#include "base/cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_printf.h"#include "base/cs_ale.h"#include "base/cs_coupling.h"#include "base/cs_fan.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_operator.h"#include "base/cs_field_pointer.h"#include "base/cs_function_default.h"#include "base/cs_gas_mix.h"#include "base/cs_ibm.h"#include "base/cs_internal_coupling.h"#include "base/cs_mobile_structures.h"#include "base/cs_parameters.h"#include "base/cs_parameters_check.h"#include "base/cs_physical_constants.h"#include "base/cs_physical_properties.h"#include "base/cs_porous_model.h"#include "base/cs_porosity_from_scan.h"#include "base/cs_post.h"#include "base/cs_pressure_correction.h"#include "base/cs_prototypes.h"#include "base/cs_restart.h"#include "base/cs_runaway_check.h"#include "base/cs_syr_coupling.h"#include "base/cs_thermal_model.h"#include "base/cs_turbomachinery.h"#include "base/cs_velocity_pressure.h"#include "base/cs_vof.h"#include "base/cs_wall_condensation.h"#include "base/cs_wall_distance.h"#include "base/cs_wall_functions.h"#include "cdo/cs_domain_setup.h"#include "gui/cs_gui.h"#include "gui/cs_gui_boundary_conditions.h"#include "gui/cs_gui_mobile_mesh.h"#include "gui/cs_gui_output.h"#include "gui/cs_gui_radiative_transfer.h"#include "gui/cs_gui_specific_physics.h"#include "lagr/cs_lagr.h"#include "lagr/cs_lagr_options.h"#include "mesh/cs_mesh_location.h"#include "rayt/cs_rad_transfer.h"#include "rayt/cs_rad_transfer_fields.h"#include "rayt/cs_rad_transfer_options.h"#include "turb/cs_turbulence_model.h"#include "pprt/cs_physical_model.h"#include "atmo/cs_atmo.h"#include "atmo/cs_atmo_variables.h"#include "atmo/cs_at_data_assim.h"#include "cfbl/cs_cf_thermo.h"#include "cogz/cs_combustion_gas.h"#include "cogz/cs_combustion_read_data.h"#include "comb/cs_coal_read_data.h"#include "ctwr/cs_ctwr.h"#include "ctwr/cs_ctwr_variables.h"#include "elec/cs_elec_model.h"#include "gwf/cs_gwf.h"#include "base/cs_setup.h"Functions | |
| void | cs_setup (void) |
| Setup computation based on provided user data and functions. | |
| void cs_setup | ( | void | ) |
