cs_wall_distance.h
1#ifndef __CS_WALL_DISTANCE_H__
2#define __CS_WALL_DISTANCE_H__
5 * Compute distance to wall.
35 * Local headers
38#include "base/cs_defs.h"
45 * Type definitions
48typedef struct {
49
51
53
67 int method;
68
70
71/*=============================================================================
72 * Static global variables
73 *============================================================================*/
74
75/* Pointer to main time step structure */
76
78
79/*=============================================================================
80 * Public function prototypes
81 *============================================================================*/
82
83/*----------------------------------------------------------------------------*/
84/*
85 * \brief Compute distance to wall by solving a 3d diffusion equation.
86 *
87 * \param[in] iterns iteration number on Navier-Stokes equations
88 */
89/*----------------------------------------------------------------------------*/
90
91void
92cs_wall_distance(int iterns);
93
95/*
96 * \param[in] visvdr dynamic viscosity in edge cells after
97 * driest velocity amortization
98 */
100
101void
103
104/*----------------------------------------------------------------------------*/
109/*----------------------------------------------------------------------------*/
110
111void
113
114/*----------------------------------------------------------------------------*/
120/*----------------------------------------------------------------------------*/
121
124
125/*----------------------------------------------------------------------------*/
126
128
129#endif /* __CS_WALL_DISTANCE_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
const cs_wall_distance_options_t * cs_glob_wall_distance_options
Definition cs_wall_distance.cpp:104
void cs_wall_distance(int iterns)
Compute distance to wall by solving a 3d diffusion equation. Solve.
Definition cs_wall_distance.cpp:137
void cs_wall_distance_geometric(void)
Compute distance to wall by a brute force geometric approach (serial only)
Definition cs_wall_distance.cpp:1068
void cs_wall_distance_yplus(cs_real_t visvdr[])
Compute the dimensionless distance to the wall solving a steady transport equation.
Definition cs_wall_distance.cpp:625
cs_wall_distance_options_t * cs_get_glob_wall_distance_options(void)
Provide read/write access to cs_glob_wall_distance.
Definition cs_wall_distance.cpp:1142
Definition cs_wall_distance.h:48
int need_compute
Definition cs_wall_distance.h:50
int is_up_to_date
Definition cs_wall_distance.h:52
int method
Definition cs_wall_distance.h:67
