#include "base/cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_mem.h"#include "bft/bft_error.h"#include "base/cs_block_dist.h"Functions | |
| cs_block_dist_info_t | cs_block_dist_compute_sizes (int rank_id, int n_ranks, int min_rank_step, cs_lnum_t min_block_size, cs_gnum_t n_g_ents) |
| Compute block size and rank info for use with a block distribution. | |
| cs_block_dist_info_t | cs_block_dist_compute_sizes_nr (int rank_id, int n_ranks, int n_block_ranks, cs_gnum_t n_g_ents) |
| Compute block size and rank info for use with a block distribution for a new global number of entities with a given number of active ranks. | |
| cs_block_dist_info_t cs_block_dist_compute_sizes | ( | int | rank_id, |
| int | n_ranks, | ||
| int | min_rank_step, | ||
| cs_lnum_t | min_block_size, | ||
| cs_gnum_t | n_g_ents ) |
| [in] | rank_id | id of local rank (ignored in serial mode) |
| [in] | n_ranks | number of associated ranks |
| [in] | min_rank_step | minimum rank step between blocks |
| [in] | min_block_size | minimum number of entities per block |
| [in] | n_g_ents | total number of associated entities |
| cs_block_dist_info_t cs_block_dist_compute_sizes_nr | ( | int | rank_id, |
| int | n_ranks, | ||
| int | n_block_ranks, | ||
| [in] | n_block_ranks | number of ranks associated with a block |
