1#ifndef __CS_BOUNDARY_H__
2#define __CS_BOUNDARY_H__
45#define CS_BOUNDARY_PRESSURE_NO_RESCALING 1
46#define CS_BOUNDARY_PRESSURE_RESCALING 0
49#define CS_BOUNDARY_WALLS_NAME "auto:wall"
51#define CS_BOUNDARY_UNDEFINED 0
260 const char *zone_name);
cs_boundary_flow_subtype_bits_t
Definition cs_boundary.h:74
@ CS_BOUNDARY_FREE_INLET_OUTLET
Definition cs_boundary.h:107
@ CS_BOUNDARY_INLET_QH
Definition cs_boundary.h:113
@ CS_BOUNDARY_OUTLET
Definition cs_boundary.h:86
@ CS_BOUNDARY_COUPLED_DF
Definition cs_boundary.h:131
@ CS_BOUNDARY_FREE_SURFACE
Definition cs_boundary.h:125
@ CS_BOUNDARY_INLET_SUBSONIC_PH
Definition cs_boundary.h:116
@ CS_BOUNDARY_ROUGH_WALL
Definition cs_boundary.h:95
@ CS_BOUNDARY_SYMMETRY
Definition cs_boundary.h:89
@ CS_BOUNDARY_INLET
Definition cs_boundary.h:83
@ CS_BOUNDARY_SLIDING_WALL
Definition cs_boundary.h:98
@ CS_BOUNDARY_IMPOSED_P
Definition cs_boundary.h:104
@ CS_BOUNDARY_IMPOSED_VEL
Definition cs_boundary.h:101
@ CS_BOUNDARY_CONVECTIVE_INLET
Definition cs_boundary.h:110
Definition cs_boundary.h:128
@ CS_BOUNDARY_WALL
Definition cs_boundary.h:80
@ CS_BOUNDARY_SUBSONIC
Definition cs_boundary.h:119
@ CS_BOUNDARY_SUPERSONIC
Definition cs_boundary.h:122
int cs_boundary_type_t
Definition cs_boundary.h:69
void cs_boundary_set_default(cs_boundary_t *boundaries, cs_boundary_type_t type)
Set the default boundary related to the given cs_boundary_t structure.
Definition cs_boundary.cpp:428
void cs_boundary_free(cs_boundary_t **p_boundaries)
Free all metadate related to the domain boundaries.
Definition cs_boundary.cpp:480
void cs_boundary_get_type_descr(const cs_boundary_t *bdy, cs_boundary_type_t b_type, int descr_len_max, char descr[])
Build a boundary type description.
Definition cs_boundary.cpp:648
cs_boundary_t * cs_boundary_create(cs_boundary_category_t category, cs_boundary_type_t default_type)
Create a default boundary structure for the computational domain.
Definition cs_boundary.cpp:455
int cs_boundary_need_pressure_rescaling(cs_lnum_t n_b_faces, const cs_boundary_type_t bf_type[])
Check if one needs to perform a pressure rescaling (in case of a Dirichlet on the velocity for the wh...
Definition cs_boundary.cpp:608
void cs_boundary_add(cs_boundary_t *bdy, cs_boundary_type_t type, const char *zone_name)
Add a new boundary type for a given boundary zone.
Definition cs_boundary.cpp:504
int cs_boundary_id_by_zone_id(const cs_boundary_t *boundaries, int z_id)
Retrieve the related id associated to a boundary from its zone id.
Definition cs_boundary.cpp:395
Definition cs_boundary.h:59
@ CS_BOUNDARY_CATEGORY_ALE
Definition cs_boundary.h:62
@ CS_BOUNDARY_CATEGORY_FLOW
Definition cs_boundary.h:61
@ CS_BOUNDARY_CATEGORY_RADIATIVE
Definition cs_boundary.h:63
void cs_boundary_log_setup(const cs_boundary_t *bdy)
Summarize the setup of the boundary of the computational domain.
Definition cs_boundary.cpp:681
void cs_boundary_def_wall_zones(cs_boundary_t *boundaries)
Add a new zone gathering all CS_BOUNDARY_WALL type zones.
Definition cs_boundary.cpp:573
cs_boundary_t * cs_glob_boundaries
cs_boundary_ale_subtype_bits_t
Definition cs_boundary.h:138
@ CS_BOUNDARY_ALE_EXTERNAL_COUPLING
Definition cs_boundary.h:145
@ CS_BOUNDARY_ALE_IMPOSED_DISP
Definition cs_boundary.h:143
@ CS_BOUNDARY_ALE_SLIDING
Definition cs_boundary.h:141
@ CS_BOUNDARY_ALE_FIXED
Definition cs_boundary.h:140
@ CS_BOUNDARY_ALE_INTERNAL_COUPLING
Definition cs_boundary.h:144
@ CS_BOUNDARY_ALE_IMPOSED_VEL
Definition cs_boundary.h:142
@ CS_BOUNDARY_ALE_FREE_SURFACE
Definition cs_boundary.h:146
void cs_boundary_build_type_array(const cs_boundary_t *boundaries, cs_lnum_t n_b_faces, cs_boundary_type_t bf_type[])
Build an array on boundary faces which specifies the boundary type for each face.
Definition cs_boundary.cpp:543
bool cs_boundary_has_type(const cs_boundary_t *boundaries, int type_flag)
Check if a boundary with a given flag is present.
Definition cs_boundary.cpp:369
Definition cs_defs.h:542
Definition cs_defs.h:543
Definition cs_defs.h:335
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition cs_boundary.h:155
Definition cs_boundary.h:158
int n_boundaries
Definition cs_boundary.h:160
int * zone_ids
Definition cs_boundary.h:162
Definition cs_boundary.h:157
cs_boundary_type_t * types
Definition cs_boundary.h:161
