#include "base/cs_defs.h"#include "base/cs_field.h"#include "base/cs_map.h"#include "base/cs_restart.h"Go to the source code of this file.
Enumerations | |
| enum | cs_restart_file_t { CS_RESTART_DISABLED = -1 , CS_RESTART_MAIN = 0 , CS_RESTART_AUXILIARY = 1 , CS_RESTART_RAD_TRANSFER = 2 , CS_RESTART_LAGR = 3 , CS_RESTART_LAGR_STAT = 4 , CS_RESTART_1D_WALL_THERMAL = 5 , CS_RESTART_LES_INFLOW = 6 , CS_RESTART_IBM = 7 , CS_RESTART_N_RESTART_FILES = 8 } |
| void | cs_restart_read_field_info (cs_restart_t *r, cs_map_name_to_id_t **old_field_map) |
| Read field metadata from checkpoint. | |
| void | cs_restart_write_field_info (cs_restart_t *r) |
| Write field metadata to main checkpoint. | |
| void | cs_restart_read_variables (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, int t_id_flag, int read_flag[]) |
| Read variables from checkpoint. | |
| void | cs_restart_write_variables (cs_restart_t *r, int t_id_flag, int write_flag[]) |
| Write variables to checkpoint. | |
| void | cs_restart_read_notebook_variables (cs_restart_t *r) |
| Read notebook parameters from main checkpoint. | |
| void | cs_restart_write_notebook_variables (cs_restart_t *r) |
| Write notebook parameters to main checkpoint. | |
| void | cs_restart_read_linked_fields (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, const char *key, int read_flag[]) |
| Read fields depending on others from checkpoint. | |
| int | cs_restart_write_linked_fields (cs_restart_t *r, const char *key, int write_flag[]) |
| Write fields depending on others to checkpoint. | |
| void | cs_restart_read_bc_coeffs (cs_restart_t *r) |
| Read boundary condition coefficients for all fields from checkpoint. | |
| void | cs_restart_write_bc_coeffs (cs_restart_t *r) |
| Write boundary condition coefficients for all fields to checkpoint. | |
| int | cs_restart_read_field_vals (cs_restart_t *r, int f_id, int t_id) |
| Read field values from checkpoint. | |
| void | cs_restart_write_field_vals (cs_restart_t *r, int f_id, int t_id) |
| Write field values to checkpoint. | |
| void | cs_restart_read_time_step_info (cs_restart_t *r) |
| Read restart time step info. | |
| void | cs_restart_write_fields (cs_restart_t *r, cs_restart_file_t r_id) |
| Loop over all fields and save them in the restart file which id is passed in argument if it matches their "restart_file" key value. | |
| void | cs_restart_read_fields (cs_restart_t *r, cs_restart_file_t r_id) |
| Loop over all fields and read them in the restart file which id is passed in argument if it matches their "restart_file" key value. | |
| void | cs_restart_set_auxiliary_field_options (void) |
| Set restart file values for fields when those values cannot be determined at field definition time. | |
| void | cs_restart_initialize_fields_read_status (void) |
| Initialize fields read status array. | |
| void | cs_restart_finalize_fields_read_status (void) |
| Finalize fields read status array. | |
| int | cs_restart_get_field_read_status (const int f_id) |
| Get checkpoint read status for a field based on its id. | |
| enum cs_restart_file_t |
Restart file ids
| void cs_restart_finalize_fields_read_status | ( | void | ) |
| int cs_restart_get_field_read_status | ( | const int | f_id | ) |
| [in] | f_id | field id |
| void cs_restart_initialize_fields_read_status | ( | void | ) |
| void cs_restart_read_bc_coeffs | ( | cs_restart_t * | r | ) |
| [in,out] | r | associated restart file pointer |
| void cs_restart_read_field_info | ( | cs_restart_t * | r, |
| cs_map_name_to_id_t ** | old_field_map ) |
Old ids associated to each field are determined for future use. Note that when reading legacy files (code_saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
| [out] | old_field_map | name to id map of fields in restart file |
| int cs_restart_read_field_vals | ( | cs_restart_t * | r, |
| int | f_id, | ||
| int | t_id ) |
If the values are not found using the default rules based on the field's name, its name itself, or a "restart_rename" keyed string value, an old name may be used for compatibility with older files. For cell-based fields, the old name base is appended automatically with "_ce_phase01", except for scalars, where the name uses a different scheme, based on "scalaire_ce_%04" % s_num;
| [in] | t_id | time id (0 for current, 1 for previous, ...) |
| void cs_restart_read_fields | ( | cs_restart_t * | r, |
| cs_restart_file_t | r_id ) |
| [in] | r_id | value of the key "restart_file" |
| void cs_restart_read_linked_fields | ( | cs_restart_t * | r, |
| const cs_map_name_to_id_t * | old_field_map, | ||
| const char * | key, | ||
| int | read_flag[] ) |
Old ids associate to each field are determined for future use. Note that when reading legacy files (code_saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
| [in] | old_field_map | name to id map of fields in restart file |
| [in] | key | key for field association |
| [in,out] | read_flag | optional flag to track fields read, or nullptr; set to sum of 2^time_id for fields read, -1 for fields failed to read (size: n_fields) |
| void cs_restart_read_notebook_variables | ( | cs_restart_t * | r | ) |
| void cs_restart_read_time_step_info | ( | cs_restart_t * | r | ) |
| void cs_restart_read_variables | ( | cs_restart_t * | r, |
| int | t_id_flag, | ||
| [in] | t_id_flag | -1: all time values; 0: current values; > 0: previous values |
| [in,out] | read_flag | optional flag to track fields read, or nullptr; set to sum of 2^time_id for fields read (size: n_fields) |
| void cs_restart_set_auxiliary_field_options | ( | void | ) |
This is needed when the need for restart data depends on various combinations of settings.
| void cs_restart_write_bc_coeffs | ( | cs_restart_t * | r | ) |
| void cs_restart_write_field_info | ( | cs_restart_t * | r | ) |
| void cs_restart_write_field_vals | ( | cs_restart_t * | r, |
| int | f_id, | ||
| int | t_id ) |
| void cs_restart_write_fields | ( | cs_restart_t * | r, |
| int cs_restart_write_linked_fields | ( | cs_restart_t * | r, |
| int | write_flag[] ) |
| [in,out] | write_flag | optional flag to track fields written, or nullptr; set to sum of 2^time_id for fields written (size: n_fields) |
| void cs_restart_write_notebook_variables | ( | cs_restart_t * | r | ) |
| void cs_restart_write_variables | ( | cs_restart_t * | r, |
