cs_restart_map.h
1#ifndef __CS_RESTART_MAP_H__
2#define __CS_RESTART_MAP_H__
5 * Checkpoint / restart extension to mapped meshes
35 * Local headers
38#include "base/cs_defs.h"
39#include "base/cs_restart.h"
45/*============================================================================
46 * Macro definitions
48
49
51 * Local type definitions
53
54
55/*=============================================================================
56 * Global variables
58
59
60/*============================================================================
61 * Public function prototypes
62 *============================================================================*/
63
64/*----------------------------------------------------------------------------*/
70/*----------------------------------------------------------------------------*/
71
72void
73cs_restart_map_set_mesh_input(const char *mesh_path);
74
75/*----------------------------------------------------------------------------*/
88/*----------------------------------------------------------------------------*/
89
90void
91cs_restart_map_set_options(bool apply_mesh_deformation,
92 float tolerance_base,
93 float tolerance_fraction);
94
95/*----------------------------------------------------------------------------*/
117/*----------------------------------------------------------------------------*/
118
119void
120cs_restart_map_set_locations(bool map_cell_centers,
121 bool map_vertices);
122
123/*----------------------------------------------------------------------------*/
127/*----------------------------------------------------------------------------*/
128
129void
131
132/*----------------------------------------------------------------------------*/
138/*----------------------------------------------------------------------------*/
139
140void
142
143/*----------------------------------------------------------------------------*/
144
146
147#endif /* __CS_RESTART_MAP_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:543
void cs_restart_map_free(void)
Free restart file mapping to different mesh.
Definition cs_restart_map.cpp:709
void cs_restart_map_build(void)
Build mapping of restart files to different mesh if defined.
Definition cs_restart_map.cpp:544
void cs_restart_map_set_locations(bool map_cell_centers, bool map_vertices)
Indicate whether location for restart file mapping is needed at cells or vertices.
Definition cs_restart_map.cpp:526
void cs_restart_map_set_options(bool apply_mesh_deformation, float tolerance_base, float tolerance_fraction)
Set options relative to restart file mapping to a given mesh input.
Definition cs_restart_map.cpp:491
void cs_restart_map_set_mesh_input(const char *mesh_path)
Indicate restart files should be mapped to a given mesh input.
Definition cs_restart_map.cpp:466
