| struct | cs_pressure_correction_cdo_t |
| void | cs_pressure_correction_fv_activate (void) |
| Activate the pressure increment solving with Legacy FV. | |
| void | cs_pressure_correction_cdo_destroy_all (void) |
| Free the main structure related to the pressure correction. | |
| void | cs_pressure_correction_cdo_activate (void) |
| Activate the pressure increment solving with CDO. | |
| void | cs_pressure_correction_model_activate (void) |
| Activate the pressure increment, either FV or CDO. | |
| bool | cs_pressure_correction_cdo_is_activated (void) |
| Test if pressure solving with CDO is activated. | |
| void | cs_pressure_correction_cdo_init_setup (void) |
| Start setting-up the pressure increment equation At this stage, numerical settings should be completely determined but connectivity and geometrical information is not yet available. | |
| void | cs_pressure_correction_cdo_finalize_setup (const cs_domain_t *domain) |
| Finalize setting-up the pressure increment equation At this stage, numerical settings should be completely determined. | |
| void | cs_pressure_correction (int iterns, cs_lnum_t nfbpcd, cs_lnum_t ncmast, cs_lnum_t ifbpcd[], cs_lnum_t ltmast[], const int isostd[], cs_real_t vel[][3], cs_real_t da_uu[][6], cs_field_bc_coeffs_t *bc_coeffs_v, cs_field_bc_coeffs_t *bc_coeffs_dp, cs_real_t spcond[], cs_real_t svcond[], cs_real_t frcxt[][3], cs_real_t dfrcxt[][3], cs_real_t i_visc[], cs_real_t b_visc[]) |
| Perform the pressure correction step of the Navier-Stokes equations for incompressible or slightly compressible flows. | |
| void cs_pressure_correction | ( | int | iterns, |
| cs_lnum_t | nfbpcd, | ||
| cs_lnum_t | ncmast, | ||
| cs_lnum_t | ifbpcd[], | ||
| cs_lnum_t | ltmast[], | ||
| const int | isostd[], | ||
| cs_real_t | vel[][3], | ||
| cs_real_t | da_uu[][6], | ||
| cs_field_bc_coeffs_t * | bc_coeffs_v, | ||
| cs_field_bc_coeffs_t * | bc_coeffs_dp, | ||
| cs_real_t | spcond[], | ||
| cs_real_t | svcond[], | ||
| cs_real_t | frcxt[][3], | ||
| cs_real_t | dfrcxt[][3], | ||
| cs_real_t | i_visc[], | ||
| cs_real_t | b_visc[] ) |
![\[ D \left( \Delta t, \delta p \right) =
\divs \left( \rho \vect{\widetilde{u}}\right)
- \Gamma^n
+ \dfrac{\rho^n - \rho^{n-1}}{\Delta t}
\]](form_219.png)
Either the legacy FV method or a CDO face-based scheme is used.
For the legacy case, the mass flux is updated as follows:
![\[ \dot{m}^{n+1}_\ij = \dot{m}^{n}_\ij
- \Delta t \grad_\fij \delta p \cdot \vect{S}_\ij
\]](form_220.png)
| [in] | nfbpcd | number of faces with condensation source term |
| [in] | ncmast | number of cells with condensation source terms |
| [in] | ifbpcd | index of faces with condensation source term |
| [in] | ltmast | list of cells with condensation source terms (1 to n numbering) |
| [in] | isostd | indicator of standard outlet and index of the reference outlet face |
| [in] | vel | velocity |
| [in,out] | da_uu | velocity matrix |
| [in] | bc_coeffs_v | boundary condition structure for the variable |
| [in] | bc_coeffs_dp | boundary conditions structure for the pressure increment |
| [in] | spcond | variable value associated to the condensation source term (for ivar=ipr, spcond is the flow rate |
| [in] | svcond | variable value associated to the condensation source term (for ivar=ipr, svcond is the flow rate |
| [in] | frcxt | external forces making hydrostatic pressure |
| [in] | dfrcxt | variation of the external forces composing the hydrostatic pressure |
| [in] | i_visc | visc*surface/dist aux faces internes |
| [in] | b_visc | visc*surface/dist aux faces de bord |
| void cs_pressure_correction_cdo_activate | ( | void | ) |
| void cs_pressure_correction_cdo_destroy_all | ( | void | ) |
| void cs_pressure_correction_cdo_finalize_setup | ( | const cs_domain_t * | domain | ) |
| [in] | domain | pointer to a cs_domaint_t structure |
| void cs_pressure_correction_cdo_init_setup | ( | void | ) |
| bool cs_pressure_correction_cdo_is_activated | ( | void | ) |
| void cs_pressure_correction_fv_activate | ( | void | ) |
| void cs_pressure_correction_model_activate | ( | void | ) |
