typedef struct _cs_sat_coupling_t | cs_sat_coupling_t |
typedef void | cs_sat_coupling_tag_t(void *context, fvm_nodal_t *mesh, cs_lnum_t n_points, cs_lnum_t point_list_base, const cs_lnum_t point_list[], int *point_tag) |
void | cs_sat_coupling_define (const char *saturne_name, const char *boundary_cpl_criteria, const char *volume_cpl_criteria, const char *boundary_loc_criteria, const char *volume_loc_criteria, int reverse, int verbosity) |
Define new code_saturne coupling. | |
int | cs_sat_coupling_n_couplings (void) |
cs_sat_coupling_t * | cs_sat_coupling_by_id (int coupling_id) |
void | cs_sat_coupling_add (const char *face_cpl_sel_c, const char *cell_cpl_sel_c, const char *face_loc_sel_c, const char *cell_loc_sel_c, const char *sat_name, int reverse, int verbosity) |
void | cs_sat_coupling_add_internal (cs_sat_coupling_tag_t *tag_func, void *tag_context, const char *boundary_cpl_criteria, const char *volume_cpl_criteria, const char *boundary_loc_criteria, const char *volume_loc_criteria, float loc_tolerance, int reverse, int verbosity) |
void | cs_sat_coupling_all_init (void) |
void | cs_sat_coupling_array_exchange (int cpl_id, cs_lnum_t nbrdis, cs_lnum_t nbrloc, cs_real_t *vardis, cs_real_t *varloc) |
void | cs_sat_coupling_exchange_at_cells (cs_field_t *f, cs_real_t *rhs, cs_real_t *fimp) |
code_saturne/code_saturne coupling using volumic source terms. | |
void | cs_sat_coupling_bnd_initialize (int *bc_type) |
code_saturne/code_saturne boundary coupling initialization call | |
void | cs_sat_coupling_initialize (void) |
Initialization of main variables for code_saturne/code_saturne coupling. | |
void | cs_sat_coupling_locate_all (void) |
Set the list of cells and boundary faces associated to a coupling and a cloud of point. | |
void | cs_sat_coupling_exchange_at_bnd_faces (int *bc_type, cs_real_t *dt) |
code_saturne/code_saturne coupling using boundary conditions | |
void | cs_sat_coupling_all_finalize (void) |
int | cs_glob_sat_coupling_face_interpolation_type |
typedef struct _cs_sat_coupling_t cs_sat_coupling_t |
typedef void cs_sat_coupling_tag_t(void *context, fvm_nodal_t *mesh, cs_lnum_t n_points, cs_lnum_t point_list_base, const cs_lnum_t point_list[], int *point_tag) |
void cs_sat_coupling_add | ( | const char * | face_cpl_sel_c, |
const char * | cell_cpl_sel_c, | ||
const char * | face_loc_sel_c, | ||
const char * | cell_loc_sel_c, | ||
const char * | sat_name, | ||
int | reverse, | ||
int | verbosity ) |
void cs_sat_coupling_add_internal | ( | cs_sat_coupling_tag_t * | tag_func, |
void * | tag_context, | ||
const char * | boundary_cpl_criteria, | ||
const char * | volume_cpl_criteria, | ||
const char * | boundary_loc_criteria, | ||
const char * | volume_loc_criteria, | ||
float | loc_tolerance, | ||
int | reverse, | ||
int | verbosity ) |
void cs_sat_coupling_all_finalize | ( | void | ) |
void cs_sat_coupling_all_init | ( | void | ) |
void cs_sat_coupling_array_exchange | ( | int | cpl_id, |
cs_lnum_t | nbrdis, | ||
cs_lnum_t | nbrloc, | ||
cs_real_t * | vardis, | ||
cs_real_t * | varloc ) |
void cs_sat_coupling_bnd_initialize | ( | int * | bc_type | ) |
[in] | bc_type | boundary face types |
cs_sat_coupling_t * cs_sat_coupling_by_id | ( | int | coupling_id | ) |
void cs_sat_coupling_define | ( | const char * | saturne_name, |
int | reverse, | ||
int | verbosity ) |
The arguments to cs_sat_coupling_define are:
[in] | saturne_name | matching code_saturne application name |
[in] | boundary_cpl_criteria | boundary face selection criteria for coupled faces, or NULL |
[in] | volume_cpl_criteria | cell selection criteria for coupled cells, or NULL |
[in] | boundary_loc_criteria | boundary face selection criteria for location (not functional) |
[in] | volume_loc_criteria | cell selection criteria for location |
[in] | reverse | reverse mode if 1 |
[in] | verbosity | verbosity level |
In the case of only 2 code_saturne instances, the 'saturne_name' argument is ignored, as there is only one matching possibility.
In case of multiple couplings, a coupling will be matched with available code_saturne instances based on the 'saturne_name' argument.
[in] | boundary_cpl_criteria | boundary face selection criteria for coupled faces, or nullptr |
[in] | volume_cpl_criteria | cell selection criteria for coupled cells, or nullptr |
void cs_sat_coupling_exchange_at_bnd_faces | ( | int * | bc_type, |
cs_real_t * | dt ) |
[in] | dt | time step (per cell) |
void cs_sat_coupling_exchange_at_cells | ( | cs_field_t * | f, |
cs_real_t * | rhs, | ||
cs_real_t * | fimp ) |
[in] | f | pointer to cs_field_t |
[out] | rhs | Explicit terms (RHS) |
[out] | fimp | Implicit source terms |
void cs_sat_coupling_initialize | ( | void | ) |
void cs_sat_coupling_locate_all | ( | void | ) |
The local "support" cells and boundary faces are used to locate the values in the distant "coupled" cells and faces. Depending on the role of sender and/or receiver of the current process in the coupling, some of these sets can be empty or not.
The cell values are always located and interpolated on the distant "cells" support. The face values are located and interpolated on the distant "face" support if present, or on the distant "cell" support if not.
If the input arrays LCESUP and LFBSUP are not ordered, they will be orderd in output.
int cs_sat_coupling_n_couplings | ( | void | ) |
extern |
