void)
 Query number of external mobile structures defined.
void cs_mobile_structures_add_n_structures (int n_structures)
 Add internal mobile structures.
void cs_mobile_structures_add_external_structures (void)
 Add external mobile structures.
void cs_mobile_structures_set_newmark_coefficients (cs_real_t alpha, cs_real_t beta, cs_real_t gamma)
 Set Newmark coefficients for internal mobile structures.
void cs_mobile_structures_prediction (int itrale, int italim, int ineefl, int impale[])
 Predict displacement of mobile structures with ALE.
void cs_mobile_structures_displacement (int itrale, int italim, int *itrfin)
 Displacement of mobile structures with ALE for internal coupling.
void cs_mobile_structures_restart_read (cs_restart_t *r)
 Read mobile structures data to checkpoint.
void cs_mobile_structures_restart_write (cs_restart_t *r)
 Write mobile structures data to checkpoint.
int cs_glob_mobile_structures_n_iter_max
double cs_glob_mobile_structures_i_eps
◆ cs_mobile_structures_add_external_structures()
void cs_mobile_structures_add_external_structures ( void )
This function may be called multiple time to change the number of mobile structures.
◆ cs_mobile_structures_add_n_structures()
void cs_mobile_structures_add_n_structures ( int n_structures)
[in]n_structuresnumber of internal mobile structures
◆ cs_mobile_structures_displacement()
void cs_mobile_structures_displacement ( int itrale,
int italim,
int * itrfin )
[in]itraleALE iteration number
[in]italimimplicit coupling iteration number
[in,out]itrfinindicator for last iteration of implicit coupling
◆ cs_mobile_structures_finalize()
void cs_mobile_structures_finalize ( void )
◆ cs_mobile_structures_get_n_ext_structures()
int cs_mobile_structures_get_n_ext_structures ( void )
◆ cs_mobile_structures_get_n_int_structures()
int cs_mobile_structures_get_n_int_structures ( void )
◆ cs_mobile_structures_initialize()
void cs_mobile_structures_initialize ( void )
◆ cs_mobile_structures_log_setup()
void cs_mobile_structures_log_setup ( void )
◆ cs_mobile_structures_prediction()
void cs_mobile_structures_prediction ( int itrale,
int italim,
int ineefl,
int impale[] )
[in]ineeflindicate whether fluxes should be saved
[out]impaleimposed displacement indicator
◆ cs_mobile_structures_restart_read()
void cs_mobile_structures_restart_read ( cs_restart_t * r)
[in,out]rassociated restart file pointer
◆ cs_mobile_structures_restart_write()
void cs_mobile_structures_restart_write ( cs_restart_t * r)
◆ cs_mobile_structures_set_newmark_coefficients()
void cs_mobile_structures_set_newmark_coefficients ( cs_real_t alpha,
cs_real_t beta,
cs_real_t gamma )
[in]alphaalpha coefficient for Newmark algorithm
[in]betabeta coefficient for Newmark algorithm
[in]gammagamma coefficient for Newmark algorithm
◆ cs_mobile_structures_setup()
void cs_mobile_structures_setup ( void )
◆ cs_glob_mobile_structures_i_eps
extern
Relative precision of implicitation of the structure displacement
◆ cs_glob_mobile_structures_n_iter_max
extern
Maximum number of implicitation iterations of the structure displacement
