Various field initializations. More...
#include "base/cs_defs.h"#include <assert.h>#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_mem.h"#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_ale.h"#include "base/cs_array.h"#include "base/cs_array_reduce.h"#include "base/cs_assert.h"#include "cfbl/cs_cf_model.h"#include "cfbl/cs_cf_thermo.h"#include "comb/cs_coal_initialize.h"#include "ctwr/cs_ctwr_initialize.h"#include "base/cs_dispatch.h"#include "elec/cs_elec_model.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "base/cs_gas_mix.h"#include "gui/cs_gui.h"#include "gui/cs_gui_mobile_mesh.h"#include "base/cs_ibm.h"#include "base/cs_math.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parameters.h"#include "base/cs_parameters_check.h"#include "base/cs_parall.h"#include "base/cs_physical_constants.h"#include "pprt/cs_physical_model.h"#include "base/cs_porous_model.h"#include "base/cs_porosity_from_scan.h"#include "base/cs_prototypes.h"#include "base/cs_scalar_clipping.h"#include "base/cs_solve_navier_stokes.h"#include "base/cs_time_step.h"#include "turb/cs_turbulence_init.h"#include "base/cs_velocity_pressure.h"#include "base/cs_vof.h"#include "base/cs_initialize_fields.h"Functions | |
| void | cs_f_ppiniv0 (void) |
| void | cs_f_d3pini1 (void) |
| void | cs_f_user_initialization_wrapper (cs_real_t dt[]) |
| void | cs_initialize_fields_stage_0 (void) |
| Computed variable and property initialization. | |
| void | cs_initialize_fields_stage_1 (void) |
| Initialize variable, time step, and wall distance fields. | |
| void cs_f_d3pini1 | ( | void | ) |
| void cs_f_ppiniv0 | ( | void | ) |
| void cs_f_user_initialization_wrapper | ( | cs_real_t | dt[] | ) |
| void cs_initialize_fields_stage_0 | ( | void | ) |
The time step, the indicator of wall distance computation are also initialized just before reading a restart file or use the user initializations.
| void cs_initialize_fields_stage_1 | ( | void | ) |
