mesh.f90 File Reference
Module for mesh-related arrays. More...
Modules
module  mesh
Functions/Subroutines
elemental pure integer function ifacel (iside, ifac)
 Index-numbers of the two (only) neighboring cells for each internal face
elemental pure integer function ifabor (ifac)
 index-number of the (unique) neighboring cell for each boundary face
integer ndim
 spatial dimension (3)
integer, save ncelet = 0
 number of extended (real + ghost of the 'halo') cells. See Note 1: ghost cells - (halos)
integer, save ncel = 0
 number of real cells in the mesh
integer, save nfac = 0
 number of internal faces (see Note 2: internal faces)
integer, save nfabor = 0
 number of boundary faces (see Note 2: internal faces)
integer, dimension(:,:), pointer ifacel_0
integer, dimension(:), pointer ifabor_0
double precision, dimension(:,:), pointer xyzcen
 coordinate of the cell centers
double precision, dimension(:,:), pointer surfac
 surface vector of the internal faces. Its norm is the surface of the face and it is oriented from ifacel(1,.) to ifacel(2,.)
double precision, dimension(:,:), pointer surfbo
 surface vector of the boundary faces. Its norm is the surface of the face and it is oriented outwards
double precision, dimension(:,:), pointer suffac
 fluid surface vector of the internal faces. Its norm is the surface of the face and it is oriented from ifacel(1,.) to ifacel(2,.)
double precision, dimension(:,:), pointer suffbo
 fluid surface vector of the boundary faces. Its norm is the surface of the face and it is oriented outwards
double precision, dimension(:,:), pointer cdgfac
 coordinates of the centers of the internal faces
double precision, dimension(:,:), pointer cdgfbo
 coordinates of the centers of the boundary faces
double precision, dimension(:), pointer volume
 volume of each cell
double precision, dimension(:), pointer cell_f_vol
 fluid volume of each cell
double precision, dimension(:), pointer surfan
 norm of the surface vector of the internal faces
double precision, dimension(:), pointer surfbn
 norm of the surface of the boundary faces
double precision, dimension(:), pointer suffan
 norm of the fluid surface vector of the internal faces
double precision, dimension(:), pointer suffbn
 norm of the fluid surface of the boundary faces
double precision, dimension(:), pointer dist
 for every internal face, dot product of the vectors $ \vect{IJ}$ and $\vect{n}$. I and J are respectively the centers of the first and the second neighboring cell. The vector $\vect{n}$ is the unit vector normal to the face and oriented from the first to the second cell
double precision, dimension(:), pointer distb
 For every boundary face, dot product between the vectors $\vect{IF}$ and $\vect{n}$. I is the center of the neighboring cell. F is the face center. The vector $\vect{n}$ is the unit vector normal to the face and oriented to the exterior of the domain
double precision, dimension(:), pointer pond
 weighting (Aij=pond Ai+(1-pond)Aj) for every internal face, $\displaystyle\frac{\vect{FJ}.\vect{n}}{\vect{IJ}.\vect{n}}$. With regard to the mesh quality, its ideal value is 0.5
double precision, dimension(:,:), pointer dijpf
 vector I'J' for interior faces for every internal face, the three components of the vector $\vect{I'J'}$, where I' and J' are respectively the orthogonal projections of the neighboring cell centers I and J on a straight line orthogonal to the face and passing through its center
double precision, dimension(:,:), pointer diipb
 vector II' for interior faces for every boundary face, the three components of the vector $\vect{II'}$. I' is the orthogonal projection of I, center of the neighboring cell, on the straight line perpendicular to the face and passing through its center
double precision, dimension(:,:), pointer dofij
 vector OF for interior faces for every internal face, the three components of the vector $\vect{OF}$. O is the intersection point between the face and the straight line joining the centers of the two neighboring cells. F is the face center
