cs_domain_setup.h
1#ifndef __CS_DOMAIN_SETUP_H__
2#define __CS_DOMAIN_SETUP_H__
5 * Manage the definition/setting of a computation
31 * Local headers
34#include "base/cs_defs.h"
36#include "cdo/cs_domain.h"
37#include "base/cs_param_types.h"
38
43/*============================================================================
44 * Macro definitions
46
48 * Type definitions
50
51/*============================================================================
52 * Global variables
53 *============================================================================*/
54
55/*============================================================================
56 * Public function prototypes
58
59/*----------------------------------------------------------------------------*/
68/*----------------------------------------------------------------------------*/
69
70void
72 int nt_max,
73 double t_max);
74
75/*----------------------------------------------------------------------------*/
83/*----------------------------------------------------------------------------*/
84
85void
87
88/*----------------------------------------------------------------------------*/
98/*----------------------------------------------------------------------------*/
99
100cs_xdef_t *
102 cs_time_func_t *func,
103 void *func_input);
104
105/*----------------------------------------------------------------------------*/
112/*----------------------------------------------------------------------------*/
113
114void
116 double dt);
117
118/*----------------------------------------------------------------------------*/
125/*----------------------------------------------------------------------------*/
126
127void
129
130/*----------------------------------------------------------------------------*/
140/*----------------------------------------------------------------------------*/
141
142void
144
145/*----------------------------------------------------------------------------*/
151/*----------------------------------------------------------------------------*/
152
153void
155
156/*----------------------------------------------------------------------------*/
162/*----------------------------------------------------------------------------*/
163
164void
166
167/*----------------------------------------------------------------------------*/
174/*----------------------------------------------------------------------------*/
175
176void
178
179/*----------------------------------------------------------------------------*/
185/*----------------------------------------------------------------------------*/
186
187void
188cs_domain_setup_log(const cs_domain_t *domain);
189
190/*----------------------------------------------------------------------------*/
191
193
194#endif /* __CS_DOMAIN_SETUP_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
void cs_domain_setup_log(const cs_domain_t *domain)
Summary of the main domain settings.
Definition cs_domain_setup.cpp:881
void cs_domain_setup_initialize(cs_domain_t *domain)
First setup stage of the cs_domain_t structure Define extra domain boundaries Setup predefined equati...
Definition cs_domain_setup.cpp:603
void cs_domain_def_time_step_by_value(cs_domain_t *domain, double dt)
Define the value of the time step.
Definition cs_domain_setup.cpp:434
void cs_domain_set_time_param(cs_domain_t *domain, int nt_max, double t_max)
Set parameters for unsteady computations: the max number of time steps or the final physical time of ...
Definition cs_domain_setup.cpp:329
void cs_domain_setup_init_cdo_structures(cs_domain_t *domain)
After having read the mesh and the first setup stage build the connectivities and mesh quantities rel...
Definition cs_domain_setup.cpp:472
cs_xdef_t * cs_domain_def_time_step_by_function(cs_domain_t *domain, cs_time_func_t *func, void *func_input)
Define the value of the time step thanks to a predefined function.
Definition cs_domain_setup.cpp:386
void cs_domain_setup_finalize_module(cs_domain_t *domain)
Last user setup stage of the cs_domain_t structure.
Definition cs_domain_setup.cpp:756
void cs_domain_setup_init_state(cs_domain_t *domain)
Initialize systems of equations and their related field/properties values according to the user setti...
Definition cs_domain_setup.cpp:817
void cs_domain_automatic_time_step_settings(cs_domain_t *domain)
Set time step parameters for unsteady computations when this is not already done. This situation shou...
Definition cs_domain_setup.cpp:351
void cs_domain_setup_finalize(cs_domain_t *domain)
Last GUI and then user setup stage of the cs_domain_t structure.
Definition cs_domain_setup.cpp:706
@ dt
Definition cs_field_pointer.h:65
void cs_time_func_t(double time, void *input, cs_real_t *retval)
Function which defines the evolution of a quantity according to the current time and any structure gi...
Definition cs_param_types.h:172
Definition cs_domain.h:129
Definition cs_xdef.h:160
