cs_search.h
1#ifndef __CS_SEARCH_H__
2#define __CS_SEARCH_H__
5 * Search elements in arrays
6 *===========================================================================*/
30#include "base/cs_defs.h"
33 * Local headers
34 *---------------------------------------------------------------------------*/
36#include "base/cs_base.h"
38/*---------------------------------------------------------------------------*/
43 * Macro and type definitions
44 *===========================================================================*/
45
47 * Public function prototypes
48 *===========================================================================*/
49
50/*----------------------------------------------------------------------------
51 * Get the position inside an array related to a value thanks to a binary
52 * search. Array or list must be ordered.
53 *
54 * parameters:
55 * size <-- size of list
56 * gnum <-- find index for this number
57 * lst <-- list of ordered global numbers to scan
58 *
59 * returns:
60 * id associated to the current number. If not found, returned -1.
61 *---------------------------------------------------------------------------*/
62
63int
64cs_search_g_binary(size_t size,
65 cs_gnum_t gnum,
66 const cs_gnum_t lst[]);
67
68/*----------------------------------------------------------------------------
69 * Get the position inside an array related to a value thanks to a binary
70 * search (binary search). Array or list must be ordered.
71 *
72 * parameters:
73 * size <-- size of list
74 * num <-- find index for this number
75 * lst <-- list of ordered numbers to scan
76 *
77 * returns:
78 * id associated to the current number. If not found, return -1.
79 *---------------------------------------------------------------------------*/
80
81int
82cs_search_binary(size_t size,
83 cs_lnum_t num,
84 const cs_lnum_t lst[]);
85
86/*----------------------------------------------------------------------------
87 * Get the position inside an array related to a value thanks to a binary
88 * search (binary search). Index must be ordered and without null range.
89 *
90 * parameters:
91 * size <-- size of index -1
92 * gnum <-- number for which we want the position in index
93 * index <-- index array
94 *
95 * returns:
96 * id in index of gnum. If not found, returned -1.
97 *---------------------------------------------------------------------------*/
98
99int
100cs_search_gindex_binary(size_t size,
101 cs_gnum_t gnum,
102 const cs_gnum_t index[]);
103
104/*---------------------------------------------------------------------------*/
105
107
108#endif /* __CS_SEARCH_H__ */
Definition cs_defs.h:542
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
Definition cs_defs.h:335
int cs_search_g_binary(size_t size, cs_gnum_t gnum, const cs_gnum_t lst[])
Definition cs_search.cpp:206
int cs_search_binary(size_t size, cs_lnum_t num, const cs_lnum_t lst[])
Definition cs_search.cpp:227
int cs_search_gindex_binary(size_t size, cs_gnum_t gnum, const cs_gnum_t index[])
Definition cs_search.cpp:249
