cs_ale.h File Reference
#include "base/cs_base.h"
#include "cdo/cs_domain.h"
#include "base/cs_restart.h"
Include dependency graph for cs_ale.h:
Data Structures
struct  cs_ale_data_t
Enumerations
enum  cs_ale_type_t { CS_ALE_NONE = 0 , CS_ALE_LEGACY = 1 , CS_ALE_CDO = 2 }
void cs_ale_allocate (void)
 Allocation of ialtyb and impale for the ALE structure.
void cs_ale_update_mesh_quantities (cs_real_t *min_vol, cs_real_t *max_vol, cs_real_t *tot_vol)
 Compute cell and face centers of gravity, cell volumes and update bad cells.
void cs_ale_project_displacement (const int ale_bc_type[], const cs_real_3_t *meshv, const cs_real_33_t gradm[], const cs_real_3_t *claale, const cs_real_33_t *clbale, const cs_real_t *dt, cs_real_3_t *disp_proj)
 Project the displacement on mesh vertices (solved on cell center).
void cs_ale_update_mesh (int itrale)
 Update mesh in the ALE framework.
void cs_ale_update_bcs (int *ale_bc_type, cs_real_3_t *b_fluid_vel)
 Update ALE BCs for required for the fluid.
void cs_ale_solve_mesh_velocity (int iterns)
 Solve a Poisson equation on the mesh velocity in ALE framework.
void cs_ale_activate (void)
 Activate the mesh velocity solving with CDO.
bool cs_ale_is_activated (void)
 Test if mesh velocity solving with CDO is activated.
void cs_ale_add_property_fields (void)
 Add "property" fields dedicated to the ALE model.
void cs_ale_init_setup (cs_domain_t *domain)
 Setup the equations solving the mesh velocity when CDO is activated.
void cs_ale_log_setup (void)
void cs_ale_setup_boundaries (const cs_domain_t *domain)
 Setup the equations solving the mesh velocity.
void cs_ale_finalize_setup (cs_domain_t *domain)
 Finalize the setup stage for the equation of the mesh velocity.
void cs_ale_destroy_all (void)
 Free the main structure related to the ALE mesh velocity solving.
void cs_ale_restart_read (cs_restart_t *r)
 Read ALE data from restart file.
void cs_ale_restart_write (cs_restart_t *r)
 Write ALE data from restart file.
cs_ale_type_t cs_glob_ale
cs_ale_data_tcs_glob_ale_data
int cs_glob_ale_n_ini_f
int cs_glob_ale_need_init
◆ cs_ale_type_t
ALE computation type
Enumerator
CS_ALE_NONE
no ALE
CS_ALE_LEGACY
Mesh deformation computed with legacy operators
CS_ALE_CDO
Mesh deformation computed with CDO
◆ cs_ale_activate()
void cs_ale_activate ( void )
◆ cs_ale_add_property_fields()
void cs_ale_add_property_fields ( void )
◆ cs_ale_allocate()
void cs_ale_allocate ( void )
◆ cs_ale_destroy_all()
void cs_ale_destroy_all ( void )
◆ cs_ale_finalize_setup()
void cs_ale_finalize_setup ( cs_domain_t * domain)
◆ cs_ale_init_setup()
void cs_ale_init_setup ( cs_domain_t * domain)
◆ cs_ale_is_activated()
bool cs_ale_is_activated ( void )
true ifmesh velocity solving with CDO is requested, false otherwise
true if mesh velocity solving with CDO is requested, false otherwise
◆ cs_ale_log_setup()
void cs_ale_log_setup ( void )
◆ cs_ale_project_displacement()
void cs_ale_project_displacement ( const int ale_bc_type[],
const cs_real_3_t * meshv,
const cs_real_3_t * claale,
const cs_real_33_t * clbale,
const cs_real_t * dt,
cs_real_3_t * disp_proj )
[in]ale_bc_typeType of boundary for ALE
[in]meshvMesh velocity
[in]gradmMesh velocity gradient (du_i/dx_j : gradv[][i][j])
[in]claaleBoundary conditions A
[in]clbaleBoundary conditions B
[in]dtTime step
[out]disp_projDisplacement projected on vertices
◆ cs_ale_restart_read()
void cs_ale_restart_read ( cs_restart_t * r)
[in,out]rassociated restart file pointer
◆ cs_ale_restart_write()
void cs_ale_restart_write ( cs_restart_t * r)
◆ cs_ale_setup_boundaries()
void cs_ale_setup_boundaries ( const cs_domain_t * domain)
[in]domainpointer to a cs_domain_t structure
◆ cs_ale_solve_mesh_velocity()
void cs_ale_solve_mesh_velocity ( int iterns)
It also updates the mesh displacement so that it can be used to update mass fluxes (due to mesh displacement).
[in]iternsNavier-Stokes iteration number
◆ cs_ale_update_bcs()
void cs_ale_update_bcs ( int * ale_bc_type,
cs_real_3_t * b_fluid_vel )
[out]ale_bc_typetype of ALE bcs
[out]b_fluid_velFluid velocity at boundary faces
◆ cs_ale_update_mesh()
void cs_ale_update_mesh ( int itrale)
[in]itralenumber of the current ALE iteration
◆ cs_ale_update_mesh_quantities()
void cs_ale_update_mesh_quantities ( cs_real_t * min_vol,
cs_real_t * max_vol,
cs_real_t * tot_vol )
[out]min_volMinimum cell volume
[out]max_volMaximum cell volume
[out]tot_volTotal cell volume
◆ cs_glob_ale
extern
◆ cs_glob_ale_data
cs_ale_data_t* cs_glob_ale_data
extern
◆ cs_glob_ale_n_ini_f
extern
Number of iterations for fluid flow initialization
◆ cs_glob_ale_need_init
extern
Indicate whether an iteration to initialize ALE is required
