60#define CS_POST_ON_LOCATION (1 << 0)
63#define CS_POST_BOUNDARY_NR (1 << 1)
66#define CS_POST_MONITOR (1 << 2)
70#define CS_POST_WRITER_ALL_ASSOCIATED 0
72#define CS_POST_WRITER_DEFAULT -1
73#define CS_POST_WRITER_ERRORS -2
74#define CS_POST_WRITER_PARTICLES -3
75#define CS_POST_WRITER_TRAJECTORIES -4
76#define CS_POST_WRITER_PROBES -5
77#define CS_POST_WRITER_PROFILES -6
78#define CS_POST_WRITER_HISTOGRAMS -7
82#define CS_POST_MESH_VOLUME -1
83#define CS_POST_MESH_BOUNDARY -2
84#define CS_POST_MESH_PARTICLES -3
85#define CS_POST_MESH_TRAJECTORIES -4
86#define CS_POST_MESH_PROBES -5
90#define CS_POST_MESH_SURFACE -1001
101#define CS_POST_TYPE_int CS_INT_TYPE
102#define CS_POST_TYPE_cs_real_t CS_REAL_TYPE
103#define CS_POST_TYPE_float CS_FLOAT
104#define CS_POST_TYPE_double CS_DOUBLE
296 const char *case_name,
297 const char *dir_name,
298 const char *fmt_name,
299 const char *fmt_opts,
301 bool output_at_start,
323 const char *mesh_name,
324 const char *cell_criteria,
328 const int writer_ids[]);
361 const char *mesh_name,
363 void *cell_select_input,
368 const int writer_ids[]);
388 const char *mesh_name,
389 const char *i_face_criteria,
390 const char *b_face_criteria,
394 const int writer_ids[]);
431 const char *mesh_name,
434 void *i_face_select_input,
435 void *b_face_select_input,
440 const int writer_ids[]);
460 const char *mesh_name,
465 const int writer_ids[]);
496 const char *mesh_name,
497 const char *cell_criteria,
502 const int writer_ids[]);
538 const char *mesh_name,
540 void *p_select_input,
544 const int writer_ids[]);
580 fvm_nodal_t *exp_mesh,
585 const int writer_ids[]);
610 const int writer_ids[]);
1167 const char *var_name,
1172 const void *cel_vals,
1173 const void *i_face_vals,
1174 const void *b_face_vals,
1230 const char *var_name,
1235 const void *vtx_vals,
1280 const char *var_name,
1310 const char *var_name,
1313 int parent_location_id,
1315 void *interpolate_input,
1360 int parent_location_id,
1362 void *interpolate_input,
cs_datatype_t
Definition cs_defs.h:300
Definition cs_defs.h:542
Definition cs_defs.h:543
Definition cs_defs.h:335
@ t
Definition cs_field_pointer.h:94
void cs_interpolate_from_location_t(void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals)
Function pointer for interpolatation of values defined on a mesh location at a given set of points.
Definition cs_interpolate.h:71
const char * cs_post_get_default_format_options(void)
Return the default writer format options.
Definition cs_post.cpp:5651
int cs_post_get_free_mesh_id(void)
Return the next "reservable" (i.e. non-user) mesh id available.
Definition cs_post.cpp:5679
void cs_post_mesh_get_b_face_ids(int mesh_id, cs_lnum_t b_face_ids[])
Get a postprocessing mesh's list of boundary faces.
Definition cs_post.cpp:5358
void cs_post_write_probe_values(int mesh_id, int writer_id, const char *var_name, int var_dim, cs_datatype_t datatype, int parent_location_id, cs_interpolate_from_location_t *interpolate_func, void *interpolate_input, const void *vals, const cs_time_step_t *ts)
Output a variable defined at cells or faces of a post-processing mesh using associated writers.
Definition cs_post.cpp:7003
void cs_post_time_step_output(const cs_time_step_t *ts)
Loop on post-processing meshes to output variables.
Definition cs_post.cpp:7793
void cs_post_add_time_mesh_dep_output(cs_post_time_mesh_dep_output_t *function, void *input)
Register a processing of time-dependent variables than can be output on different meshes to the call ...
Definition cs_post.cpp:8598
int cs_post_get_free_writer_id(void)
Return the next "reservable" (i.e. non-user) writer id available.
Definition cs_post.cpp:5665
void cs_post_init_error_writer(void)
Initialize post-processing writer with same format and associated options as default writer,...
Definition cs_post.cpp:8465
void cs_post_add_writer_t_step(int writer_id, int nt)
Add an activation time step for a specific writer or for all writers.
Definition cs_post.cpp:6012
void cs_post_renum_faces(const cs_lnum_t init_i_face_num[], const cs_lnum_t init_b_face_num[])
Update references to parent mesh of post-processing meshes in case of computational mesh interior and...
Definition cs_post.cpp:7379
void cs_post_init_meshes(int check_mask)
Initialize main post-processing meshes.
Definition cs_post.cpp:7600
void cs_post_add_free_faces(void)
Postprocess free (isolated) faces of the current global mesh.
Definition cs_post.cpp:8254
void cs_post_time_step_begin(const cs_time_step_t *ts)
Check if post-processing is activated and then update post-processing of meshes if there is a need to...
Definition cs_post.cpp:7760
void cs_post_finalize(void)
Destroy all structures associated with post-processing.
Definition cs_post.cpp:8159
void cs_post_define_mesh_by_location(int mesh_id, const char *mesh_name, int location_id, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a volume or surface post-processing mesh by associated mesh location id.
Definition cs_post.cpp:4594
void cs_post_define_volume_mesh(int mesh_id, const char *mesh_name, const char *cell_criteria, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a volume post-processing mesh.
Definition cs_post.cpp:4336
void cs_post_define_volume_mesh_by_func(int mesh_id, const char *mesh_name, cs_post_elt_select_t *cell_select_func, void *cell_select_input, bool time_varying, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a volume post-processing mesh using a selection function.
Definition cs_post.cpp:4404
void cs_post_mesh_get_vertex_ids(int mesh_id, cs_lnum_t *vertex_ids)
Get a postprocessing mesh's list of vertices.
Definition cs_post.cpp:5430
void cs_post_write_vertex_var(int mesh_id, int writer_id, const char *var_name, int var_dim, bool interlace, bool use_parent, cs_datatype_t datatype, const void *vtx_vals, const cs_time_step_t *ts)
Output a variable defined at vertices of a post-processing mesh using associated writers.
Definition cs_post.cpp:6607
void cs_post_write_particle_values(int mesh_id, int writer_id, int attr_id, const char *var_name, int component_id, const cs_time_step_t *ts)
Output an existing lagrangian particle attribute at particle positions or trajectory endpoints of a p...
Definition cs_post.cpp:6840
void cs_post_elt_select_t(void *input, cs_lnum_t *n_elts, cs_lnum_t **elt_list)
Function pointer to elements selection definition.
Definition cs_post.h:126
cs_lnum_t cs_post_mesh_get_n_vertices(int mesh_id)
Get a postprocessing mesh's number of vertices.
Definition cs_post.cpp:5400
cs_time_control_t * cs_post_get_time_control(int writer_id)
Return a pointer to the time control associated to a writer_id.
Definition cs_post.cpp:5962
fvm_writer_t * cs_post_get_writer(int writer_id)
Return a pointer to the FVM writer associated to a writer_id.
Definition cs_post.cpp:5937
void cs_post_define_particles_mesh_by_func(int mesh_id, const char *mesh_name, cs_post_elt_select_t *p_select_func, void *p_select_input, bool trajectory, bool auto_variables, int n_writers, const int writer_ids[])
Define a particles post-processing mesh using a selection function.
Definition cs_post.cpp:4741
void cs_post_write_var(int mesh_id, int writer_id, const char *var_name, int var_dim, bool interlace, bool use_parent, cs_datatype_t datatype, const void *cel_vals, const void *i_face_vals, const void *b_face_vals, const cs_time_step_t *ts)
Definition cs_post.cpp:6124
void cs_post_write_meshes(const cs_time_step_t *ts)
Output post-processing meshes using associated writers.
Definition cs_post.cpp:6067
int cs_post_init_error_writer_cells(void)
Definition cs_post.cpp:8515
bool cs_post_writer_exists(int writer_id)
Check for the existence of a writer of the given id.
Definition cs_post.cpp:5546
void cs_post_write_vertex_function(int mesh_id, int writer_id, const cs_function_t *f, const cs_time_step_t *ts)
Output a function evaluation at cells or faces of a post-processing mesh using associated writers.
Definition cs_post.cpp:6726
void cs_post_set_changing_connectivity(void)
Configure the post-processing output so that mesh connectivity may be automatically updated.
Definition cs_post.cpp:7474
void cs_post_define_writer(int writer_id, const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int interval_n, double interval_t)
Define a writer; this objects manages a case's name, directory, and format, as well as associated mes...
Definition cs_post.cpp:4181
void cs_post_define_particles_mesh(int mesh_id, const char *mesh_name, const char *cell_criteria, double density, bool trajectory, bool auto_variables, int n_writers, const int writer_ids[])
Define a particles post-processing mesh.
Definition cs_post.cpp:4673
void cs_post_write_probe_function(int mesh_id, int writer_id, const cs_function_t *f, int parent_location_id, cs_interpolate_from_location_t *interpolate_func, void *interpolate_input, const cs_time_step_t *ts)
Output function-evaluated values at cells or faces of a post-processing probe set using associated wr...
Definition cs_post.cpp:7141
const char * cs_post_get_default_format(void)
Return the default writer format name.
Definition cs_post.cpp:5637
cs_lnum_t cs_post_mesh_get_n_cells(int mesh_id)
Get a postprocessing mesh's number of cells.
Definition cs_post.cpp:5196
void cs_post_write_vars(const cs_time_step_t *ts)
Definition cs_post.cpp:8137
void cs_post_add_time_dep_output(cs_post_time_dep_output_t *function, void *input)
Register a processing of time-dependent variables to the call to cs_post_write_vars().
Definition cs_post.cpp:8557
cs_lnum_t cs_post_mesh_get_n_b_faces(int mesh_id)
Get a postprocessing mesh's number of boundary faces.
Definition cs_post.cpp:5328
cs_datatype_t cs_post_type_t
Definition cs_post.h:95
void cs_post_time_mesh_dep_output_t(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *ts)
Definition cs_post.h:183
void cs_post_add_writer_t_value(int writer_id, double t)
Add an activation time value for a specific writer or for all writers.
Definition cs_post.cpp:6040
void cs_post_mesh_set_post_domain(int mesh_id, bool post_domain)
Set whether postprocessing mesh's parallel domain should be output.
Definition cs_post.cpp:5459
void cs_post_activate_by_time_step(const cs_time_step_t *ts)
Update "active" or "inactive" flag of writers based on the time step.
Definition cs_post.cpp:5697
void cs_post_activate_writer_if_enabled(int writer_id, bool activate)
Force the "active" or "inactive" flag for a specific writer or for all writers for the current time s...
Definition cs_post.cpp:5831
void cs_post_mesh_get_cell_ids(int mesh_id, cs_lnum_t *cell_ids)
Get a postprocessing mesh's list of cells.
Definition cs_post.cpp:5226
void cs_post_write_function(int mesh_id, int writer_id, const cs_function_t *cel_f, const cs_function_t *i_face_f, const cs_function_t *b_face_f, const cs_time_step_t *ts)
Definition cs_post.cpp:6394
void cs_post_disable_writer(int writer_id)
Disable specific writer or all writers not currently active until cs_post_enable_writer or cs_post_ac...
Definition cs_post.cpp:5869
void cs_post_free_mesh(int mesh_id)
Remove a post-processing mesh.
Definition cs_post.cpp:5482
void cs_post_activate_writer(int writer_id, bool activate)
Definition cs_post.cpp:5802
void cs_post_time_dep_output_t(void *input, const cs_time_step_t *ts)
Definition cs_post.h:149
void cs_post_define_surface_mesh(int mesh_id, const char *mesh_name, const char *i_face_criteria, const char *b_face_criteria, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a surface post-processing mesh.
Definition cs_post.cpp:4454
void cs_post_mesh_detach_writer(int mesh_id, int writer_id)
De-associate a writer from a postprocessing mesh.
Definition cs_post.cpp:5048
void cs_post_mesh_get_i_face_ids(int mesh_id, cs_lnum_t i_face_ids[])
Definition cs_post.cpp:5285
void cs_post_define_edges_mesh(int mesh_id, int base_mesh_id, int n_writers, const int writer_ids[])
Create a mesh based upon the extraction of edges from an existing mesh.
Definition cs_post.cpp:4931
void cs_post_mesh_attach_field(int mesh_id, int writer_id, int field_id, int comp_id)
Associate a field to a writer and postprocessing mesh combination.
Definition cs_post.cpp:5112
cs_lnum_t cs_post_mesh_get_n_i_faces(int mesh_id)
Get a postprocessing mesh's number of interior faces.
Definition cs_post.cpp:5255
void cs_post_time_step_end(void)
Flush writers and free time-varying and Lagragian mesh if needed of meshes if there is a time-depende...
Definition cs_post.cpp:8093
void cs_post_renum_cells(const cs_lnum_t init_cell_num[])
Update references to parent mesh of post-processing meshes in case of computational mesh cell renumbe...
Definition cs_post.cpp:7303
const int * cs_post_mesh_get_ent_flag(int mesh_id)
Get a postprocessing meshes entity presence flag.
Definition cs_post.cpp:5178
void cs_post_define_surface_mesh_by_func(int mesh_id, const char *mesh_name, cs_post_elt_select_t *i_face_select_func, cs_post_elt_select_t *b_face_select_func, void *i_face_select_input, void *b_face_select_input, bool time_varying, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[])
Define a surface post-processing mesh using selection functions.
Definition cs_post.cpp:4534
int cs_post_mesh_find_next_with_cat_id(int cat_id, int start_mesh_id)
Find next mesh with a given category id.
Definition cs_post.cpp:5603
void cs_post_init_writers(void)
Initialize post-processing writers.
Definition cs_post.cpp:7486
void cs_post_mesh_attach_writer(int mesh_id, int writer_id)
Associate a writer to a postprocessing mesh.
Definition cs_post.cpp:5003
void cs_post_mesh_set_element_centers_only(int mesh_id, bool centers_only)
Set restriction of a postprocessing mesh to element centers.
Definition cs_post.cpp:4975
void cs_post_enable_writer(int writer_id)
Enable a specific writer or all writers currently disabled by previous calls to cs_post_disable_write...
Definition cs_post.cpp:5906
bool cs_post_writer_is_active(int writer_id)
Query if a given writer is currently active.
Definition cs_post.cpp:5783
bool cs_post_mesh_exists(int mesh_id)
Check for the existence of a post-processing mesh of the given id.
Definition cs_post.cpp:5575
void cs_post_define_existing_mesh(int mesh_id, fvm_nodal_t *exp_mesh, int dim_shift, bool transfer, bool auto_variables, int n_writers, const int writer_ids[])
Create a post-processing mesh associated with an existing exportable mesh representation.
Definition cs_post.cpp:4807
fvm_writer_time_dep_t cs_post_get_writer_time_dep(int writer_id)
Return time dependency associated to a writer_id.
Definition cs_post.cpp:5981
Definition fvm_writer.h:57
Definition cs_function.h:121
Definition cs_time_control.h:96
time step descriptor
Definition cs_time_step.h:64
