cs_renumber.h
1#ifndef __CS_RENUMBER_H__
2#define __CS_RENUMBER_H__
5 * Optional mesh renumbering
31 * Local headers
34#include "base/cs_base.h"
35#include "mesh/cs_mesh.h"
36
37/*----------------------------------------------------------------------------*/
38
41/*============================================================================
42 * Macro definitions
43 *============================================================================*/
45/*============================================================================
46 * Type definitions
48
49/* Renumbering algorithms */
50
51typedef enum {
52
53 CS_RENUMBER_CELLS_SCOTCH_PART, /* SCOTCH partitioning */
54 CS_RENUMBER_CELLS_SCOTCH_ORDER, /* SCOTCH ordering */
55 CS_RENUMBER_CELLS_METIS_PART, /* METIS partitioning */
56 CS_RENUMBER_CELLS_METIS_ORDER, /* METIS ordering */
57 CS_RENUMBER_CELLS_MORTON, /* Morton space filling curve */
58 CS_RENUMBER_CELLS_HILBERT, /* Hilbert space filling curve */
59 CS_RENUMBER_CELLS_RCM, /* Reverse Cuthill-McKee */
60 CS_RENUMBER_CELLS_NONE /* No cells renumbering */
61
63
64typedef enum {
65
66 CS_RENUMBER_I_FACES_BLOCK, /* No shared cell in block */
67 CS_RENUMBER_I_FACES_MULTIPASS, /* Use multipass face numbering */
68 CS_RENUMBER_I_FACES_SIMD, /* Renumber for vector (SIMD) operations */
69 CS_RENUMBER_I_FACES_NONE /* No interior face numbering */
70
72
73typedef enum {
74
75 CS_RENUMBER_B_FACES_THREAD, /* No cell shared between threads */
76 CS_RENUMBER_B_FACES_SIMD, /* Renumber for vector (SIMD) operations */
77 CS_RENUMBER_B_FACES_NONE /* No boundary face numbering */
78
80
81typedef enum {
82
83 CS_RENUMBER_VERTICES_BY_CELL_ADJ, /* Renumbering based on cell adjacency */
84 CS_RENUMBER_VERTICES_BY_FACE_ADJ, /* Renumbering based on face adjacency */
85 CS_RENUMBER_VERTICES_NONE /* No vertex numbering */
86
88
89/* Ordering options for adjacency arrays */
90
91typedef enum {
92
93 CS_RENUMBER_ADJACENT_LOW, /* Lowest adjacent id first */
94 CS_RENUMBER_ADJACENT_HIGH /* Highest adjacent id first */
95
97
98/*=============================================================================
99 * Public function prototypes
100 *============================================================================*/
101
102/*----------------------------------------------------------------------------
103 * Set the target number of threads for mesh renumbering.
104 *
105 * By default, the target number of threads is set to cs_glob_n_threads,
106 * but the value may be forced using this function. This is mainly useful
107 * for testing purposes.
108 *
109 * parameters:
110 * n_threads <-- target number of threads for mesh numbering
111 *----------------------------------------------------------------------------*/
112
113void
114cs_renumber_set_n_threads(int n_threads);
115
116/*----------------------------------------------------------------------------
117 * Return the target number of threads for mesh renumbering.
118 *
119 * returns:
120 * the target number of threads for mesh numbering
121 *----------------------------------------------------------------------------*/
122
123int
125
126/*----------------------------------------------------------------------------
127 * Set the minimum sunset sizes when renumbering for threads.
128 *
129 * parameters:
130 * min_i_subset_size <-- minimum number of interior faces per
131 * thread per group
132 * min_b_subset_size <-- minimum number of boundary faces per
133 * thread per group
134 *----------------------------------------------------------------------------*/
135
136void
138 cs_lnum_t min_b_subset_size);
139
140/*----------------------------------------------------------------------------
141 * Get the minimum sunset sizes when renumbering for threads.
142 *
143 * min_i_subset_size --> minimum number of interior faces per
144 * thread per group, or NULL
145 * min_b_subset_size --> minimum number of boundary faces per
146 * thread per group, or NULL
147 *----------------------------------------------------------------------------*/
148
149void
151 cs_lnum_t *min_b_subset_size);
152
153/*----------------------------------------------------------------------------*/
171/*----------------------------------------------------------------------------*/
172
173void
174cs_renumber_set_algorithm(bool halo_adjacent_cells_last,
175 bool halo_adjacent_faces_last,
176 cs_renumber_ordering_t i_faces_base_ordering,
177 cs_renumber_cells_type_t cells_pre_numbering,
178 cs_renumber_cells_type_t cells_numbering,
179 cs_renumber_i_faces_type_t i_faces_numbering,
180 cs_renumber_b_faces_type_t b_faces_numbering,
181 cs_renumber_vertices_type_t vertices_numbering);
182
183/*----------------------------------------------------------------------------*/
203/*----------------------------------------------------------------------------*/
204
205void
206cs_renumber_get_algorithm(bool *halo_adjacent_cells_last,
207 bool *halo_adjacent_faces_last,
208 cs_renumber_ordering_t *i_faces_base_ordering,
209 cs_renumber_cells_type_t *cells_pre_numbering,
210 cs_renumber_cells_type_t *cells_numbering,
211 cs_renumber_i_faces_type_t *i_faces_numbering,
212 cs_renumber_b_faces_type_t *b_faces_numbering,
213 cs_renumber_vertices_type_t *vertices_numbering);
214
215/*----------------------------------------------------------------------------
216 * Renumber mesh elements for vectorization or threading depending on code
217 * options and target machine.
218 *
219 * Renumbering cells may also allow improving locality (and favor faces
220 * renumbering).
221 * It is also possible to place cells connected to ghost cells last,
222 * which may be useful to enable computation/communication overlap.
223 *
224 * parameters:
225 * mesh <-> pointer to global mesh structure
226 *----------------------------------------------------------------------------*/
227
228void
230
231/*----------------------------------------------------------------------------*/
240/*----------------------------------------------------------------------------*/
241
242void
244
245/*----------------------------------------------------------------------------
246 * Renumber interior faces for vectorization or threading depending on code
247 * options and target machine.
248 *
249 * parameters:
250 * mesh <-> pointer to global mesh structure
251 *----------------------------------------------------------------------------*/
252
253void
255
256/*----------------------------------------------------------------------------
257 * Renumber interior faces by global number.
258 *
259 * This effectively resets the interior faces to their initial numbering.
260 *
261 * parameters:
262 * mesh <-> pointer to global mesh structure
263 *----------------------------------------------------------------------------*/
264
265void
267
268/*----------------------------------------------------------------------------
269 * Renumber boundary faces for vectorization or threading depending on code
270 * options and target machine.
271 *
272 * parameters:
273 * mesh <-> pointer to global mesh structure
274 *----------------------------------------------------------------------------*/
275
276void
278
279/*----------------------------------------------------------------------------
280 * Renumber boundary faces by global number.
281 *
282 * This effectively resets the boundary faces to their initial numbering.
283 *
284 * parameters:
285 * mesh <-> pointer to global mesh structure
286 *----------------------------------------------------------------------------*/
287
288void
290
291/*----------------------------------------------------------------------------*/
304/*----------------------------------------------------------------------------*/
305
306void
308 cs_lnum_t n_faces,
309 const cs_lnum_t face_ids[]);
310
311/*----------------------------------------------------------------------------*/
320/*----------------------------------------------------------------------------*/
321
322void
324
325/*----------------------------------------------------------------------------*/
326
328
329#endif /* __CS_RENUMBER_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
Definition cs_defs.h:335
void cs_renumber_mesh(cs_mesh_t *mesh)
Renumber mesh elements for vectorization or threading depending on code options and target machine.
Definition cs_renumber.cpp:5890
void cs_renumber_get_min_subset_size(cs_lnum_t *min_i_subset_size, cs_lnum_t *min_b_subset_size)
Definition cs_renumber.cpp:5771
void cs_renumber_set_n_threads(int n_threads)
Definition cs_renumber.cpp:5711
void cs_renumber_b_faces(cs_mesh_t *mesh)
Renumber boundary faces for vectorization or threading depending on code options and target machine.
Definition cs_renumber.cpp:6057
Definition cs_renumber.h:64
@ CS_RENUMBER_I_FACES_BLOCK
Definition cs_renumber.h:66
@ CS_RENUMBER_I_FACES_SIMD
Definition cs_renumber.h:68
@ CS_RENUMBER_I_FACES_NONE
Definition cs_renumber.h:69
@ CS_RENUMBER_I_FACES_MULTIPASS
Definition cs_renumber.h:67
void cs_renumber_set_algorithm(bool halo_adjacent_cells_last, bool halo_adjacent_faces_last, cs_renumber_ordering_t i_faces_base_ordering, cs_renumber_cells_type_t cells_pre_numbering, cs_renumber_cells_type_t cells_numbering, cs_renumber_i_faces_type_t i_faces_numbering, cs_renumber_b_faces_type_t b_faces_numbering, cs_renumber_vertices_type_t vertices_numbering)
Select the algorithm for mesh renumbering.
Definition cs_renumber.cpp:5801
void cs_renumber_b_faces_select_ignore(cs_mesh_t *mesh, cs_lnum_t n_faces, const cs_lnum_t face_ids[])
Renumber boundary faces such that selected faces appear last and will be ignored.
Definition cs_renumber.cpp:6143
void cs_renumber_i_faces_by_gnum(cs_mesh_t *mesh)
Definition cs_renumber.cpp:6021
Definition cs_renumber.h:91
@ CS_RENUMBER_ADJACENT_HIGH
Definition cs_renumber.h:94
@ CS_RENUMBER_ADJACENT_LOW
Definition cs_renumber.h:93
Definition cs_renumber.h:51
@ CS_RENUMBER_CELLS_SCOTCH_ORDER
Definition cs_renumber.h:54
@ CS_RENUMBER_CELLS_SCOTCH_PART
Definition cs_renumber.h:53
@ CS_RENUMBER_CELLS_METIS_PART
Definition cs_renumber.h:55
@ CS_RENUMBER_CELLS_HILBERT
Definition cs_renumber.h:58
@ CS_RENUMBER_CELLS_METIS_ORDER
Definition cs_renumber.h:56
@ CS_RENUMBER_CELLS_RCM
Definition cs_renumber.h:59
@ CS_RENUMBER_CELLS_NONE
Definition cs_renumber.h:60
@ CS_RENUMBER_CELLS_MORTON
Definition cs_renumber.h:57
Definition cs_renumber.h:81
@ CS_RENUMBER_VERTICES_NONE
Definition cs_renumber.h:85
@ CS_RENUMBER_VERTICES_BY_FACE_ADJ
Definition cs_renumber.h:84
@ CS_RENUMBER_VERTICES_BY_CELL_ADJ
Definition cs_renumber.h:83
Definition cs_renumber.h:73
@ CS_RENUMBER_B_FACES_NONE
Definition cs_renumber.h:77
@ CS_RENUMBER_B_FACES_SIMD
Definition cs_renumber.h:76
@ CS_RENUMBER_B_FACES_THREAD
Definition cs_renumber.h:75
void cs_renumber_b_faces_by_gnum(cs_mesh_t *mesh)
Definition cs_renumber.cpp:6103
void cs_renumber_cells(cs_mesh_t *mesh)
Renumber cells depending on code options and target machine.
Definition cs_renumber.cpp:5925
void cs_renumber_get_algorithm(bool *halo_adjacent_cells_last, bool *halo_adjacent_faces_last, cs_renumber_ordering_t *i_faces_base_ordering, cs_renumber_cells_type_t *cells_pre_numbering, cs_renumber_cells_type_t *cells_numbering, cs_renumber_i_faces_type_t *i_faces_numbering, cs_renumber_b_faces_type_t *b_faces_numbering, cs_renumber_vertices_type_t *vertices_numbering)
Return the algorithms for mesh renumbering.
Definition cs_renumber.cpp:5844
void cs_renumber_set_min_subset_size(cs_lnum_t min_i_subset_size, cs_lnum_t min_b_subset_size)
Definition cs_renumber.cpp:5752
int cs_renumber_get_n_threads(void)
Definition cs_renumber.cpp:5732
void cs_renumber_vertices(cs_mesh_t *mesh)
Renumber vertices depending on code options and target machine.
Definition cs_renumber.cpp:6293
void cs_renumber_i_faces(cs_mesh_t *mesh)
Renumber interior faces for vectorization or threading depending on code options and target machine.
Definition cs_renumber.cpp:5975
Definition mesh.f90:26
Definition cs_mesh.h:85
