cs_renumber.h File Reference
#include "base/cs_base.h"
#include "mesh/cs_mesh.h"
Include dependency graph for cs_renumber.h:
Enumerations
enum  cs_renumber_cells_type_t {
  CS_RENUMBER_CELLS_SCOTCH_PART , CS_RENUMBER_CELLS_SCOTCH_ORDER , CS_RENUMBER_CELLS_METIS_PART , CS_RENUMBER_CELLS_METIS_ORDER ,
  CS_RENUMBER_CELLS_MORTON , CS_RENUMBER_CELLS_HILBERT , CS_RENUMBER_CELLS_RCM , CS_RENUMBER_CELLS_NONE
enum  cs_renumber_i_faces_type_t { CS_RENUMBER_I_FACES_BLOCK , CS_RENUMBER_I_FACES_MULTIPASS , CS_RENUMBER_I_FACES_SIMD , CS_RENUMBER_I_FACES_NONE }
enum  cs_renumber_b_faces_type_t { CS_RENUMBER_B_FACES_THREAD , CS_RENUMBER_B_FACES_SIMD , CS_RENUMBER_B_FACES_NONE }
enum  cs_renumber_vertices_type_t { CS_RENUMBER_VERTICES_BY_CELL_ADJ , CS_RENUMBER_VERTICES_BY_FACE_ADJ , CS_RENUMBER_VERTICES_NONE }
enum  cs_renumber_ordering_t { CS_RENUMBER_ADJACENT_LOW , CS_RENUMBER_ADJACENT_HIGH }
void cs_renumber_set_n_threads (int n_threads)
 Set the target number of threads for mesh renumbering.
int cs_renumber_get_n_threads (void)
 Return the target number of threads for mesh renumbering.
void cs_renumber_set_min_subset_size (cs_lnum_t min_i_subset_size, cs_lnum_t min_b_subset_size)
 Set the minimum sunset sizes when renumbering for threads.
void cs_renumber_get_min_subset_size (cs_lnum_t *min_i_subset_size, cs_lnum_t *min_b_subset_size)
 Get the minimum sunset sizes when renumbering for threads.
void cs_renumber_set_algorithm (bool halo_adjacent_cells_last, bool halo_adjacent_faces_last, cs_renumber_ordering_t i_faces_base_ordering, cs_renumber_cells_type_t cells_pre_numbering, cs_renumber_cells_type_t cells_numbering, cs_renumber_i_faces_type_t i_faces_numbering, cs_renumber_b_faces_type_t b_faces_numbering, cs_renumber_vertices_type_t vertices_numbering)
 Select the algorithm for mesh renumbering.
void cs_renumber_get_algorithm (bool *halo_adjacent_cells_last, bool *halo_adjacent_faces_last, cs_renumber_ordering_t *i_faces_base_ordering, cs_renumber_cells_type_t *cells_pre_numbering, cs_renumber_cells_type_t *cells_numbering, cs_renumber_i_faces_type_t *i_faces_numbering, cs_renumber_b_faces_type_t *b_faces_numbering, cs_renumber_vertices_type_t *vertices_numbering)
 Return the algorithms for mesh renumbering.
void cs_renumber_mesh (cs_mesh_t *mesh)
 Renumber mesh elements for vectorization or threading depending on code options and target machine.
void cs_renumber_cells (cs_mesh_t *mesh)
 Renumber cells depending on code options and target machine.
void cs_renumber_i_faces (cs_mesh_t *mesh)
 Renumber interior faces for vectorization or threading depending on code options and target machine.
void cs_renumber_i_faces_by_gnum (cs_mesh_t *mesh)
void cs_renumber_b_faces (cs_mesh_t *mesh)
 Renumber boundary faces for vectorization or threading depending on code options and target machine.
void cs_renumber_b_faces_by_gnum (cs_mesh_t *mesh)
void cs_renumber_b_faces_select_ignore (cs_mesh_t *mesh, cs_lnum_t n_faces, const cs_lnum_t face_ids[])
 Renumber boundary faces such that selected faces appear last and will be ignored.
void cs_renumber_vertices (cs_mesh_t *mesh)
 Renumber vertices depending on code options and target machine.
◆ cs_renumber_b_faces_type_t
Enumerator
Renumber for threads, with one block per thread, and no cell referenced by faces in different threads blocks.
Renumber to allow SIMD operations in boundary face->cell gather operations.
No interior face renumbering.
◆ cs_renumber_cells_type_t
Enumerator
Subpartition for thread blocks based SCOTCH library.
Fill-reducing ordering based on SCOTCH library.
Subpartition for thread blocks based METIS library.
Fill-reducing ordering based on METIS library.
Order cells using domain-local Morton space-filling curve.
Order cells using domain-local Hilbert space-filling curve.
Order cells using domain-local reverse Cuthill-McKee algorithm.
No cells renumbering.
◆ cs_renumber_i_faces_type_t
Enumerator
No shared cell in block. This should produce blocks of similar (prescribed) size across thread groups.
Use multipass face numbering. This should produce a smaller number of blocks, with a diminishing number of faces per thread group.
Renumber to allow SIMD operations in interior face->cell gather operations (such as SpMV products with native matrix representation).
◆ cs_renumber_ordering_t
Enumerator
Lexicographical ordering with lowest adjacent id first
Lexicographical ordering with highest adjacent id first } ;
◆ cs_renumber_vertices_type_t
Enumerator
Renumbering based on the cell adjacency.
Renumbering based on the face adjacency.
No vertex renumbering.
◆ cs_renumber_b_faces()
void cs_renumber_b_faces ( cs_mesh_t * mesh)
parameters: mesh <-> pointer to global mesh structure
[in,out]meshpointer to global mesh structure
◆ cs_renumber_b_faces_by_gnum()
void cs_renumber_b_faces_by_gnum ( cs_mesh_t * mesh)
◆ cs_renumber_b_faces_select_ignore()
void cs_renumber_b_faces_select_ignore ( cs_mesh_t * mesh,
cs_lnum_t n_faces,
const cs_lnum_t face_ids[] )
Those faces will appear last, and the local number of boundary faces set to the number of remaining faces; The mesh's n_b_faces_all and n_g_b_faces_all allows accessing the full boundary faces list.
[in]n_facesnumber of selected faces
[in]face_idsnumber of selected faces
◆ cs_renumber_cells()
void cs_renumber_cells ( cs_mesh_t * mesh)
◆ cs_renumber_get_algorithm()
void cs_renumber_get_algorithm ( bool * halo_adjacent_cells_last,
bool * halo_adjacent_faces_last,
cs_renumber_ordering_t * i_faces_base_ordering,
cs_renumber_cells_type_t * cells_pre_numbering,
cs_renumber_cells_type_t * cells_numbering,
cs_renumber_i_faces_type_t * i_faces_numbering,
cs_renumber_b_faces_type_t * b_faces_numbering,
cs_renumber_vertices_type_t * vertices_numbering )
Any argument may be passed NULL if this option is not queried.
[out]halo_adjacent_cells_lastif true, cells adjacent to ghost cells will be placed last (after pre-numbering)
[out]halo_adjacent_faces_lastif true, interior faces adjacent to ghost cells will be placed last (after pre-numbering)
[out]i_faces_base_orderingpre-ordering of interior faces by lowest or highest adjacent cell id
[out]cells_pre_numberingalgorithm for cells pre-numbering
[out]cells_numberingalgorithm for cells numbering
[out]i_faces_numberingalgorithm for interior faces numbering
[out]b_faces_numberingalgorithm for boundary faces numbering
[out]vertices_numberingalgorithm for vertices numbering
Any argument may be passed nullptr if this option is not queried.
◆ cs_renumber_get_min_subset_size()
void cs_renumber_get_min_subset_size ( cs_lnum_t * min_i_subset_size,
cs_lnum_t * min_b_subset_size )
[out]min_i_subset_sizeminimum number of interior faces per thread per group, or nullptr
[out]min_b_subset_sizeminimum number of boundary faces per thread per group, or nullptr
◆ cs_renumber_get_n_threads()
int cs_renumber_get_n_threads ( void )
the target number of threads for mesh numbering
◆ cs_renumber_i_faces()
void cs_renumber_i_faces ( cs_mesh_t * mesh)
◆ cs_renumber_i_faces_by_gnum()
void cs_renumber_i_faces_by_gnum ( cs_mesh_t * mesh)
◆ cs_renumber_mesh()
void cs_renumber_mesh ( cs_mesh_t * mesh)
Renumbering cells may also allow improving locality (and favor faces renumbering). It is also possible to place cells connected to ghost cells last, which may be useful to enable computation/communication overlap.
◆ cs_renumber_set_algorithm()
void cs_renumber_set_algorithm ( bool halo_adjacent_cells_last,
cs_renumber_vertices_type_t vertices_numbering )
[in]halo_adjacent_cells_lastif true, cells adjacent to ghost cells will be placed last (after pre-numbering)
[in]halo_adjacent_faces_lastif true, interior faces adjacent to ghost cells will be placed last (after pre-numbering)
[in]i_faces_base_orderingpre-ordering of interior faces by lowest or highest adjacent cell id
[in]cells_pre_numberingalgorithm for cells pre-numbering
[in]cells_numberingalgorithm for cells numbering
[in]i_faces_numberingalgorithm for interior faces numbering
[in]b_faces_numberingalgorithm for boundary faces numbering
[in]vertices_numberingalgorithm for vertices numbering
◆ cs_renumber_set_min_subset_size()
void cs_renumber_set_min_subset_size ( cs_lnum_t min_i_subset_size,
cs_lnum_t min_b_subset_size )
[in]min_i_subset_sizeminimum number of interior faces per thread per group
[in]min_b_subset_sizeminimum number of boundary faces per thread per group
◆ cs_renumber_set_n_threads()
void cs_renumber_set_n_threads ( int n_threads)
By default, the target number of threads is set to cs_glob_n_threads, but the value may be forced using this function. This is mainly useful for testing purposes.
[in]n_threadstarget number of threads for mesh numbering
◆ cs_renumber_vertices()
void cs_renumber_vertices ( cs_mesh_t * mesh)
