◆ cs_domain_automatic_time_step_settings()
| void cs_domain_automatic_time_step_settings |
cs_domain_t * | domain | ) |
Set time step parameters for unsteady computations when this is not already done. This situation should occur when the GUI is used to set a constant time step.
- Parameters
◆ cs_domain_def_time_step_by_function()
Define the value of the time step thanks to a predefined function.
- Parameters
| [in] | func | pointer to a cs_time_func_t function |
| [in] | func_input | pointer to a structure cast on-the-fly |
- Returns
- a pointer to the created definition (cs_xdef_t structure)
◆ cs_domain_def_time_step_by_value()
| void cs_domain_def_time_step_by_value |
cs_domain_t * | domain, |
double | dt ) |
Define the value of the time step.
- Parameters
| [in] | dt | value of the constant time step |
◆ cs_domain_set_time_param()
| void cs_domain_set_time_param |
int | nt_max, |
double | t_max ) |
Set parameters for unsteady computations: the max number of time steps or the final physical time of the simulation.
- Parameters
| [in] | nt_max | max. number of time step iterations |
| [in] | t_max | final physical time of the simulation |
◆ cs_domain_setup_finalize()
Last GUI and then user setup stage of the cs_domain_t structure.
- Parameters
◆ cs_domain_setup_finalize_module()
| void cs_domain_setup_finalize_module |
Last user setup stage of the cs_domain_t structure.
- Parameters
◆ cs_domain_setup_init_cdo_structures()
| void cs_domain_setup_init_cdo_structures |
After having read the mesh and the first setup stage build the connectivities and mesh quantities related to CDO/HHO schemes.
- Parameters
◆ cs_domain_setup_init_state()
| void cs_domain_setup_init_state |
Initialize systems of equations and their related field/properties values according to the user settings.
- Parameters
◆ cs_domain_setup_initialize()
| void cs_domain_setup_initialize |
First setup stage of the cs_domain_t structure Define extra domain boundaries Setup predefined equations Create fields (already done in the FV part) Define cs_sles_t structures for variable fields.
- Parameters
◆ cs_domain_setup_log()
Summary of the main domain settings.
- Parameters
| [in] | domain | pointer to the cs_domain_t structure to summarize |
