cs_resource.h
1#ifndef __CS_RESOURCE_H__
2#define __CS_RESOURCE_H__
5 * Resource allocation management (available time).
30#include "base/cs_defs.h"
33 * Standard C library headers
37 * Local headers
38 *----------------------------------------------------------------------------*/
40#include "base/cs_base.h"
42/*----------------------------------------------------------------------------*/
45
46/*=============================================================================
47 * Macro Definitions
49
50/*=============================================================================
51 * Type Definitions
53
54/*============================================================================
55 * Global variables
57
58/*============================================================================
59 * Public function prototypes
60 *============================================================================*/
61
62/*----------------------------------------------------------------------------*/
68/*----------------------------------------------------------------------------*/
69
70double
72
73/*----------------------------------------------------------------------------*/
79/*----------------------------------------------------------------------------*/
80
81void
83
84/*----------------------------------------------------------------------------*/
92/*----------------------------------------------------------------------------*/
93
94void
96 int *ts_max);
97
98/*----------------------------------------------------------------------------*/
99
101
102#endif /* __CS_RESOURCE_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
void cs_resource_set_wt_limit(double wt)
Set wall-clock time limit.
Definition cs_resource.cpp:233
double cs_resource_get_wt_limit(void)
Get current wall-clock time limit.
Definition cs_resource.cpp:219
void cs_resource_get_max_timestep(int ts_cur, int *ts_max)
Limit number of remaining time steps if the remaining allocated time is too small to attain the reque...
Definition cs_resource.cpp:249
