1#ifndef __CS_CF_THERMO_H__
2#define __CS_CF_THERMO_H__
111 tmp1 = energ - Q - vol*Pinf;
114 if (tmp1 >
eps) s += CV*log(tmp1);
115 if (tmp2 >
eps) s += CV*(
gamma-1.)*log(tmp2);
198 e = Q + CV*T*(P+
gamma*Pinf) / tmp;
224 tau = (
gamma-1.)*CV*T / tmp;
253 - CV*(
gamma-1.)*log(tmp) + Qprim;
282 tmp1 = pow(v, 1.-
gamma);
284 tmp2 = exp((s - Qprim) / CV);
285 e = Q + v * Pinf + tmp1*tmp2;
318 for (
cs_lnum_t ii = 0; ii < l_size; ii++) {
322 _(
"Error in thermodynamics computations for "
323 "compressible flows:\n"
324 "Value of gamma smaller to 1. encountered.\n"
325 "Gamma (specific heat ratio) must be a real number "
326 "greater or equal to 1.\n"));
331 for (
Definition bft_error.cpp:193
const cs_cf_model_t * cs_glob_cf_model
@ CS_EOS_STIFFENED_GAS
Definition cs_cf_model.h:75
@ CS_EOS_IDEAL_GAS
Definition cs_cf_model.h:74
@ CS_EOS_GAS_MIX
Definition cs_cf_model.h:76
void cs_cf_thermo_wall_bc(cs_real_t *wbfa, cs_real_t *wbfb, cs_lnum_t face_id)
Compute wall boundary condition values.
Definition cs_cf_thermo.cpp:936
void cs_cf_thermo_dt_from_pe(cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *ener, cs_real_t *dens, cs_real_t *temp, cs_real_3_t *vel, cs_lnum_t l_size)
Compute density and temperature from pressure and total energy;.
Definition cs_cf_thermo.cpp:478
void cs_cf_check_internal_energy(cs_real_t *ener, cs_lnum_t l_size, cs_real_3_t *vel)
Check the positivity of the internal energy.
Definition cs_cf_thermo.cpp:224
void cs_cf_thermo(const int iccfth, cs_lnum_t face_id, cs_real_t *bc_en, cs_real_t *bc_pr, cs_real_t *bc_tk, cs_real_3_t *bc_vel)
This function is a driver allowing to call the appropriate thermodynamical functions depending on the...
Definition cs_cf_thermo.cpp:1664
static cs_real_t cs_cf_thermo_temperature_sg_ve(cs_real_t vol, cs_real_t energ, cs_stiffened_gas_t sg)
Computation of the temperature.
Definition cs_cf_thermo.h:135
cs_real_t cs_cf_thermo_b_rho_from_pt(cs_lnum_t face_id, cs_real_t bc_pr, cs_real_t bc_tk)
Compute density at boundary based on pressure and temperature.
Definition cs_cf_thermo.cpp:1805
void cs_cf_thermo_eps_sup(const cs_real_t *dens, cs_real_t *eps_sup, cs_lnum_t l_size)
Compute epsilon sup:
Definition cs_cf_thermo.cpp:1583
void cs_cf_thermo_default_init(void)
Initialize density, total energy and isochoric specific heat according to the chosen thermodynamic la...
Definition cs_cf_thermo.cpp:121
void cs_cf_thermo_c_square(cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *dens, cs_real_t *fracv, cs_real_t *fracm, cs_real_t *frace, cs_real_t *c2, cs_lnum_t l_size)
Compute square of sound velocity:
Definition cs_cf_thermo.cpp:726
void cs_cf_thermo_s_from_dp(cs_real_t *cp, cs_real_t *cv, cs_real_t *dens, cs_real_t *pres, cs_real_t *entr, cs_lnum_t l_size)
Compute entropy from pressure and density:
Definition cs_cf_thermo.cpp:882
static cs_real_t cs_cf_thermo_internal_energy_sg_tp(cs_real_t T, cs_real_t P, cs_stiffened_gas_t sg)
Computation of internal energy in plane (T,P).
Definition cs_cf_thermo.h:187
static cs_real_t cs_cf_thermo_internal_energy_sg_sv(cs_real_t s, cs_real_t v, cs_stiffened_gas_t sg)
Computation of internal energy in plane (s,v).
Definition cs_cf_thermo.h:269
static cs_real_t cs_cf_thermo_entropy_sg_tp(cs_real_t T, cs_real_t P, cs_stiffened_gas_t sg)
Computation of entropy in plane (T,P).
Definition cs_cf_thermo.h:240
static cs_real_t cs_cf_thermo_pressure_sg_ve(cs_real_t vol, cs_real_t energ, cs_stiffened_gas_t sg)
Computation of the pressure.
Definition cs_cf_thermo.h:163
void cs_cf_thermo_cv(cs_real_t *cp, cs_real_t *xmasml, cs_real_t *cv, cs_lnum_t l_size)
Compute the isochoric specific heat:
Definition cs_cf_thermo.cpp:846
static void cs_cf_thermo_gamma(cs_real_t *cp, cs_real_t *cv, cs_real_t *gamma, cs_lnum_t l_size)
Compute .
Definition cs_cf_thermo.h:302
void cs_cf_thermo_de_from_pt(cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *temp, cs_real_t *dens, cs_real_t *ener, cs_real_3_t *vel, cs_lnum_t l_size)
Compute density and total energy from pressure and temperature.
Definition cs_cf_thermo.cpp:410
void cs_cf_check_pressure(cs_real_t *pres, cs_lnum_t l_size)
Check the positivity of the pressure.
Definition cs_cf_thermo.cpp:186
void cs_cf_thermo_beta(cs_real_t *cp, cs_real_t *cv, cs_real_t *dens, cs_real_t *beta, cs_lnum_t l_size)
Compute the thermal expansion coefficient:
Definition cs_cf_thermo.cpp:797
static cs_real_t cs_cf_thermo_specific_volume_sg_tp(cs_real_t T, cs_real_t P, cs_stiffened_gas_t sg)
Computation of specific volume in plane (T,P).
Definition cs_cf_thermo.h:214
void cs_cf_thermo_pt_from_de(cs_real_t *cp, cs_real_t *cv, cs_real_t *dens, cs_real_t *ener, cs_real_t *pres, cs_real_t *temp, cs_real_3_t *vel, cs_real_t *fracv, cs_real_t *fracm, cs_real_t *frace, cs_lnum_t l_size)
Compute pressure and temperature from density and total energy.
Definition cs_cf_thermo.cpp:623
void cs_cf_thermo_ph_inlet_bc(cs_real_t *bc_en, cs_real_t *bc_pr, cs_real_3_t *bc_vel, cs_lnum_t face_id)
Compute inlet boundary condition with total pressure and total enthalpy imposed.
Definition cs_cf_thermo.cpp:1274
void cs_cf_check_density(cs_real_t *dens, cs_lnum_t l_size)
Check the positivity of the density given by the user.
Definition cs_cf_thermo.cpp:264
void cs_cf_set_thermo_options(void)
Set variability of isobaric specific heat and isochoric specific heat according to the chosen thermod...
Definition cs_cf_thermo.cpp:96
void cs_cf_thermo_pe_from_dt(cs_real_t *cp, cs_real_t *cv, cs_real_t *dens, cs_real_t *temp, cs_real_t *pres, cs_real_t *ener, cs_real_3_t *vel, cs_lnum_t l_size)
Compute pressure and total energy from density and temperature.
Definition cs_cf_thermo.cpp:554
void cs_cf_thermo_te_from_dp(cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *dens, cs_real_t *temp, cs_real_t *ener, cs_real_3_t *vel, cs_lnum_t l_size)
Compute temperature and total energy from density and pressure.
Definition cs_cf_thermo.cpp:340
void cs_cf_check_temperature(cs_real_t *temp, cs_lnum_t l_size)
Check strict positivity of temperature (Celsius) given by the user.
Definition cs_cf_thermo.cpp:299
static cs_real_t cs_cf_thermo_entropy_sg_ve(cs_real_t vol, cs_real_t energ, cs_stiffened_gas_t sg)
Computation of entropy in plane (v,e) with a stiffened gas law.
Definition cs_cf_thermo.h:99
void cs_cf_thermo_subsonic_outlet_bc(cs_real_t *bc_en, cs_real_t *bc_pr, cs_real_3_t *bc_vel, cs_lnum_t face_id)
Compute subsonic outlet boundary conditions values.
Definition cs_cf_thermo.cpp:1036
Definition cs_defs.h:542
#define _(String)
Definition cs_defs.h:67
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
@ gamma
Definition cs_field_pointer.h:200
@ eps
Definition cs_field_pointer.h:73
@ cv
Definition cs_field_pointer.h:103
@ vel
Definition cs_field_pointer.h:70
@ cp
Definition cs_field_pointer.h:102
Definition cs_cf_thermo.h:54
cs_real_t cv
Definition cs_cf_thermo.h:56
cs_real_t q
Definition cs_cf_thermo.h:60
cs_real_t qprim
Definition cs_cf_thermo.h:59
cs_real_t gamma
Definition cs_cf_thermo.h:57
cs_real_t pinf
Definition cs_cf_thermo.h:58
