1#ifndef __CS_POROSITY_FROM_SCAN_H__
2#define __CS_POROSITY_FROM_SCAN_H__
Definition cs_defs.h:542
Definition cs_defs.h:342
cs_real_t cs_real_34_t[3][4]
Definition cs_defs.h:374
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
cs_porosity_from_scan_opt_t * cs_glob_porosity_from_scan_opt
void cs_porosity_from_scan_set_output_name(const char *output_name)
Set the output name for the FVM writer of scan points.
Definition cs_porosity_from_scan.cpp:956
cs_ibm_cog_location_t
Definition cs_porosity_from_scan.h:71
@ CS_COG_FROM_PYRAMID
Definition cs_porosity_from_scan.h:74
@ CS_COG_WITHOUT_RECONSTRUCTION_FOR_IBM_PLANE
Definition cs_porosity_from_scan.h:75
@ CS_COG_FROM_FLUID_FACES
Definition cs_porosity_from_scan.h:73
void cs_ibm_add_sources_by_file_name(const char *file_name)
Add the scanner sources from csv file to fill fluid space.
Definition cs_porosity_from_scan.cpp:1023
void cs_porosity_from_scan_set_file_name(const char *file_name)
Set the file name of points for the computation of the porosity from scan.
Definition cs_porosity_from_scan.cpp:914
void cs_porous_model_restart_write(void)
Write the restart file of the ibm module.
Definition cs_porosity_from_scan.cpp:1361
void cs_porosity_from_scan_add_source(const cs_real_t source[3], bool transform)
Add a scanner source point.
Definition cs_porosity_from_scan.cpp:982
void cs_porous_model_restart_read(void)
Read the restart file of the ibm module.
Definition cs_porosity_from_scan.cpp:1397
void cs_compute_porosity_from_scan(void)
Compute the porosity which is equal to one from a source, radiating sphericaly, and is 0 when touchin...
Definition cs_porosity_from_scan.cpp:1089
Definition cs_porosity_from_scan.h:79
char ** headers
Definition cs_porosity_from_scan.h:84
bool compute_porosity_from_scan
Definition cs_porosity_from_scan.h:80
cs_real_34_t transformation_matrix
Definition cs_porosity_from_scan.h:91
bool postprocess_points
Definition cs_porosity_from_scan.h:86
int n_headers
Definition cs_porosity_from_scan.h:82
int * header_type
Definition cs_porosity_from_scan.h:83
char * output_name
Definition cs_porosity_from_scan.h:85
bool use_staircase
Definition cs_porosity_from_scan.h:98
cs_ibm_cog_location_t cog_location
Definition cs_porosity_from_scan.h:101
int nb_sources
Definition cs_porosity_from_scan.h:92
cs_real_t convection_porosity_threshold
Definition cs_porosity_from_scan.h:97
cs_real_t eigenvalue_criteria
Definition cs_porosity_from_scan.h:99
cs_lnum_t threshold
Definition cs_porosity_from_scan.h:95
char * file_names
Definition cs_porosity_from_scan.h:81
int use_restart
Definition cs_porosity_from_scan.h:100
cs_real_t porosity_threshold
Definition cs_porosity_from_scan.h:96
cs_lnum_t * source_c_ids
Definition cs_porosity_from_scan.h:94
cs_real_3_t * sources
Definition cs_porosity_from_scan.h:93
