#include "base/cs_defs.h"#include <assert.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "base/cs_base.h"#include "base/cs_field.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "mesh/cs_mesh_location.h"#include "base/cs_parall.h"#include "base/cs_post.h"#include "base/cs_fan.h"Functions | |
| void | cs_fan_define (int fan_dim, int mode, const cs_real_t inlet_axis_coords[3], const cs_real_t outlet_axis_coords[3], cs_real_t fan_radius, cs_real_t blades_radius, cs_real_t hub_radius, const cs_real_t curve_coeffs[3], cs_real_t axial_torque) |
| Fan definition (added to the ones previously defined) | |
| void | cs_fan_destroy_all (void) |
| Destroy the structures associated with fans. | |
| int | cs_fan_n_fans (void) |
| Return number of fans. | |
| void | cs_fan_field_create (void) |
| void | cs_fan_log_setup (void) |
| Log fans definition setup information. | |
| void | cs_fan_log_iteration (void) |
| Log fan information for a given iteration. | |
| void | cs_fan_build_all (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities) |
| Define the cells belonging to the different fans. | |
| void | cs_fan_compute_flows (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, const cs_real_t i_mass_flux[], const cs_real_t b_mass_flux[], const cs_real_t c_rho[], const cs_real_t b_rho[]) |
| Compute the flows through the fans. | |
| void | cs_fan_compute_force (const cs_mesh_quantities_t *mesh_quantities, cs_real_3_t source_t[]) |
| Compute the force induced by the fans (needs a previous calculation of the flows through each fan). | |
| void | cs_fan_flag_cells (const cs_mesh_t *mesh, int cell_fan_id[]) |
| Flag the cells belonging to the different fans (by the fan id, -1 otherwise) | |
| void | cs_fan_cells_select (void *input, cs_lnum_t *n_cells, cs_lnum_t **cell_ids) |
| Selection function for cells belonging to fans. | |
Fan modeling through velocity source terms.
| void cs_fan_build_all | ( | const cs_mesh_t * | mesh, |
| const cs_mesh_quantities_t * | mesh_quantities ) |
| [in] | mesh | associated mesh structure |
| [in] | mesh_quantities | mesh quantities |
This function may be used for the definition of postprocessing meshes.
| [in,out] | input | pointer to input (unused here) |
| [out] | n_cells | number of selected cells |
| [out] | cell_ids | array of selected cell ids (0 to n-1 numbering) |
| void cs_fan_compute_flows | ( | const cs_mesh_t * | mesh, |
| const cs_mesh_quantities_t * | mesh_quantities, | ||
| const cs_real_t | i_mass_flux[], | ||
| const cs_real_t | b_mass_flux[], | ||
| const cs_real_t | c_rho[], | ||
| const cs_real_t | b_rho[] ) |
| [in] | mesh | mesh structure |
| [in] | i_mass_flux | interior faces mass flux |
| [in] | b_mass_flux | boundary faces mass flux |
| [in] | c_rho | density at cells |
| [in] | b_rho | density at boundary faces |
| void cs_fan_compute_force | ( | const cs_mesh_quantities_t * | mesh_quantities, |
| cs_real_3_t | source_t[] ) |
| [in] | source_t | explicit source term for the velocity |
| void cs_fan_define | ( | int | fan_dim, |
| int | mode, | ||
| const cs_real_t | inlet_axis_coords[3], | ||
| const cs_real_t | outlet_axis_coords[3], | ||
| cs_real_t | fan_radius, | ||
| cs_real_t | blades_radius, | ||
| cs_real_t | hub_radius, | ||
| const cs_real_t | curve_coeffs[3], | ||
| cs_real_t | axial_torque ) |
Fans are handled as explicit momentum source terms at the given location, based on the fan's axis and diameter. The fan's pressure characteristic curve is defined by 3 coefficients, such that:
| [in] | fan_dim | fan dimension: 2: pseudo-2D (extruded mesh) 3: 3D (standard) |
| [in] | mode | mode: 0: fan 1: wind turbine |
| [in] | inlet_axis_coords | intersection of axis and inlet face |
| [in] | outlet_axis_coords | intersection of axis and outlet face |
| [in] | fan_radius | fan radius |
| [in] | blades_radius | blades radius |
| [in] | hub_radius | hub radius |
| [in] | curve_coeffs | coefficients of degre 0, 1 and 2 of the pressure drop/flow rate characteristic curve |
| [in] | axial_torque | fan axial torque |
| void cs_fan_destroy_all | ( | void | ) |
| void cs_fan_field_create | ( | void | ) |
| void cs_fan_flag_cells | ( | const cs_mesh_t * | mesh, |
| int | cell_fan_id[] ) |
| [in] | mesh | assosiated mesh structure |
| [out] | cell_fan_id | fan id (or -1) for each cell |
| void cs_fan_log_iteration | ( | void | ) |
| void cs_fan_log_setup | ( | void | ) |
| int cs_fan_n_fans | ( | void | ) |
