#include "base/cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "ple_locator.h"#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_array.h"#include "base/cs_assert.h"#include "base/cs_base.h"#include "base/cs_coupling.h"#include "base/cs_io.h"#include "base/cs_mem.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_connect.h"#include "mesh/cs_mesh_location.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parall.h"#include "base/cs_preprocessor_data.h"#include "base/cs_timer.h"#include "base/cs_timer_stats.h"#include "fvm/fvm_nodal.h"#include "fvm/fvm_interpolate.h"#include "base/cs_restart.h"#include "base/cs_restart_map.h"Functions | |
| void | cs_restart_map_set_mesh_input (const char *mesh_path) |
| Indicate restart files should be mapped to a given mesh input. | |
| void | cs_restart_map_set_options (bool apply_mesh_deformation, float tolerance_base, float tolerance_fraction) |
| Set options relative to restart file mapping to a given mesh input. | |
| void | cs_restart_map_set_locations (bool map_cell_centers, bool map_vertices) |
| Indicate whether location for restart file mapping is needed at cells or vertices. | |
| void | cs_restart_map_build (void) |
| Build mapping of restart files to different mesh if defined. | |
| void | cs_restart_map_free (void) |
| Free restart file mapping to different mesh. | |
| void cs_restart_map_build | ( | void | ) |
| [in] | need_vertices | indicate if location at vertices is needed |
| void cs_restart_map_free | ( | void | ) |
Revert restart reading to default behavior.
By default, mapping is done for cell-based quantities, but not for vertex-based quantities.
Mapping of quantities at faces or particles is not handled yet, but will use the cell-center or vertex based mappings in the future in all cases:
| [in] | map_cell_centers | locate cell centers in the previous mesh. |
| [in] | map_vertices | locate vertices in the previous mesh. |
| void cs_restart_map_set_mesh_input | ( | const char * | mesh_path | ) |
| [in] | mesh_path | path to mesh input |
| void cs_restart_map_set_options | ( | bool | apply_mesh_deformation, |
| float | tolerance_base, | ||
| float | tolerance_fraction ) |
| [in] | apply_mesh_deformation | apply mesh deformation from upstream computation (if present) so as to map to final, and not initial mesh shape. |
| [in] | tolerance_base | associated base tolerance (used for bounding box check only, not for location test) |
| [in] | tolerance_fraction | associated fraction of element bounding boxes added to tolerance |
