Module for definition of general parameters. More...
Modules | |
module | paramx |
integer | nscamx |
maximum number of scalars solutions of an advection equation, apart from the variables of the turbulence model ![]() | |
integer | nvarmx |
maximal number of variables = nscamx + 12 (u,v,w,P,Rij,e,alp) | |
integer | iindef |
pointer for undefined type face (non-standard case) | |
integer | ientre |
if itypfb=ientre: inlet face. | |
integer | isolib |
if itypfb=isolib: free outlet face (or more precisely free inlet/outlet with forced pressure) | |
integer | isymet |
if itypfb=isymet: symmetry face (or wall without friction). | |
integer | iparoi |
if itypfb=iparoi: smooth solid wall face, impermeable and with friction. | |
integer | iparug |
if itypfb=iparug: rough solid wall face, impermeable and with friction. | |
integer | iesicf |
if itypfb=iesicf: imposed inlet/outlet for compressible flow (for example, supersonic inlet). | |
integer | isspcf |
if itypfb=isspcf: supersonic outlet for compressible flow. | |
integer | isopcf |
if itypfb=isopcf: mixed outlet for compressible flow with a given pressure. | |
integer | iephcf |
if itypfb=iephcf: mixed inlet for compressible flow with given total pressure and total enthalpy (reservoir boundary conditions). | |
integer | ieqhcf |
integer | icscpl |
code/code coupling condition | |
integer | icscpd |
code/code coupling condition with decentered flux | |
integer | ifrent |
if itypfb=ifrent: free entrance based on Bernoulli equation when the flow is incoming, standard outlet when outgoing | |
integer | ifresf |
if itypfb=ifresf: free surface for mobile mesh boundary condition | |
integer | i_convective_inlet |
if itypfb=i_convective_inlet: inlet face where the total mass flux is prescribed. | |
integer | ibfixe |
boundary condition type for mesh velocity in ALE: fixed wall | |
integer | igliss |
boundary condition type for mesh velocity in ALE: sliding wall | |
integer | ivimpo |
boundary condition type for mesh velocity in ALE: imposed velocity. | |
integer | ibalfs |
Boundary condition type for mesh velocity in ALE for modelling free surface ( ![]() | |
integer | nstrmx |
maximum number of structures in ALE | |
integer | cs_f_user_head_losses |
integer | cs_user_boundary_conditions |
integer | cs_user_cooling_towers |
integer | cs_user_combustion |
integer | cs_user_extra_operations |
integer | cs_user_initialization |
integer | cs_user_mass_source_terms |
integer | cs_user_metal_structures_source_terms |
integer | cs_user_parameters |
integer | cs_user_physical_properties |
integer | cs_user_turbulence_source_terms |
integer | cs_user_turbulence_source_terms2 |
integer | cs_user_atmo_soil |
integer | cs_user_physical_properties_smagorinsky_c |
integer | usalcl |
integer | usatdv |
integer | usati1 |
integer | usatph |
integer | usatsoil |
integer | uscfx1 |
integer | uscfx2 |
integer | usipph |
integer | ushist |
integer | usphyv |
integer | usporo |
integer | ussmag |
integer | usstr1 |
integer | usstr2 |
integer | ustsnv |
integer | ustssc |
integer | ustsvv |
integer | usthht |
integer | usvosy |
integer | usvpst |
integer | usvist |
