#include "base/cs_defs.h"#include <assert.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_error.h"#include "base/cs_array.h"#include "base/cs_base.h"#include "cdo/cs_equation_param.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parall.h"#include "base/cs_time_step.h"#include "base/cs_volume_mass_injection.h"Functions | |
| void | cs_volume_mass_injection_flag_zones (void) |
| Flag volume zones with the appropriate CS_VOLUME_ZONE_MASS_SOURCE_TERM flag when at least one volume mass injection on that zone is present. | |
| void | cs_volume_mass_injection_build_lists (void) |
| Build the list and zone ids of cells with volume mass injection. | |
| void | cs_volume_mass_injection_eval (void) |
| Evaluate contributions to volume mass injection. | |
| void | cs_volume_mass_injection_get_arrays (const cs_field_t *f, cs_lnum_t *n_elts, const cs_lnum_t **elt_ids, int **mst_type, cs_real_t **mst_val, cs_real_t **gamma) |
| Return pointers to the mass source term arrays. | |
Volume mass injection and associated source terms computation.
| void cs_volume_mass_injection_build_lists | ( | void | ) |
| void cs_volume_mass_injection_eval | ( | void | ) |
| void cs_volume_mass_injection_flag_zones | ( | void | ) |
This is necessary for the reverse zone indexing required by the legacy code to function with defintions that are partially unrolled an not purely zone-based.
| void cs_volume_mass_injection_get_arrays | ( | const cs_field_t * | f, |
| cs_lnum_t * | n_elts, | ||
| const cs_lnum_t ** | elt_ids, | ||
| int ** | mst_type, | ||
| cs_real_t ** | mst_val, | ||
| cs_real_t ** | gamma ) |
| [in] | f | pointer to associated field |
| [out] | n_elts | number of cells with mass source terms |
| [out] | elt_ids | pointer to source mass cells list (1-based numbering)//FIXME |
| [out] | mst_type | mass source types (0: ambient value, 1: s_val value) |
| [out] | mst_val | pointer to mass source values |
| [out] | gamma | pointer to flow mass value |
