#include "base/cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_mem.h"#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "base/cs_log.h"#include "base/cs_map.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parall.h"#include "base/cs_parameters.h"#include "pprt/cs_physical_model.h"#include "base/cs_porous_model.h"#include "mesh/cs_mesh_location.h"#include "base/cs_time_step.h"#include "turb/cs_turbulence_model.h"#include "base/cs_velocity_pressure.h"Functions | |
| cs_velocity_pressure_model_t * | cs_get_glob_velocity_pressure_model (void) |
| cs_velocity_pressure_param_t * | cs_get_glob_velocity_pressure_param (void) |
| Provide access to cs_glob_velocity_pressure_param. | |
| void | cs_velocity_pressure_set_n_buoyant_scalars (void) |
| void | cs_velocity_pressure_set_solid (void) |
| void | cs_velocity_pressure_model_log_setup (void) |
| Print the volocity-pressure model parameters to setup log. | |
| void | cs_velocity_pressure_param_log_setup (void) |
| Print Velocity-pressure parameters to setup.log. | |
Velocity-pressure coupling model and parameters.
| cs_velocity_pressure_model_t * cs_get_glob_velocity_pressure_model | ( | void | ) |
| cs_velocity_pressure_param_t * cs_get_glob_velocity_pressure_param | ( | void | ) |
| void cs_velocity_pressure_model_log_setup | ( | void | ) |
Print the stokes model parameters to setup.log.
| void cs_velocity_pressure_param_log_setup | ( | void | ) |
| void cs_velocity_pressure_set_n_buoyant_scalars | ( | void | ) |
| void cs_velocity_pressure_set_solid | ( | void | ) |
