| int | cs_time_table_column_id_by_name (const cs_time_table_t *table, const char *name) |
| Get column id corresponding to a given header/label. | |
| cs_time_table_t * | cs_time_table_by_name_try (const char *name) |
| Try to get time table based on name. | |
| cs_time_table_t * | cs_time_table_by_name (const char *name) |
| Get time table based on name. | |
| void | cs_time_table_set_offset (cs_time_table_t *table, cs_real_t time_offset) |
| Set time offset value for a time table. | |
| void | cs_time_table_set_headers (cs_time_table_t *table, const int n_headers, const char **headers) |
| Set headers labels for a time table. Number of headers needs to be equal to the number of columns, otherwise an error is raised. | |
| cs_time_table_t * | cs_time_table_from_csv_file (const char *name, const char *file_name, const char *separator, const int n_headers, const int n_columns, const int *col_idx, const bool ignore_missing_tokens) |
| Define a time table from a CSV file. | |
| cs_time_table_t * | cs_time_table_from_csv_file_simple (const char *name, const char *file_name, const char *separator) |
| Define a time table from a CSV file. We suppose that all columns are to be read, no headers line to skip and that missing tokens are to be ignored. | |
| cs_time_table_t * | cs_time_table_from_csv_file_simple_headers (const char *name, const char *file_name, const char *separator, const int n_headers) |
| Define a time table from a CSV file. We suppose that all columns are to be read and that missing tokens are to be ignored. | |
| void | cs_time_table_set_time_col_id (cs_time_table_t *table, const int col_id) |
| Define the column id for time based on an index. | |
| void | cs_time_table_set_time_from_label (cs_time_table_t *table, const char *time_label) |
| Define the column id for time based on a label. | |
| void | cs_time_table_reset_position (cs_time_table_t *table) |
| Reset time table time value (force search from beginning of table). | |
| void | cs_time_table_update_position (cs_time_table_t *table, cs_real_t time, bool reset_time_value) |
| Update time coefficients used for data interpolation. | |
| cs_real_t | cs_time_table_compute_time_value (const char *name, cs_real_t t, const int col, bool overwrite_prev) |
| Compute value using a given abscissa and a specific column. | |
| cs_real_t | cs_time_table_compute_time_value_by_label (const char *name, cs_real_t t, const char *label, bool overwrite_prev) |
| Compute value using a given abscissa and a label. | |
| void | cs_time_table_compute_n_time_values (const char *name, cs_real_t t, const int n_cols, const int cols[], bool overwrite_prev, cs_real_t *retvals) |
| Compute values for several columns of a time table for a given abscissa. | |
| void | cs_time_table_compute_n_time_values_by_label (const char *name, cs_real_t t, const int n_cols, const char *labels[], bool overwrite_prev, cs_real_t *retvals) |
| static cs_real_t | CS_TIME_TABLE (const char *name, const char *label) |
| Compute value from time table based on label and current time. Positions are not updated for the table. | |
| int | cs_time_table_get_n_rows (const char *name) |
| Extract n_rows from cs_time_table_t structure. | |
| int | cs_time_table_get_n_cols (const char *name) |
| Extract n_cols from cs_time_table_t structure. | |
| const cs_real_t ** | cs_time_table_get_data (const char *name) |
| Return pointer to table data. | |
| void | cs_time_table_destroy_all (void) |
| Free all data structures related to datasets. | |
inlinestatic |
| [in] | name | Name of the used time table |
| [in] | label | Label of column used for computation |
| cs_time_table_t * cs_time_table_by_name | ( | const char * | name | ) |
| [in] | name | Name of time table |
| cs_time_table_t * cs_time_table_by_name_try | ( | const char * | name | ) |
| int cs_time_table_column_id_by_name | ( | const cs_time_table_t * | table, |
| const char * | name ) |
| [in] | table | pointer to time table |
| [in] | name | name of the header/column |
| void cs_time_table_compute_n_time_values | ( | const char * | name, |
| cs_real_t | t, | ||
| const int | n_cols, | ||
| const int | cols[], | ||
| bool | overwrite_prev, | ||
| cs_real_t * | retvals ) |
| [in] | name | Name of the time table to use |
| [in] | t | Time for which we seek values |
| [in] | n_cols | Number of values to compute |
| [in] | cols | Array with the indices of columns for computation |
| [in] | overwrite_prev | Start search of value using first value |
| [out] | retvals | Array of output values |
| void cs_time_table_compute_n_time_values_by_label | ( | const char * | name, |
| cs_real_t | t, | ||
| const char * | labels[], | ||
| [in] | labels | Array with the labels of columns for computation |
| cs_real_t cs_time_table_compute_time_value | ( | const char * | name, |
| cs_real_t | t, | ||
| const int | col, | ||
| bool | overwrite_prev ) |
| [in] | col | Index of column used for computation |
| cs_real_t cs_time_table_compute_time_value_by_label | ( | const char * | name, |
| cs_real_t | t, | ||
| const char * | label, | ||
| void cs_time_table_destroy_all | ( | void | ) |
| cs_time_table_t * cs_time_table_from_csv_file | ( | const char * | name, |
| const char * | file_name, | ||
| const char * | separator, | ||
| const int | n_headers, | ||
| const int | n_columns, | ||
| const int * | col_idx, | ||
| const bool | ignore_missing_tokens ) |
| [in] | name | Name of the table to be created |
| [in] | file_name | Path to CSV file |
| [in] | separator | Separator used in the CSV file |
| [in] | n_headers | Number of header lines to be ignored during parsing |
| [in] | n_columns | Number of columns to read. -1 for all |
| [in] | col_idx | Array containing indexes of columns to read if n_columns != -1 |
| [in] | ignore_missing_tokens | Should we ignore missing tokens |
| cs_time_table_t * cs_time_table_from_csv_file_simple | ( | const char * | name, |
| const char * | separator ) |
| cs_time_table_t * cs_time_table_from_csv_file_simple_headers | ( | const char * | name, |
| const int | n_headers ) |
| const cs_real_t ** cs_time_table_get_data | ( | const char * | name | ) |
| int cs_time_table_get_n_cols | ( | const char * | name | ) |
| int cs_time_table_get_n_rows | ( | const char * | name | ) |
| void cs_time_table_reset_position | ( | cs_time_table_t * | table | ) |
| [in] | table | Pointer to time table structure |
| void cs_time_table_set_headers | ( | cs_time_table_t * | table, |
| const char ** | headers ) |
| [in] | n_headers | Number of headers to define |
| [in] | headers | Array of headers strings |
| void cs_time_table_set_offset | ( | cs_time_table_t * | table, |
| cs_real_t | time_offset ) |
| [in] | time_offset | Value of time offset for the table. |
| void cs_time_table_set_time_col_id | ( | cs_time_table_t * | table, |
| const int | col_id ) |
| [in] | col_id | Index of column which is to be used as time |
| void cs_time_table_set_time_from_label | ( | cs_time_table_t * | table, |
| const char * | time_label ) |
| [in] | time_label | Label to identify index of column which is to be used as time |
| [in] | time_label | Label to identify index of column used as time |
